Question about Ecoquest Breeze AT Living Air Purifier
Ecoquest breeze problems
It blows fuses quickly, but when it works it clicks on then off, on then off etc
Its a 250v  1 amp fuse, Radio Shack has them
Posted on Aug 15, 2008
You might want to make sure that the back screen is in the whole way. I had that problem and that fixed it. What size fuse does it take. I am trying to find it. I through it out with a DVD fuse and don't know which was which.
Posted on Jun 18, 2008
Will not turn on - no power at all
If your Breeze was working, but you cleaned it and now it won't turn on, the problem almost certainly is with the reassembly of the components. Go through the following checklist.
1) Make sure the plug in the back is inserted firmly and the wall socket is live.
2) The little switch by the plug should have the "I" end depressed and the "0" end up.
3) Check to make sure the back screen is inserted firmly, depressing the interior safety switch. (It will click when positioned correctly).
4) Make sure the plates are inserted correctly, with the top and bottom in the little grooves and the metal fingers pressing firmly on the screen part of the plate. You may need to twist the white upright posts slightly to align the contacts.
5) Try both the manual and remote controls. If the manual controls work, but the remote ones do not, check to see if the little plastic battery shield is still in the remote. Remove it by pulling on the little tab. If that's not the issue, also try a new battery in the remote. If one set of controls works, but the other doesn't, you may operate the machine with only the working controls and ignore the others.
6) If none of the above suggestions helps, remove the plug in back, and pull out the fuse to see if it is blown. Very infrequently, a sudden powerup or power surge will blow the fuse. If so, replace it with the EXACT same size fuse, available at an auto parts store.
If none of these troubleshooting steps works, then it would appear that the problem is in the computerization. Unfortunately, Vollara (new name for EcoQuest) is no longer servicing nor selling the Breeze. Your only option to get it fixed would be to find a dealer who still has some, along with extra parts, in stock. If you call Customer Service, they will give you some trade-up options. 800-989-2299. Use #16618 if you need a referral number.
Feb 12, 2011 | Ecoquest Breeze AT Living Air Purifier
When I turn on the unit it imeadiately blows the little fuse in it.
The problem can be one of several things. 1) Make sure the fuse is the EXACT size required. 2) Check the metal contact points (fingers) that press into the plate. If they aren't firmly in place, you may need to turn the white posts, or bend them slightly. 3) Make sure the plate is clean and not damaged in any way. If you see black marks, broken screen strands, loosened glue, discoloration, or cracked background at all, you need a new plate. Call the company (New name Vollara) 800-989-2299 to order new plates. Give 16618 as the dealer referral number. The company is no longer manufacturing or repairing the Breeze, but if none of the above suggestions work, you also can email us at fredandmb@frontier.com and we may be able to help you.
Feb 07, 2011 | Ecoquest Breeze AT Living Air Purifier
I went to ( www.ecoquest.com (click on the DOWNLOADS tab, then on OTHER on the green bar. The Breeze AT is in the Owner's Manuals list) as suggested by Guru but the page is not active. I have searched...
jenirod: EcoQuest is now Vollara. The Breeze is no longer available in our product line, but it sounds like your problem is an easy fix. We've been with the company for 20+ years (Alpine/EcoQuest/Vollara). You can contact us at fredandmb@frontier.com.
Jan 12, 2011 | Ecoquest Breeze AT Living Air Purifier
Fuse blows
HOW CAN I CLEAN THE INSIDE OF MY BREEZE?
Feb 26, 2010 | Ecoquest Breeze AT Living Air Purifier
Does the breeze at have one or 2 fuses
It has one fuse. A 1.0 Amp slow blow for 110 volt models and 0.5 Am slow blow for 220 volt models.
Nov 30, 2009 | Ecoquest Breeze AT Living Air Purifier
Will not turn on Have checked switch under filter Have checked continuity of the fuse plates are making contact Ecoquest Breeze AQ
Have you checked the fuse? It is located in back of the Breeze in the fuse holder next to where the plug connects to the purifier. It uses a 1.0 Amp slow blow for 110 volt models and 0.5 Amp slow blow for 220 volt models.
Oct 28, 2009 | Ecoquest Breeze AT Living Air Purifier
Fan works but no light on inside the unit.
The most common problem I have found with Breeze ATs not producing ozone is corroded terminal ends. The second most common problem is the coil that energizes the plate. The terminal ends are easily replaced. If the coil is bad, it is my understanding that Ecoquest is no longer servicing the Breeze and I don't know a source for them. Another possibility is that the contacts which touch the plate are not making firm contact.
Aug 31, 2009 | Ecoquest Breeze AT Living Air Purifier
What type of fuse do you get for a Breeze AT EcoQuest unit?
A buss type fuse is like the glass tubeb with metal ends and just snaps in two clamp type holder. Any automotive store carries them. know what amperage, like 5, 10,15 ,20 etc. The 250 v is the norm. The fuse protects against amperage overload not voltage. They come in tins of assorted or specifc in fives. Good luck
Jun 21, 2009 | Ecoquest Breeze AT Living Air Purifier
Purifier doesn't go on and keeps blowing fuses when turned on
If the machine keeps blowing fuses there is a short in the electrical circuit and it needs to be looked at by a certified repair center.
Make sure the fuses you replace are the same as the original
100,110 volt models use the 1.0 amp slow blow fuse
220 volt models use the 0.5 amp slow blow fuse.
I hope this helps
Eric
Jan 10, 2009 | Ecoquest Breeze AT Living Air Purifier
Is there a problem with putting the Ecoquest Breeze close to or around a computer
I wonder if it has anything to do with traping the dust from getting into the computer. I've never heard of one being used that way before.
Sep 07, 2008 | Ecoquest Breeze AT Living Air Purifier
Ecoquest Breeze AT Living Air Purifier Logo
236 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
