Question about GE Dishwashers
GE Model GLD4466r00ss dishwasher has a green clean light blinking. When I press the start button it just beeps but can't start. What should I do?
  • 188 Answers
SOURCE: blinking clean light
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Mar 03, 2009
  • 4 Answers
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Posted on Jul 01, 2008
SOURCE: "Clean light" keeps blinking; dishwasher won't start new cycle
It says in the manual to check the heating element.
Posted on Sep 10, 2008
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Posted on Jul 02, 2009
KevinWhite
  • 1902 Answers
SOURCE: the green light for "clean" is blinking green and
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Posted on Mar 07, 2011
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Green light is blinking --says clean when you push
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
The green light for "clean" is blinking green and
Kevin
Mar 07, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
My dishwasher blinks the green clean light
May have a bad heater. press hi temp, air dry,hi temp, air dry (or whatever button is equivalent on your model). this starts a test and will allow unit to work again. When drying light goes out touch the heater. If it is cold then it may be bad. You will need a voltmeter to tell for sure however.
May 27, 2010 | Whirlpool 24 in. GU2548XTP Built-in...
My GE Profile dishwasher won't start. The power
More then likely the Control Panel has faulted and will need to be replaced. You can try shutting off power for a few minutes and see if it resets.If so great if not time to replace.Not that hard of a repair for a DIY
Jan 08, 2018 | GE 24 in. Profile PDW7800 Built-in...
My Trionr XL dishwasher will not run. I push the
It sounds like your dishwasher might be locked. You unlock the dishwasher by pressing the "heated dry" button for three secs. and then releasing it, that should do it.
Jul 04, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Whirlpool quiet partner I won't run just keeps blinking
is the cean light blinking 7 times and then repaeating?? If so this is a water heating fault and means that the computer sensed that the water temp didnt rise just 3deg in the last main wash cycle. If its not blinking 7times then repeat, it sounds like the user interface (membrane switches) have failed. Let me know more and i can help.
Apr 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Check to see how it's loaded. If something is obstructing either of the spray arms it will not start. I had this same problem and checked to see if there was something impeding the arms - I found there was. Reloaded the unit and it's running like a champ now!
Feb 07, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Dishwashers Logo
304 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
