I'm unable to get other devices to connect to my wireless network because I forgot my security password for my router. I'm trying to add my daughter's new laptop computer to the network, as well as my sons new wirelesss devise for his X-box 360. Thank you. GWS
    Genius:
  • 3,587 Answers
Hmmm..well...forgetting the password....checks his notes..ahhh..here it is..
you'll need to create another node, name it something different, point it at your wireless hub, and then leave the WEP off of it..
other than that, you'll need some code from your wireless router guys to reset it...
Hope you find a solution
and thankya for using fixya
Posted on Apr 27, 2008
WIRELESS GATEWAY
How to View or Change Your Wireless Network Password
Symptoms:
You have lost or forgotten the password to your wireless network
You have lost or forgotten the password for the router, access point or other network device
You left the default password or used a weak password and someone has hijacked your network
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
Launch your Internet browser and type http://www.routerlogin.net in or http://192.168.1.1 or http://192.168.0.1 the address field for your browser. Enter the router's username and password.
The default username is admin, the default password is password.
From the left-hand navigation menu of the Router administration interface, select Set Up > Wireless Settings
Note: On some routers this option will be under BASIC > Wireless.
From the center screen, you find the current wireless security settings under the Security Options heading.
If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Read more about Securing your Wireless Network.
If you cannot log into your router:
- If you were routed to the NETGEAR website or getting the "Page cannot be displayed" message when trying to login to router, make sure you are connected to the NETGEAR router. Check your wired connection and make sure cable is securely plugged in and LED is on. If wireless adapter is on, make sure you are NOT connected on a different wireless network.
- Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default access information to reconfigure your router settings. NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
See the following articles for more information:
Secure Your Wireless Network: WPA/WPA2 (Recommended)
Reset and Restore a NETGEAR device to Factory Default Settings
Default Password for NETGEAR devices
Jul 19, 2012 | Gateway Computers & Internet
I forgot my user mname and password for my wifi connection
You can secure your wireless network wit WEP or WAP code.
For know your security key Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
The old password is in * or # format so you need to enter new password.
Let me know if you need furhter assistance.
Thanks for using FixYa
Mar 26, 2010 | WiFlyer - Portable, shareable WiFi base...
I have a belkin router set up in my home and I just purchased a 2nd laptop but I am unsure how to add this new laptp to the connector
If you router is already set up and you want to add a new computer, you don't need to run the set up CD for the router again.
If you want to add a new wireless device ( laptop or any other wireless device) to the network, then you should know all the wireless settings of the router. What wireless settings do you need to know ?
You should know the wireless network name ( SSID ), wireless channel and the wireless security password
( network key ). Once you get all the wireless settings of the router , you will need to connect to the wireless network on the computer. when you try to connect to the network , you will see your wireless network in the list. You just need to select your network and connect to it. If it is secured then you will need to enter the network key and you will be able to go online.
To check the wireless settings of the router , you will need to access the router set up page. On the set up page you will find all the wireless settings of the router.
Click Here for step by step instructions
Dec 27, 2009 | Belkin (F5D7231-4) Wireless Router
I misplaced my cd to connect my other laptop to the wireless router, WRT54G, and I'm trying to get it through your site
If your router is already set up and you want to add a new computer, you don't need to run the set up CD for the router again.
Click Here for more info
Dec 19, 2009 | Linksys Wireless-N WRT150N Router
Reset router and add a new netkey . I have a Router G MIMO Plus. Model F5D9230-4. I move my office and I lost manuals and CD installation. We also change computer so we forgot the netkey. How can we reset...
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
Thanks for using FixYa.
Dec 10, 2009 | Belkin (F5D9230-4) Wireless Router...
Forgot my security password (network key)I need to
Logon to your router from your computer using your browser and going to http://192.168.1.2/. If it wants a username, the default username is blank and the default password is either blank or "password".
The Belkin management tool will come up. From there, go into your security and look to see if your passphrase is visible. If it is, you're good to go. If not, you can change it on that page save it and close out.
Don't forget to change the passphrase on any wireless devices you are using connected to the Belkin wireless router.
Nov 16, 2009 | Belkin (F5D7230-4) Router (587009)
I need to add a password to my wireless network
Do you want to secure the wireless network ?
For that you will need to access the router set up.
You said that you want to add a password. I don't understand that. Is your wireless network already secured ? Or you want to make it secured ?
If it is already secured then it must have the password to connect to the wireless network. You can use only 1 password for the network. You can not use 2 password for the wireless network.
If your network is not secured yet then you will need to make it secured and enable password protection on it.
Click Here to know more about how to make it secured
Nov 12, 2009 | Computers & Internet
Lost my user name and need to add new computer
Are you trying to connect to the wireless network ?
Or your new computer will be connected to router with the cable.
If it is hard wired to the router and the router is working for the other computers then you don't need to change anything on the router.
If you are trying to connect to the wireless network then you should know the wireless settings of the router.
Click Here for step by step solutions
Nov 06, 2009 | D-Link DIR-300 Wireless Router
Symbol MC9090 unable to connect to wireless network...
check in your router MAC security
if in your router MAC security is enabled then only those can connect whose MAC addresses are in allow list in router.
you can access your router with following link
http://192.168.1.1
or
http://192.168.1.0
for belkin router
http://192.168.2.1
type user name as "admin" and password as "admin" or blank or "password
then go to wireless advanced security then check MAC security if enabled then add your moto MAC in allow list.
Let me know .
Jul 29, 2009 | Symbol Motorola MC9090 Mobile Computer
Can't connect my Ipod touch to my router?
You must be sure to what router you are trying to connect. I understand you have a ZyXel and a linksys. You must have 2 wireless networks. Your wireless network must be secured, so you just have to use the correct password. I need more details. Try this http://technicalsupport.blog.friendster.com
Feb 08, 2009 | Linksys Wireless-G WRT54G Router
Open Questions:
How do I fix my Toshiba laptop? Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 25, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
David Payne
David Payne
