Question about Samsung Cell Phones
I have the samsung impression and when ever i plug in the usb to share media it never connects wen i plug it in my phone says bluetooth activated usb not available i dont no wat to do i have been trying to fix this for three days please help
  • 50 Answers
Go into your settings and check for a something close to PC Connection. Look in there and make sure it isnt set on "No Connection" it should say PC Studio or Mass Storage
Posted on Aug 08, 2010
How do i use my samsung c5212 as a modem to pc and to connect to internet.
Follow the below mentioned steps : 1. Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
2 Launch Internet Sharing, found in the Start menu on your Samsung cell phone. Open the application.
3 Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than is showing on the display.
4 Start the Internet Sharing connection. On your Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
5 Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
May 14, 2011 | Cell Phones
My problem is that bluetooth is not activated in my mobile phone samsung e250
To turn on Bluetooth, go to Bluetooth under the applications section in the main menu. After clicking Activation, select On to get Bluetooth started on the phone. Once Bluetooth is activated, you can look around for other phones to share. To enable others to see your phone, you must click on My Phone's Visibility then set it to On.
Mar 31, 2011 | O2 Samsung SGH-E250 Cellular Phone
Can i use Samsung omnia i900 windows phone as a modem to connect to intenet?
1. install the Samsung Omnia modem driver on your Windows PC - can be found @http://www.samsungmobile.com/promotion/omnia/fr/sub02_xp.jsp
2. if you have installed Active Sync on your Windows PC then make sure that before you connect your mobile device to PC you disable "Allow USB connections" from the Active SyncOption menu
3. after you connect Samsung Omnia to PC, on your mobile device go to START->PROGRAMS->INTERNET SHARING and select the connection type (bluetooth or USB - most commonly used would be USB); tap "Connect". Your Samsung Omnia will connect to the mobile network if you have set up a profile for GPRS/HSDPA according to your billing plan provided by the network operator.
Feb 27, 2011 | Computers & Internet
I need to use this phone as a modem for internet. How?
  • Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the AT&T Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
  • Launch Internet Sharing, found in the Start menu on your AT&T Samsung cell phone. Open the application.
  • Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than AT&T is showing on the display.
  • Start the Internet Sharing connection. On your AT&T Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
  • Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your AT&T Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
Feb 04, 2011 | Samsung SGHE250i Cell Phone
How to connect htc smart to computer for surfing internet
Using USB...
On the phone, goto Start, Programs, choose internet sharing. On the computer, make sure that activesync doesn't think it is connected, and plug in a mini-usb cable into the phone. After a moment, Windows should detect the new "network connection" and take over from there.
Using Bluetooth,
Open the bluetooth manager. Setup a partnership with the phone (pairing). Once done, goto properties for the partnership, and check "enable network capability' or similar. On the phone, goto Internet Connection Sharing, and switch from USB to Bluetooth. Note, you phone needs to be paired with the computer already.
Sep 22, 2010 | HTC Cell Phones
I got the Samsung A877 Impression and i wanted to know how to put music from my computer on it ... it came with a usb cord but that doesnt seem to want to work with my computer so what do i do ???
you can copy music files in two ways:
1) Send via USB
a) Install the Samsung PC Suite (driver) in your PC/Laptop.
b) Connect the device with the PC/Laptop via the USB cable got.
The PC suite will act as an interface for connecting the mobile to the PC. Use original USB cable for faster & efficient data transfer.
c) The PC suite will give an interface for copying the music files to the mobile, Or, you can directly copy files by accessing the extra drive shown on the MyComputer which denotes the mobile device's memory.
2) Send via Bluetooth
If you have an active bluetooth device available in your PC/Laptop then just send files to the mobile after searching the mobile.
Regards
Vineeth K.
Aug 05, 2010 | Samsung Cell Phones
I have a samsung impression and it will not connect the bluetooth. I have been trying for almost an hour and all it says is activating bluetooth. What do I do to fix this
are you at home? if you are out of country the roaming function can take over the bluetooth function. also check the bluetooth settings to ensure that the phone is not hidden and is open connectivity.
Dec 01, 2009 | Samsung SGH-A877 Impression Cell Phone
How do i get pictures off my samsung phone
Hiii
can u be specific what cell phone model ur using?
If it supports a USB connection, then samsung usually detects as a memory storage device on pc when its connected with USB cable, u can simple browse to the file and copy it to ur hard disk.
or
Download samsung pc suite from samsung website and follow the instructions while installing it.
or
if u hav a bluetooth enabled handset and have a laptop u can transfer files using bluetooth, or on desktop use a usb dongle to share files between ur phone and pc.
regards.
hope it solves ur query
Sep 07, 2009 | Samsung Cell Phones
Sansung i780 to be used as a USB modem
(I) 1)First pair the PC and your phone of course 2)After pairing, meaning the phone and the pc sees each other, go to your phone and look for the icon "internet sharing". 3)Choose bluetooth pan as you pc connection then press connect. So now your phone is on data connection via gprs, 3g or 3g+ 4) Then go to your pc now and go to My bluetooth places search for Network Access Point and enable it. It will turn green with arrows, meaning it has established a connection.TADA! Now you have internet connection using your i780s
(II) Do you have in your programs or settings a icon called Internet Sharing?
If so please connect to active sync first and then select the internet sharing icon.
Active sync will disconnect and your laptop will start using your phone as the modem.
Wuth
Jul 01, 2008 | Cell Phones
Problems on games in samsung e250
To Install Java Games On Your Samsung-E250,You Have To Download "Softick" PPP and A "Java game Uploader"(search it on Google)..........
lnstall java games using usb data cable
SAMSUNG E250
Install\Run SoftickPPP221 from the Softick.PPP.v2.21 Folder. Ignore any errors about usbsync.dll by pressing OK.
Leave the option use usb in shared mode checked.
Run when finished installing. You will get an error message about being unable to locate usbport.dll, just click cancel.
Plug in your usb cable and turn phone on.
Right click on softickppp running in your taskbar and select settings.
In the usb tab uncheck accept ppp connection on usb and tick both use usb in exclusive mode and overide usb compatability,
Click on ok and completely exit softickppp by right clicking then exit.
Run softickppp and again goto settings. On the bluetooth\serial tab tick the correct com port.Mine is com3. Then click ok
On your phone key in *#52828378# press 2 ota type setting and select serial bearer ota.
Run samsung java uploader and add your jad file
On your phone select 3 serial test , 1 ppp up , 2 usb
Your phone will now reboot. While its rebooting right cklick on softickkppp in your taskbar and choose shutdown ppp
When your phone has rebooted again key in *#52828378#
Right click softickk ppp and activate ppp
On your phones java test menu press 3 serial test , 1 ppp up , 2 usb , 2 serial download
Your game should install and start running.
Oct 15, 2007 | Samsung SGH-E900 Cellular Phone
Cell Phones Logo
32 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
