Question about Bosch HS2125 Tamper Plate 8" x 8"
I just bought a Bosch 35 lb jackhammer and want to know if it will work with the tamper plate or do I need the larger hammer?
  • 251 Answers
Hi , you can use a tamper plate with it for small jobs , but to be honest i would go for a GSH27 ( easier on the back ) .
Posted on Aug 08, 2010
Why my Bosch brute jackhammer only hums when I press trigger? Can someone help me please?
seems as if the jackhammer motor is locked up and frozen might wanna be careful opening it up and freeing that motor up while its unplugged
Apr 17, 2017 | Bosch Hammering
I bought a new jack hammer. After using it for a few hours grease started to come out where the bit is. Is this normal
No thats not normal real JACK HAMMERS on AIR ??? but its not Milwaukee not Bosch not Dewalt but a China brand? if you are have a real jack hammer then its not the right collum because its placed under Hammer drills? and you have also not possible speaking about maybe a little weight rotary hammer ? because ONLY real demolition and jackhammers are very specially made for the long lasting jobs !!! but the weight and power is very important by use the right tool for the right job the most rotary hammers ( exept brands like Hilti and Duss) are not made for long lasting jobs and are made for only working for a short time. its also makes the great price difference between a hammerdrill a rotary hammer a real demolition or a real jackhammer is much higher price. The tools on air Atlas Copco or Ingersoll for the hard and heavy jobs
If you have bought your tool by a hardware store and it is a real jack hammer go immediately back its possible that you are wrong informed by the seller or the budget was the fact. about the price for the tool maybe you have a real jackhammer but have choose a to little model size machine to do the job or its a budget brand online bought China machine. Its a simple question but a hard answer, difficult questions do not exist but difficult answers sometimes.
Regard and luck by warranty and a very small change maybe it is just only a factory flaw.
Apr 09, 2016 | Drills
How do i chack bosch 60 lb jackhammer oil leval
Bosch hammer uses grease available in repair kit. Check ebay or parts house. Remove four hex bolts on the mid section of the hammer and pull off the lower end. Most of the grease goes here. There is a side cover to expose the drive gears if you hear gear noise. Depending on use, only needs grease once a year. Good luck.
Jun 30, 2014 | Makita HM1500B 42 Lb. Demolition Hammer
Jackhammer is not hammering
Its need service if its anchor / drive gear is worn or the o-rings seals are worn, if its this model hammer make a trade-in service that in case its an old hammer like this model its not the model to service by your one the best option is trade-in by your dealer. if its handle this model
http://dasen-hammer.en.made-in-china.com/product/BMgJKvoEXFpm/China-High-Quality-11e-1500W-Electrical-Demolition-Hammer.html
Mar 27, 2014 | Hammering
Bosch jackhammer
broken power cable or autostop inside the carbon brush they are short its time for a revision !!
Nov 28, 2013 | Hammering
How to fix jackhammer it doesnt hammer.
Bosch hammer drill 11304 uses sds bits and is generally a good hammer. Usually only needs yearly (depending on use) lube with Bosch grease to keep it working well. No hammering usually means lack of lubrication or broken connecting rod on the hammer piston. Not easy to repair. Tackle only if you have lots of experience with Bosch or other complicated hammers. Parts are easy to find. Good luck.
Mar 02, 2012 | Hammering
Hammer runs but bit does not move much
how much oil do i put in my bosch jackhammer?
Jan 30, 2011 | Electric Demolition Jackhammer
Have a problem with bosch brute jackhammer, quit working while using it, replaced switch, still nothing, anyone that can help?
did you check the cord first? after that I would check the brushes and make sure the switch wired correctly. Let me know if you need more assistance.
Dec 15, 2009 | Bosch Hammering
Breaker Hammers Features
power, raw strength, comfort and vibration
Aug 27, 2008 | Bosch 11335K Factory-Reconditioned 35 lb....
Bosch HS2125 Tamper Plate 8" x 8" Logo
157 people viewed this question
Top Bosch Hammering Experts
John Trevino
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
