Question about Nintendo GameCube Console
The disk won't spin
I've taken it apart, cleaned the lens,taken it apart again, what can I do!
    Sergeant:
  • 209 Answers
Dear QueenSarah,
Right then, there are several things that can cause this type of problem, but ultimately, the issue here is that by the sounds of things, the DC motor that is designed to turn the disk spindle, is not operating. The cause of this can vary from a simple lid sensor (the sensor that activates the disk motor when the disk cover lid is closed) or even a failed spindle motor.
I think the best cause of action here is to log onto googles' server and search for the service/ repair manual for this product and go from there. If components are then discovered to have a fault, then you will certainly need a multimeter and tools, and of course, you will need to know how to use them.
You can get a whole bunch of information off the internet on how to use the tools andservice data. For now though, your best link is www.kpsec.freeuk.com/
I hope that this info proves to be somewhat useful, and if you have additional questions then please do contact me and i will provide additional assistance for you on this problem, but in the meantime, take care
Yours sincerely
Oz
Posted on Apr 27, 2008
My teac dv223 won't read any disks,
Try cleaning the lens. You can get lens cleaners for CD/DVD players.
Nov 17, 2012 | Audio Players & Recorders
Does not spin dvd
Sometimes the brushless motor driver circuit fails. Rarely does the motor itself go bad. On some models, if the the laser diode is too weak to read the disc, the player will not bother to spin it. It won't spin so a lens cleaner disc won't work You can try to take it apart and clean the tiny lens. Don't use alcohol. Windex and a Q-tip works great to remove grease and dirt. Don't buff it hard. Just wipe lightly a few times and look at it at an angle to make sure it is shiny, not hazy. Almost all of these are not an economically viable repair. If cleaning the lens does not help, you are looking at another portable player.
Sep 02, 2012 | kawasaki PVS-10921 Portable DVD Player
I have an Aiwa z650 3disc cd player,the disc spins a couple of times and then stops I'm told the potentiometer may need adjusting,I've taken the case of but can't find this thing
Not sure bout that ,,usally when it spins a few times and thats it,,motor wore out,,,put a disc in try as it stops spinning or right wen its fixon to start spinning given it a help spin,,i had that fix or getem goin,,,,also try tapping it ,,and hitting the side od the machine,,good luck,,
Dec 23, 2011 | Aiwa Audio Players & Recorders
Cleaning the lens from the inside
Cleaning the lens from the inside is not possible from a practical point of view. However, if you don't care that your camera won't work after you've taken it apart but you just want to see what's inside, then go ahead. If you see dust inside the lens and this is what is concerning you, please know that all lenses have dust inside...it can't be totally eliminated. In 99.999% of cases, the dust doesn't show up on the actual pictures.
Oct 17, 2011 | Casio EXILIM Card EX-S770 Digital Camera
Power works; fan spins;light is on; promo screen works; disc won't read; disk won't spin
The most likely situation you have here is that the cd drive lens isn't reading, just because with a gamecube, it relies on that lens to detect if there is a disc inserted. Your best bet is to try and clean the lens with a que tip and some rubbing alcohol. Be gentle, only very gentle wipes back and forth in a circular motion, then dry it the same way. If that doesn't work, I can give you some tips on how to rip the thing apart and see if it is a connection inside somewhere
Sep 09, 2011 | Nintendo GameCube Console
The console starts up fine everthing runs fine apart from the disk drive. I have taken apart the disk drive and put it back together, tried cleaning the lens and rails, all that happens is the disk sins up...
XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console....
click here to download repair guide
Dec 29, 2010 | Microsoft Xbox 360 Console
Disk is inserted yet message says no disk inserted
If the DVD is not reading any CD, or DVD, then it is often a lens problem.
Try first cleaning lens with a lens cleaner DVD, possibly one with cleaning solution, that can be purchased at any computer & electronics shop.
If that does not work the unit must be taken apart, to clean the lens pickup with isopropyl alcohol and soft cotton tips.
If this happens only with a single DVD , then the disk is dirty , scratched or defective, or , if it is blank the unit does not like the particular brand.
Dec 31, 2008 | RCA DRC105N DVD Player
PS2 won't read disk sometimes
I've helped someone else with a similar problem here: http://www.fixya.com/support/t1300166-playstation_2_console_keeps_freezing
It's not enough to use a disk to clean the laser lens. You have to take the PS2 apart and clean the lens manually. Nicotine, Incense, diffusers, and other smokes and just time itself clouds the lens. Not only that but the part that the disk sits and spins on needs to be cleaned over time as well to assure the disk is in proper alignment and Is not just kinda spinning on the spindle.
In that link i posted above you be led to directions on how to take apart your PS2 and what parts to clean. The instructions I have posted in that tutorial is for the (FAT) PS2 model not SLIMLINE. If you have a slimline model you don't have to take apart anything just open your cover and clean the parts in the video.
Hope that helps,
9x|
Nov 30, 2008 | Sony PlayStation 2 (PS2) Console
Toshiba sd-310vu dvd player makes noise and says disc error
The motor that spins the disk rests on rubber shocks. The rear shocks wear out over time allowing the disk to set uneven and rub eventually stopping the disk and giving a disk error. To fix simply put one small flat washer under each of the rear shocks this will level the motor and stop it from rubbing.
Jul 02, 2008 | Toshiba Televison & Video
Nintendo GameCube Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
