Question about Motorola Mobility RAZR V3m Cellular Phone
PLEASE HELP! Ok, so I have bought this Motorola Razor phone for half a year now, and it won't turn on. I don't know if this is charging it, but when i plug in the wire that i use for my mouse into the phone, it shows a lilttle red circle at the top left corner of the front screen (phone closed.) Please help, I'm STUCK.
    Problem Solver:
  • 5 Answers
Something is wrong with your phone charger you'll have to buy a new one
Posted on Apr 27, 2008
I have a jabra ote3 bluetooth. i don't have the manual. can i connect the bluetooth to a verizon motorola razor?
Yes,You can connect the Jabra head set to motorola razor.
Please follow the steps to connect it to motorola razor
1. Turn headset off. Press and hold until solid light comes on.
2. Activate Bluetooth on your phone.
3. Search for Bluetooth devices and select Jabra BT2070.
4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 .
Thank You
Aug 11, 2010 | Cell Phones
Motorola Razor will not charge
turn the lights off in a room while the phone is on and see if you can see a light coming from the phone while it is closed and on.if you have a new battery did you let it fully charge before using.make sure the blue tooth is turned off.
May 13, 2010 | Motorola Mobility RAZR V3
Won t charge
Download Motorola Phone tools and get a new battery for your phone.
The batteries go bad about once a year, sometimes longer.
if this helps you please leave a vote on fixya
May 21, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Razor
HI,
Every phone battery has a life cycle. if the battery is more than year old , it most probably requires a replacement. As its not able to retain charge. If its under one year , get the same replaced from the motorola service center . I had the same problem with my razor and they replaced it free of charge as the same was under 1 yr .
Thanks
Proton
Apr 22, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Razor phone won't charge
Hi, I had the same problem with my Old Razor, I bought a new battery and that fixed the problem.
New Batteries for Razors are around £6 - £7 online. google it.
Apr 16, 2009 | Motorola Mobility RAZR V3
Motorola V3 battery suddenly empty
You really need to Upgrade to a New Phone. My RAZR did the Same thing for over a Year and a Half until the Flip screen went Completely Blank.
Jan 04, 2009 | Motorola Mobility RAZR V3
Phone shuts down during a charge
change the battery and if that does not work take the phone and have the service center reflash the firmware on the phone this method should correct it.
Aug 28, 2007 | Motorola Mobility RAZR V3
Motorola Razor won't turn on
you will have to make the time and get to a service center that is the only way it can be fix
Aug 26, 2007 | Motorola Mobility RAZR V3
Usb port
yes you are but you may not have done it properly so you should take it to a professional service center or technician and have them do the repair for you.
Aug 23, 2007 | Motorola Mobility RAZR V3
Motorola razor
try ur old battery if not ok check the voltage level of ur battery if it is 3.6 volts and mobile is still not on then may be software prob. but if have less than 3.6 volts bost ur battery with boaster if u dont have boster put ur mobile on charge for some time 30 minute if the prob is from battery this will began to charge withing 30 minute.
Mar 18, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3m Cellular Phone Logo
44 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
