Furnace blower motor is fine, but the air conditioner unit will not start. when it gets a signal to come on there is a click as if a breaker is shutting it off.
    President:
  • 949 Answers
The click you are hearing may be the relay or contactor. If you hear the noise at the outside unit and nothing starts out there the problem could be with the fuse or breaker that supplies the high voltage to the condenser, as this is on a separate breaker than the furnace.
Check the large breakers in the main breaker box. If they are okay look for a box on the outside wall of your home near the condenser unit. It may contain a fuse or breaker in there. If those are okay then there could be a problem with the capacitor or contactor. You would have to check the voltage coming into the contactor and out. You should have 240 volts on both ends with the contactor activated.
Let me know if you have questions
Posted on Aug 08, 2010
  • 8 more comments
  • juerigmusa Aug 08, 2010
    The Breakers both look good and are on. There is no fuse that I could see. Is the contactor on the side of the compressor a box about 2" square
  • Philip Aug 08, 2010
    The contactor is about 2" - 3" square and has 2 large wires coming in the bottom, usually about 4 going out the top and 2 very small ones on the sides.
    Here is a picture of one on it's side. The small wires may be on one side (brown and yellow shown here) or may be one on each side.
    One more thing, even if the breakers for the A/C look good, try turning them all the way off then back on it may be partially tripped.
    I turned Breakers off and on and get a humming sound from the unit
    If it is humming and nothing is running outside the problem is either
    - no high voltage to the condenser, (not likely since you check the breakers and no fuses were found),
    - a bad contactor (not likely since you are hearing the hum)
    - bad capacitor
    You would need a meter that reads up to 250 volts and can check ohms to go from here. Do you have access to a meter? If so I can walk you through what to check
    Now the unit is humming louder and heating up , but not running
    Ok, Turn it off
    Since I cannot hear over this website the hum you hear must have been the compressor running rather than the contactor. It would run and overheat then trip the breaker (either internal or external) this would explain why it started when you flipped them.
    The problem with the unit is the condenser fan motor. The compressor is running but the fan on top that cools the coils and compressor has failed. The motor can be replaced, it typically will run about $150 - $200 for the motor depending on the size and speeds. The cost for labor to have a professional put it in would be about $150.00 also.
    If you feel comfortable you can take this on yourself. It does take some work to get it apart and a bit of electrical knowledge to wire it up correctly.
    Thanks, I think your correct about the condensor fan motor because I hear the compressor kick in but fan motor will not run
    Yes, it explains all your symptoms. Is there anything else I can answer for you?
AC unit does not kick in, NO hum from motor, blower on furnace comes on, Capacitor looks good, any other ideas? Could I have a bad motor?
There is a relay in the outside unit that is controlled by the furnace. You need to check that voltage is coming to it from the furnace. If it is then you need to change the relay. High voltage is present in the unit. Turn of the breaker before doing this
Jun 08, 2015 | Heating & Cooling
No display
It could be a breaker has tripped or the batteries died in your thermostat if it does not have a common wire connected. Is the unit not working at all? What type of unit do you have? (i.e. gas furnace, heat pump ect.)
Most units have a breaker inside the panel near the blower motor that you may overlook seeing as how it is not in the main panelbox with all of the rest of your breakers. I would start there and follow the 24volt wires back to the thermostat. The problem is somewhere in between the blower motor and the thermostat. Good luck!
Feb 01, 2013 | Heating & Cooling
Auto fan does not start electric furnace
see this causes and fix it. God bless you
If the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel.
If there is not enough heat, raise the thermostat setting five degrees to see if it turns the unit on. If the unit still does not generate enough heat, check the comfort controls . Clean or replace a dirty filter, clean the blower assembly (see the Forced-Air Distribution Fix-It Guide), and make sure that all registers are open and not blocked.
If the furnace turns on and off repeatedly (cycles), clean or replace the filter; and clean the blower assembly (see Forced-Air Distribution Fix-It Guide).
If the furnace is noisy, make sure access panels are mounted and fastened securely; spray squeaking belts with fan-belt dressing and replace worn or damaged belts; adjust the blower belt; lubricate motor and blower oil ports.
If the element does not heat, refer to the Heating Element Fix-It Guide for guidance.
Oct 08, 2012 | Coleman Mobile Modular Home Electric...
THERMOSTAT HAS NO POWER
Hi, yes the thermostat feed does come off the furnace from the transformer. That's where it gets it 24 volt supply, 120 volts is stepped down to 24 volts for the controls. If it trips the main breaker, it may be a matter of the wires that feed the breaker are loose and this will cause the breaker to over heat and trip. Shut it off and tighten the wires.The breaker may also be weak. This is a high voltage problem. So, anything that runs off of this breaker can cause it to trip, like the blower motor may be drawing to much amperage. Make sure there is no lint build up on the motor or in the windings or on the blower wheel also. My guess would be the breaker is burned or wires are loose creating enough heat to trip it at times. This is where you will need to start. Keep me posted. If you have a amprobe you can check the rated amps on the data plate of all motors and see what they are drawing under a load. If not, you will have to see whats getting hot, breaker, motors ect. Keep me updated as you will be able to find the problem. Like I said, my bet would be the breaker is going. You can also kill power and pull the breaker to look for any hot or burned spots on it. Concentrate there first.
Best of luck, you should find it quickly.
Shastalaker7
May 24, 2010 | Heating & Cooling
The furnace part of my central air is wired to a seperate breaker but keeps tripping the breaker and making a spark in the breaker box.
Usually a Central Unit is wired seperate, the Air handler inside and the
Cooling unit outside. It appears that the breaker is bad, is it a Single Pole Breaker?
Another possibility is that the indoor blower motor might be bad.
Jan 10, 2010 | Heating & Cooling
No A/C.
It maybe the blower motor. Determine if the blower motor is getting ac, if not getting ac to the blower motor then there might be a breaker, which would probably be located somewere near the motor, or the motor has an internal breaker or fuse.
Aug 13, 2009 | Heating & Cooling
36e93 bryant furnace inop
CHECK THE PRIMARY CONTROL TO SEE IF IT IS LOCKED OUT. IF THE RED BUTTON HAS POPPED UP THEN PRESS IT ONCE TO START, IF IT DOESN'T RUN THEN CALL A TECHNICIAN. ALSO CHECK THE SIDE OF THE MOTOR TO SEE IF IT HAS GONE ON THERMAL OVERLOAD(LITTLE RED BUTTON). RESET IT AND THEN PRESS PRIMARY CONTROL BUTTON. IF MOTOR BUTTON HAS POPPED OUT THEN REPLACE MOTOR. COULD ALSO BE A BREAKER. GOOD LUCK THANKS FOR AN HONEST RATING AND FOR USING FIX-YA.
Nov 09, 2008 | Bryant 462AJC021BA Air Conditioner
Ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Sep 15, 2008 | Ruud UBHC Air Conditioner
Rheem Central Air united stopped working, no hum but power is there
It looks as if the 24 signal from the thermostat is not getting to the contactor. Or possibly the coil in the contactor itself is dead. Or a third option may be a bad control power board in the condensing unit itself. If you feel comfortable reading through these devices comment back. PLEASE REMEMBER THERE IS HIGH VOLTAGE INSIDE THE CONDENSER AND A CAPACITOR.
Jul 06, 2008 | Ruud Heating & Cooling
Heating & Cooling Logo
116 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
