Question about Motorola Mobility RAZR V3
Dropped it - put battery back in. Works for outgoing calls but only vibrates, does NOT RING for incoming calls. Checked Settings--> Ring Styles and changed to Loud (still doesn't ring) and back to Vibe & Ring (still doesn't ring.) How to fix?
  • 370 Answers
You dont hear tones after you dropped it.
This is because the speaker connection may be disconnected due to sudden ****.
You need to contact your authorized motorola service centre to fix this problem.this is a very small problem so no need to worry.
Thank you
Posted on Aug 08, 2010
  • M vS Aug 08, 2010
    "selra" already said loudspeaker on back so I looked and sure enough the bottom part where the speaker is located was crooked. After quite a bit of tinkering it snapped back in the correct position and now the phone rings again. It sure helps to know where the problem is! Thank you both.
There is now no ring associated with incoming calls on line 3, but otherwise that line functions for both incoming and outgoing calls
http://service.us.panasonic.com/OPERMANPDF/KXTG4500B.PDF
page 80,do this first,
25611223-5sp5orn0xnhdqraxk0v0421v-4-0.png then if you want to reset both phone and base,
clear base unit settings to default,
1 Press {MENU}. 2 Scroll to "Initial setting" by pressing {<} or {>}, then press {ENTER}. 3 Scroll to "Initialize base" by pressing {<} or {>}, then press {ENTER}. 4 Scroll to "Clear settings" by pressing {<} or {>}, then press {ENTER}. L The "Clear settings?" screen is displayed. 5 Press {CLEAR}. L Confirmation tone is heard.
clear handset to default,
Press {MENU}. 2 Scroll to "Initial setting" by pressing {V} or {^}, then press . 3 Scroll to "Initialize HS" by pressing {V} or {^}, then press . 4 Scroll to "Clear settings" by pressing {V} or {^}, then press . L The "Clear settings?" screen is displayed. 5 Press . L Confirmation tone is heard.
Mar 27, 2015 | Panasonic KX-TG4500 Phone
My iPhone incoming calls ring but do not vibrate, but all other notifications vibrate correctly.
Strange. I would try resetting your iPhone. Hold down the home and power buttons until it powers off. It should start up automatically but if not just press the power button. This has worked for me in the past when my iPhone has acted strangely.
Don't worry about a reset or hard reboot. You won't lose any data or settings.
Aug 06, 2012 | Apple iPhone 3GS Black (16 GB)
Lg neon will not ring or vibrate
If you have made sure it's set to ring and/or vibrate and it's still not working, then turn off your phone and take out the battery. Put the battery back in and turn it on, then see if it works. This will probably fix the issue. If you haven't made sure it's set to ring/vibrate, you can do so by going to "Menu" > "Settings" > "Audio & Ringtones" > "Ringtone" > "Volume" and make sure the volume is up and not on silent. You can also quickly adjust this by the up and down arrow buttons on the side of your phone without having to go to the menu. I hope this helps :)
Apr 29, 2011 | LG Neon GT365 Cell Phone
VIBRATE STAYS ON
Follow the below instructions and you can remove the vibrate state. I have included a link to download the phone's manual as a PDF file.
Sound Settings
Ringer Types
Ringer types help you identify incoming calls and messages.
You can assign ringer types to individual Contacts entries,
types of calls, and types of messages.
Downloaded Ringers can be downloaded right to your
phone.
Preprogrammed Ringers include a variety of standard
ringer types and familiar music.
Vibrating Ringer alerts you to calls or messages without
disturbing others.
Selecting Ringer Types for Voice Calls
Your phone provides a variety of ringer options that allow you
to customize your ring and volume settings. These options
allow you to identify incoming calls by the ring.
To select a ringer type for voice calls:
1. Select Menu > Settings > Sounds > Ringer Type >
Voice Calls.
2. Select With Caller ID or No Caller ID.
http://downloadcenter.samsung.com/content/UM/200708/20070824101259031_sprint_m300_ug.pdf
Mar 19, 2011 | Samsung SPH-M300 Cellular Phone
Cannot get phone to ring only vibrate
To change the Nokia 6133 to ring, do the following-
Select Menu > Settings > Profiles > Select any one profile that is available in your mobile. (Ex. General)
1. Menu > Settings > Profiles > General > Personalise > Incoming call Alert > Ringing
2. Menu > Settings > Profiles > General > Personalise > Vibratibng Alert > Off
After this activate the profile(Ex. General)
Menu > Settings > Profiles > General > Activate
After this the phone will only ring and wont vibrate.
If you want both then change the vibrating alert to On.
Good Luck.
Jun 04, 2010 | Nokia 6133 Cellular Phone
Cellphone does not ring, or message tone
well you say that the music player is working..so there isnt any problem with the speakers..I suggest you better check de settings -> tones -> incoming call ! or settings -> tones-> incoming msg..check as they maybe switched off..that is de only possiblilty that i think maybe the problem..
May 25, 2009 | Sony Ericsson W890i Cellular Phone
My Motorola Razr won't ring or vibrate when receiving an incoming call except when plugged in to the charger
Turn off the ringer id function in settings, ring styles, load detail, ringer id's off.
Hope this helps
Jan 11, 2009 | Motorola Mobility RAZR V3
Will not ring
I dont receive phone calls and not ring
Jul 18, 2008 | Pantech C300 Cellular Phone
Razr v3
Can you not go to sounds and set a ring tone from there?
I Used to have a Pebl U6,and thats how i set my ringtones.
Hope I Helped.
Sophie x
Feb 13, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
140 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
