Question about RC Toys
Hi, my name is Tony the RC novice. I recently had a hard crash with my Wild Hawk plane on an overhead power line wire. The hatch fell off, then the battery pulled apart from its wiring harness. I put it back together and now the motor will not restart. Any suggestions?
  • ajkoch9231 Aug 08, 2010
    If the motor on my rc plane shorted out, will just replacing the motor work, or will i need another of those voltage controllers too?
    Genius:
  • 1,340 Answers
It may have fried the motor.Did you see sparks?Also what voltage is the battery?I would inspect the wire harness for separation or frayed wiring first or loose connections before you start buying things to attempt repair.You should be able to take it apart right to check it out right?Let me know if you find anything and I will figure out a way to test the battery and motor.Good luck! Greg
Posted on Aug 08, 2010
  • ajkoch9231 Aug 11, 2010
    Hi! I finally tried the motor and battery. The motor is fine; full power when I put the leads from the battery pack on it. I think it is just 8.6 volts, since there are like 7 Nickel metal hydride cells in the pack. when I touch the leads from the battery pack to the controller or whatever it is called- there is just a twitch on one of the rods, either the elevator or the rudder. I don't know which. It is only 3 channel, no airelons or whatever they are called. I don't know much else.
    Got any ideas? thanks!
  • Greg McCarthy Aug 11, 2010
    The elevator is the flat surface on the tail and the rudder is the up and down surface on the tail.The elevator controls height movement,up and down,the rudder controls direction,left and right.3 channels,Speed,height and turn most likely.Since you have speed,you need to determine which is twitching.The elevator should have a fairly wide range of movement,probably the rudder too so it can turn fairly quick and not just do a big loop.Whichever surface is doing the twitch,probably needs a new actuator.Should be a fairly easy fix...possibly$$$ though.I would like to know which surface is twitching and perhaps a little better description such as moves just millimeters or what the twitch is such as you move only one direction and it just barely moves or whatever if you know what I mean.Also,obviously make sure the other surface works fairly normal so you only have to make 1 order.When you do replace,either write down which wire goes where or some method to ensure proper wiring.Does the battery list it's rated voltage too?7 cells 8.6V sounds about right but is a rating I have never heard of.Let me know how you make out and watch out for power lines!lol.Flying is tough if you never have done it or studied aerodynamics of flight before.Good luck! Greg P.S.Be aware of airports nearby.There are FAA restrictions about proximity of RC planes to the airport in case you did not know.Just mentioning it because many people do not know and I do not know if that is in your directions.
    President:
  • 2,030 Answers
If you hit a power line, you probably shorted out the motor from the high voltage
I recently purchased a Fast Lane Hawk 4 rc helicopter. After a few small "crashes", it shakes and doesnt fly well. Does the top rotor need replacing, and if so, can I get the parts for it?
I have the same one, i have searched long and hard for parts for this without much sucsess, allthough i have found this on ebay, the blades and rotor look very simular
http://www.ebay.co.uk/itm/Metal-3-Ch-RC-Mini-Helicopter-Main-Tail-Blade-SET-G-/140315300745
Its slightly diffrent but i think the blades should fit the hawk 4. In the mean time i shall keep looking.
Sep 20, 2011 | Toys
Tony Hawk ride board will not power up. New batteries have been installed.
you should take it to walmart to exchange for a new one.
it should work even if you have no proof you bought it there.
let me know.
doug.
http://www.fun-4me.com/tony-hawk/ Tony Hawk Ride and Shred Forums
Jun 23, 2011 | Video Game Consoles & Games
I need to know how to take a chain off of a Tony Hawk Homer Bicycle. Please let me know. Thank you. Nicholas
You need a chain breaker tool, it presses a link pin out but DO not press the pin totally out of both links, it would be very hard to reinstall.
Apr 02, 2011 | Dynacraft Tony Hawk Homer Boy's 20-Inch...
Hawk talon v3 - bottom rotor won't spin
I just got one for Christmas too. Had it flying for 10 seconds, and lost control. I have to work on my piloting skills! After that initial crash, I prepared for another take off and realized my lower rotor was not spinning. It turns out that the tiny vertical gear that powers the lower rotor gear fell off its axle. The axle is connected to the sensor that receives the signal from the throttle. Luckily, I found that tiny gear sitting inside the head of my helicopter. After spending 2 hours trying to place it back on the axle, I got it running again. The rotor was spinning again, but it wouldn't take off. I did some troubleshooting, adjusting the trim multiple times. Then the gear fell off again. I found it and noticed that I had damaged the plastic teeth from using my tweezers to reinstall it. You can go to Team-RC.com to buy a complete gear system for $6.95. You won't need to replace all of the gears, just the one that fell off, and it's always a good idea to have spare parts just in case.
Happy flying
P.
Dec 28, 2010 | Team International Hawk Talon V3 RC Indoor...
Tony Hawk Shred board will not calibrate. Help!
I had the same problem. I turned the WII so the dongle/sensor that comes with the game is facing the skateboard with a clear line of sight between the dongle/sensor and skateboard. Now it's able to calibrate. Hope this works for you.
Dec 25, 2010 | Activision Tony Hawk Ride for Nintendo Wii
Tony hawk ride for wii-the board won't connect.
IT TOOK 1.5 HOURS TO SYNC UP AND CALIBRATE A NEW TONY HAWK RIDE SKATE BOARD WITH A Wii.
THE ON-LINE DIRECTIONS AND TROUBLESHOOTING = SUX!.
PLEASE FOLLOW THESE DIRECTIONS IF YOUR HAVING THE SAME ISSUE:
1) Remove skateboard battery's for 1 minute
2) Reinstall 4 new/fully charged AA Battery's in the Tony Hawk RIDE Skateboard.
3) Plug the Tony Hawk Wireless USB Dongle into the "upper" WII USB Port,
Turn on the WII,
Insert the Tony Hawk Ride game disk
Keep pressing A on the WII Controller till you get to the Error Screen saying:
*Unable to SYNC up the skateboard with the WII*
4) Make sure the WII and the plugged in wireless USB Dongle are laying on the floor in front of the wireless skateboard "sideways" with the wireless dongle towards the right side of the WII.
5) The directions state to 1st press the wireless USB dongle reset/Sync button, then the so called Start button on the board, which did not work 100 different times.
6) Instead (on the side of the board) all 4 of the blue LED lights were on. Now press and hold the button which is the Start/Home/blue little house/C- looking Button on the side of the board for 5 seconds. The Blue LED lights should now all be off!
7) Now press the WII Wireless USB Dongle reset/Sync button.
8) After the Dongle sync
Oct 26, 2010 | Nintendo Tony Hawk Ride for Wii
I want to sync my tony hawk ride board to my wii but it won't I have tried pressing the dongle button then turning on the board but it won't work
Mine did this to but when i put the tony hawk ride board up next to it and pressed the power button on the side of the board and the reset sync button on the dongle it worked. this is what the button looks like on the board. C- a c with a line through it.
Aug 16, 2010 | Nintendo Wii Console
Tony hawk the ride board connection
Press the button on the dongle, then press and HOLD the power button on the board until it stays solid. had the same problem hope this works
Dec 25, 2009 | Nintendo Wii Console
Tony Hawk Helmet Cam
Ya. Just use Windows movie maker. just add the vids and music tyo your collection and drag them onto the time line below in your order. Vuala!
Mar 11, 2008 | Digital Blue Tony Hawk HelmetCam Camcorder
Toys Logo
24 people viewed this question
Top RC Toys Experts
Tom Chichester
Kevin K.
Brett Duxbury
Brett Duxbury
Are you a RC Toy Expert? Answer questions, earn points and help others
