Question about Toshiba 50HP66 50 in. Plasma Television
Red dots show up on the black portion of the screen. Any ideas? Thanks, Steve
  • 4 Answers
I had the same red dots in the dark areas and it was driving me nuts. I also have a toshiba 50hp66. Luckily I found out that it's an easy fix. Open up the back of your tv and on the left side you will see two adjustment pots labelled Vsc and Vy. I first marked with a sharpie where the factory defaults were. Then I adjusted down (to the left) the Vy a little and the red spots were gone! My TV looks like new. Hope this helps.
Posted on Aug 26, 2010
3 year old Panasonic VIERA TC-P54VT25 screen has a series of horizontal red dots from left edge to middle of screen in lower half of screen. Visible when the picture is dark. Not so visible when the
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 23, 2014 | Panasonic Televison & Video
I HAVE RED DOTS ALL OVER ANY BLACK COLOR OF THE PICTURE
Could be whats known as dead pixels, this is tested be showing up a black or white screen. Microsoft paint or word will do. If an area always has dots then dead pixel. However if it doesn't constantly remain a dot then, some-thing else. Dead pixels come about due to age.
A technician will be able to diagnose your problem by performing white screen test.
damnor01
Nov 17, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Tv black with red green yellow dots but when warms up it alright
Try backstepping the set resolution on your TV to see if that cures it.
Please rate my help++++Thanks for using FIXYA
Mar 06, 2010 | Gateway GTW-P42M303 42 in. Plasma...
Red static in black background ~ thin line running down center
Robjrpena,
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
Jun 17, 2009 | Hitachi 50HDA39 50 in. Plasma HDTV
MY HD TV has a pixel out
The only way to get rid of the red dot is to replace the screen portion of the TV. I hope it's under warranty because it won't be cheap.
Mar 17, 2009 | Televison & Video
Dell W3000 display issue - band of red dots on the left side
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 11, 2017 | Dell W3000 30 in. HD-Ready LCD Television
Screen black after big storm...
The set has sound and no picture.If you the SSB could be the issue but the tiny red dots on a black screen will need the panle replaced also. There is a way troble shooting can be done to determine if you will need the SSB or the SSB and the panel.
May 19, 2008 | Philips 42PF9630A 42 in. Plasma Television
Mitsubishi CS-40707 Greenish/Yellowish Display
Yeah, I had mine checked for the same thing. The "blue" - There's only three - red yellow blue- portion of your tube died. Not repairable. Last I checked it costs at least $1,000 for a new 40 inch tube. Good luck. Mine went to the garbage dump!
Feb 25, 2008 | Mitsubishi CS-40707 40" TV
Red dots on left of page
You need to measure the distance between two dots (In milimeters if possible). After that I may be able to determine what is causing the problem.
Jan 24, 2008 | HP LaserJet 2820 Printer
TV turns off with balck screen and small color dot in center
Best Educated guess would be your Flyback transformer is failing. Not something you can replace at home and the value of the part may exceed the replacement value of the set by the time labour and part are factored together. DO Not look to replace this part yourself as this part inside the set as it has a high voltage that can be lethal. Output voltage can be around 50,000
Oct 29, 2007 | Televison & Video
Toshiba 50HP66 50 in. Plasma Television Logo
602 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
