Question about Garden
I have an 80 anniversary craftsman push mower that starts and once it warms up it dies then if you let it set for 2 to 3 minutes then you can start it up again and mow for maybe 5 minutes and it shuts off again
  • 100 Answers
Possibly has faulty coil assy
Posted on Aug 14, 2010
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
What would cause mower to die after starting?
your carb. is gunked up. get a can of starter fluid and a helper. have the helper spray some starter fluid into the air intake to keep it running after it starts. Once it runs for a couple of minutes it will be ok. J.
Jun 27, 2010 | Craftsman 675 Torque 190cc 21" Briggs ...
Engine starts right up after pushing primer bulb,
There is dirt in the nozzel inside the carb,take it apart and clean it with torch tip cleaners. Remember to replace all the gaskets you disturb.
Nov 01, 2009 | Toro Lawn Mower With Toro Power Tools
Husqvarna 2009 Tractor Run 30 minutes, sputter, loses power, dies
hi it seems to me either a lack of compression when she is warm /hot /check tappets or a weak mixture /air leak on the inlet someware hope this is of some help merlinv12
Aug 20, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Craftsman 24Hp Lawn tractor engine dying out
1. check the oil level... don't want the auto shut off to be the problem due to low oil level
2. pull the carb bowl and check for residue. Spray out the needle valve in the carb, spray out the bowl and any jet openings you can find...spray them out too.
3.When you winterized, did you put fuel stabilizer in the tank? If not, drain the tank and refill with fresh...
4. check the air filter element and make sure it is clean...
let me know how it goes...
k
May 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
MOWER RUNS FIVE MINUTES THEN STOP AFTER IT WARMS UP
Check your automatic choke ... a cold mower needs more choke, and the auto-choke should release when the motor warms and runs smoothly. If the choke is sticking, the motor will die when it gets warmed up, then start again after it cools down.
Apr 12, 2009 | Mtd 22" Yard Machine Push Mower
Craftsman zts 7500 will not run with levers engaged
Cody,
Yes, I am sitting when I do engage the blades on my craftsman zts 7500. All you do is pull/push the engaged button to your left well you are seated.
Apr 05, 2009 | Craftsman Garden
Push mower runs then quits!!
My toro mower starts and will run for ablut 15 minutes and starts to cut out and eventually stop running. What could be the problem
Apr 01, 2009 | Craftsman Garden
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
