Question about Gigabyte GA-8S648FX Motherboard
Hiii... my PC is a 2.4 HD.. GA-8S648FX... seems lyk evryting in Mobo detects even the fan ROM, Harddrive but there is no display and no beep noise.... any solution regarding this matter?????
    President:
  • 2,030 Answers
You should only get a beep if there is an error
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Aug 08, 2010
1 LONG BEEP, 2 SHORT BEEP
1 long, 2 short Failure in video system: a checksum error was encountered in video BIOS ROM, or a horizontal retrace failure has been encountered
Apr 29, 2014 | Gigabyte Motherboard GA-H55M-UD2H Core...
CPU fan & PSU fan working but No display coming to the screen
There should be some sort of beeps then. No beeps is an indication the CPU or RAM is not seated properly. You need to refer to board manual if there are beeps.
There is also the matter of... Never mind I just noticed the CPU is an 8 core CPU, but the board supports quad core.
Board specs
http://www.gigabyte.com/products/product-page.aspx?pid=3833#sp
CPU Specs
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103960
Double check my findings and go from there. Good Luck
Dec 11, 2012 | Gigabyte Technology gigabyte Ga-78lmt-USB3...
Intermittant no beep post power on
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 10, 2011 | Gigabyte GA-8S648FX Motherboard
I have gigabyte GA-G41M-ES2SL rev 1.1 motherboard with 2 GB RAM, 350 GB SATA HD, and SATA DVD-ROM. My PC die yesterday. i check it. there is no electricity to my pc, i think my Power supply (380W) was...
hey yo, i think your problem is quite similar to my problem. Because after I've installed it properly and after 5 hours working the screen suddenly become blank and not detect the connection. I think the mobo already broke down.. T_T
Dec 20, 2010 | Gigabyte GA-G41M-ES2L Motherboard
After 3.5 weeks of operation, I looked at the screen after being away from the computer, and it was blank. I smelled burning resistor/electronics. Rebooting results in Windows XP displaying the logo and...
I would check your power supply with a meter to see if that's the problem. If it checks out ok then it's probably the mobo. In rare instances when a power supply goes it takes the mobo with it.
Best of luck...Hank
Feb 02, 2010 | Gigabyte GA-G41M-ES2L Motherboard
Soyo SY-P4I865PE Plus Dragon 2 Power up, but no beeps/video
Your MotherBoard is undoubtably faulty replace it.
Jan 31, 2010 | Computers & Internet
Fan running, HDD light solid, no display
I assume there are no post codes (beeps)?
Pull everything including the video card, leave only the RAM and CPU installed.
Try powering it on, You should hear a long beep, then some short ones to tell you the video card wasn't detected.
If you still don't get any post beeps, try resetting the BIOS, and re-seat your RAM.
If it still doesn't post it could be a system board mounting issue, bad system board, bad RAM, bad CPU, or bad Power Supply
Jun 24, 2009 | E-Machines T2240 PC Desktop
GA-MA790FX-DQ6 Mobo not POSTing Should i reset the bios??
no beeps, indicates you have faulty CPU or mainboard.
  • remove all components even RAM and CPU.
  • insert only CPU and Speaker (without RAM or any other componet).
  • Boot and try to hear, there must be long beep for missing RAM, if not then try to re-insert the CPU or change the CPU/Mainboard.
Thanks and Good Luck
Iqbal
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Mer cury PVM7 mobo wont display on monitor
So I think you are saying it did work and then stopped, right?
If that's the case then I would try booting into the BIOS setup and reseting it first. If that does not work then I would reboot into the BIOS again and see if there is something there you need to enable for the AGP port to function.
If all this fails then you most likely have a bad motherboard. It's probably not worth the money to consider having it repaired, and I doubt you'd find anyone who's even interested trying.
Good luck.
Dec 28, 2007 | Mercury P4VM800M7 Motherboard
Gigabyte GA-8S648FX Motherboard Logo
101 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
