Dial up connections
Do the new desktop computers still come with internal modems?
    Genius:
  • 3,587 Answers
Not unless you ask for them. they are considered an ancient approach, and most folks actually don't use them even for faxing.
Posted on Apr 27, 2008
HP a6230n- Just moved to a rural area- need a internal Dial-UP Modem. Any suggestions
if not a modem in ur system then how to u use a dial-up connection|||
Apr 13, 2010 | HP PAVILION A6230N DESKTOP PC
I have an old compaq EVO desktop and Where I live I can only get dial up service and there is no enternal modem. I dö not know how to open the computer to put one in....I want to know how to install a...
well....u cant install an internal dial up modem in the laptop
wat u can do is, there are external dial up modems avlbl, atleast they used to be, not pretty sure that will u find them now, but thats ur solution
SEARCH AND GET AND EXTERNAL DIAL UP MODEM...
Nov 04, 2009 | Compaq Evo Notebook N610c
Trying to connect to internet but screen says internal modem has no driver - it sees no modem
If you're compuer is connected to a router or DSL/Cable modem through Ethernet connection, you don't need to have to use internal modem. Internal modem are just for dial up connection.
If everytime you launch IE browser and it gives you that prompt, your browser may have set up to connect everytime to a dial up connection. Try to check these settings on your IE:
1. Go to Start> Settings> Control Panel> Internet Options
2. On Internet Options, go to Connections tab.
3. Delete everything under Dial Up and Virtual Private Network Settings, Or just set it to 'Never Dial A Connection'.
4. Click on LAN Settings button.
5. On the next window, uncheck everything (particularly the proxy setting).
6. Click OK all the way out.
Oct 23, 2009 | HP Pavilion a1610n PC Desktop
My new pc Dell Inspiron desktop has no modem built in for dial-up internet connection. Im currently subscribing to a dial-up service provider on another pc, how do I connect to the same dial-up service...
You have to configure Internet Connections Sharing on the PC which has a dial-up service.
1. Click Start - Settings - Control Panel - Network Connections, right click on dial-up.
2. Clik on Properties, click on Advanced tab.
3. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box
After that you must connect the other pc to this one via network cable.
If you don'y have network adapters you have to buy them.
Sep 30, 2009 | Dell Inspiron 530s Desktop Computer...
Hp problem
Try to make a new connection shortcut and make sure your telephone line is properly connected on your modem. Also make sure that your password and username is correct. another thing is check that your system date is correct.. Hope this works ! ITTech7574
Aug 28, 2009 | HP Pavilion a6863w-b PC Bundle with 23"...
Was able to get connected to the internet twice to day when i came back in to get on the computer it couldnt connect to the internet said no dial tone. this is a new dell computer with an external modem...
Generally this is an indication of a modem failure. If there have been any storms in your area, then the modem may have been zapped. The dial tone curcuit is normally the first casualty when a modem gets hit with more power than normal.
Provided that your telephone is functional on that line (Unplug modem, and connect a handset if this is a modem only line and see if the handset gets a dial tone, this is a good check to make sure the line is functional)
Apr 17, 2009 | Dell Inspiron 530 Desktop Computer
Dial up Modem
Dial up modems have 2 phone line connections side by side in the back of a desktop, one is for the wall, other is for your telephone. Laptops have just one phone line connector. Look closely at the little symbols by the connection holes. If you don't have one, Modems (internal or externally mounted), are on eBay, buy a 56K with drivers on disk for your operating system. A few modems can be installed using Windows default drivers (drivers are software operating programs that tell your computer how to regulate and operate a device).
Sep 03, 2008 | Fujitsu Siemens AMILO Pro V1000 Notebook
My modem
Returning the computer to Gateway is the most reliable option, but unless you have the premium grade warranty this will be expensive.
You can buy a replacement from Best buy, but if it is for a laptop I would recommend either an external modem or a PCMCIA modem. Opening up a laptop is a job for an expert. If you have a desktop/tower PC then you can buy an external or an internal Modem, Only but the Internal modem if you feel confident about opening up the PC. The external modem is the safest to buy. You will need to check what connections you have on the back of your PC either a serial connector or nowadays a USB connection. Make sure the modem you buy is appropriate to the service you use e.g. dial up or DSL. The assistant in Best Buy should be able to help you with that.
This should fix it .
Carrie
Jul 21, 2008 | Computers & Internet
Connecting to Internet using a dial-up modem
can you connect that modem first, to a phone line, and run a telnet or dial connection from control panel or accessory ?
Mar 20, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
