Question about ASUS P4S8X Motherboard
Sata and IDE hard drive
I have both ports on my mother board for Sata and IDE. Currently I have two hard drives installed and operational that function off of the IDE cable (40 pin). I want to add another hard drive to the computer utilizing the SATA connection (without removing any of my old hard drives). Will the motherboard allow me to have 2 hard drives. 1 connected to IDE and one to the SATA and work properly?
  • Anonymous May 31, 2008
    computer win't find sata hard drive
    Scholar:
  • 75 Answers
yes your motherboard would allow this .. once you configure in the bois your boot drive being the IDE drives ....the operation of the other drives should be a breeze ...
Posted on Apr 27, 2008
How do i get my sata ports on my motherboard to work?
Hi there. I think your board is an early SATA board as it has IDE connectors too. I am not able to access the website you have listed but have had a fair bit of experience with SATA drives on such boards. It might well be that there is an option in your bios to switch between native SATA support and IDEmode. If you can find such a facility in bios then try changing it. You should try the drive on another machine to ensure that it is not defective, if the drive is a new one then try it on a very recent machine.
The issue might that the hard drive is not compatible with your board, some SATA3 drives will not work on older boards. The is true of some SATA2drives. It might just be an incompatibility issue.
Good Luck
Feb 10, 2015 | Computers & Internet
Does the mother board Asrock 845GV (P4I45GV) support pci sata card
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 19, 2011 | Asrock 845GV (P4I45GV) Motherboard
My bio-star p4m800-m7 mother board won't detect my 1terabyte sata hard disk, currently i'm using 160gb ide hard disk....i need to have additional storage...but the system cant detect sata...need...
Hello,Please check the BIOS to see if the SATA ports are enabled. Older boards will disable the sata ports in the BIOS by default. To enter the BIOS, hit the DEl key as soon as you boot the PC.
If ports are enabled, then you probably have to format the drive.Heres how:1. Right-click My Computer and select Manage.
2. Under Storage, click Disk Management on the left pane.
STEP 3 - Format the device / drive / MP3 player
1. Right-click on the 1 TB drive you want to format then select Format.Windows will not recognize the drives file system and will mount it with a drive letter. ex; E:
Sep 09, 2011 | EliteGroup P4M800-M7 Motherboard
Sata power supply with ide only mother board?
If all the motherboard has is IDE connectors,then you can with an add in card. To do this you need to run the installation floppy during a fresh windows installation when it prompts for 3rd party scsi or raid drivers. I'd take the easy road & install a slave drive on the IDE or run an external hard drive in a usb port. Or the ultimate option,build a system using a board with sata on it. Prices are way down on hardware in general,but it's not going to stay that way.
May 14, 2010 | Computers & Internet
Unlike IDE drive cables, which allow you to connect at least 2 drives to the same cable, SATA cables only allow one connection from motherboard to drive per cable. You can connect as many SATA drives to your motherboard as you have SATA connections.
Mar 25, 2010 | Computers & Internet
What is this system ide or ?? looking to purchase a hard drive (500gb) and a new CD & DVD burner.. Just don't want to buy the wrong item.
What mother board is it? you have sata and ide drives.. new technology is sata which is connected with sata cable to *********** board and appropriate pover coard, the older teconlogy is ide, which is connected with ide (master slave) cable frm you motehr board to you drive... just post what mother board and i could be more specific...
Jun 28, 2009 | HP Pavilion a705w PC Desktop
Add sata HDD
Make sure the power cable of SATA hard drive is properly plugged in or not.. It is possible.. Try with SATA 0..
Thank you........
Aug 30, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
Hard drive installation
You should be able to install that drive. The biggest variable is if it is a SATA or PATA drive. This model was built for SATA drives, but I think you may be able to get a PATA drive to work with the right adapters.
For the step by stem directions see the link below. It will take you right to the Dell support page. Refer to the "Adding a Second Hard Drive" section.
https://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1366406
Feb 21, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
ASUS P4S8X Motherboard Logo
186 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
