Question about Proform 760 CrossTrainer Treadmill
Red key is inserted, mains are switched on. Lit up ok. All started working fine then went indoors, came back out 5 mins later and the whole thing was dead. Turned everything off and left it for 30 mins. Turned all on but still totally dead. Anything else I,m supposed to do ? Was hoping to use this to help with after knee surgery. Thanks in advance. Christine.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
Check the breaker by the power cord to see if it was tripped. if it isn't there could possibly be a problem with your motor controller.
Posted on Aug 11, 2010
Battery is brand new i just had it out for a 10 minute ride and turned it off for 5-10 mins and i went to start it back up , all the lights were on but it would not do any thing wheni tried to start it i...
Hi,rather than jumping the gun as the bike was running fine before you had new battery fitted,I would say to have the starter checked first.good day to you.
Mar 29, 2015 | 2001 Suzuki VZ 800 Marauder
94 Volvo 850, crank & no start, no codes & injectors not firing
check the main lume harness plug for corrosion or been hot
Mar 20, 2010 | 1994 Volvo 850
Have a 2002 ion that sometimes wont start but if left for 10 mins will start up.
I have 2003 Saturn Ion. I had this problem over and over 2006 - 2008. IT IS THE IGNITION SWITCH. IT IS DEFECTIVE IN ALL ION'S.The replacement may be defective also, not sure. Mine was driving fine, went ino store for 1 hr came out stone cold dead, would not start and key **** in. Had to have towed to Saturn. They said it was battery and replaced battery.I said this did not make sense. 6 yr battery only 3 yr old , never weak start, never run down, in summer? It happened again 2 mo later. They tried to say battery , I said no. They checked battery. It was fine. Could not find problem. They did total electrical check. It happened again 1 mo later. drove into feed store. Went in came out it happened again. I got jump from someone 30 min later and started right up. 2 wks later same, I got jump 20 min later started. 1 mo late same. Sometimes it would just start up. Took to another Saturn place. They said Ignition switch, saturn was having big problem with this on Ions. Got changed and no problems for 1 yr. I was talking to repesentative at Saturn Headquarters. I told the problem. They said the ignition switch has an electrical component, or it is hooked to electrical component. THEY SAID IF I HAD JUST SAT THERE 20 MIN WITH KEY OFF, THE COMPUTER CHIP FOR IT WOULD HAVE RESET ITSELF WHEN IT COOLED DOWN AND I COULD HAVE STARTED IT EACH TIME. IT WAS BEST TO GET REPLACED AND NOT WORRY, BUT THIS WILL HELP YOU IN A STRESSFUL PINCH, UNTIL YOU CAN GET THE IGNITION SWITCH REPLACED. NOTE: Go to Auto Zone , O 'Reilleys, Pep Boys etc, get a repair manuel , CHILTON $ 23- $ 25 , for your year , make, model car. CHILTON IS MUCH BETTER THAN HAYES MANUEL. It is wonderful and many things you can do yourself.
Feb 09, 2010 | 2003 Saturn ION
My car was a bit sluggish to start then 1 day wouldn't start nothing there at all tried it tem min later and it started and has been fine til the other day went sluggish to start drove to a few places then...
check/clean battery terminals, if ok check starter wires for voltage(while turning key to start) and tightening or corrosion. If all check out ok replace the starter. If you have no voltage at the starter check your relays and ignition switch. Hopefully this helps
Aug 19, 2009 | 1998 Nissan Maxima
I have an 03 merc. sable. 58000 miles. drove 22 miles home from work parked and shut it off. went to leave 5 min later put in drive and it started to spit and shudder and then just died. 20 - 30 min later...
Start at Changing your sparkplugs wires (if you are performing this on your own replace one by one to prevent mix-up). If problem still persists, have coil pack checked or replaced. Hopefully this helps!!
Aug 12, 2009 | 2003 Mercury Sable
Car slipped out of DRIVE position only revving the RPM's.
Tranny low on fluid. When you stop or turn it all goes to one side causing the problems.
Jul 28, 2009 | 2003 Chrysler 300M
Started my car after work drove less than a mile turn it off then about 15 min later went back and tried to start it and it will turn over but not fire. can anyone help with this
hey, remove the fuel pump fuse. Turn the car over and keep cranking it over, till it sounds like it wants to start. remove and insert the fuse a couple time till you see the car wanting to start. it is a problem with the injectors on these years. my 99 b5 does the same thing. turn key over for approx ten seconds at a time. DO NOT PRESS THE GAS PEDAL. the whole point of removing the fuel pump fuse, is to not allow new fuel in , but the burn out the fuel that is there lean. When it does feel like is going to start, put the fuse back in. If it feels like going to stall, take it out. You may have to do this a couple times, but it will work !!
Mar 16, 2009 | 1996 Audi A4
WON'T START
my 2006 pt cruiser won"t start. the light do come on but it will not turn over just a clicking sound. i drove it for about an hour then went back to it 30 mins later and it didn"t start. just clicking sound.
Sep 21, 2008 | 2006 Chrysler PT Cruiser
BLACK SCREEN, AUDIO OK
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Aug 27, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Proform 760 CrossTrainer Treadmill Logo
237 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
