Question about HP Compaq Presario 2200 Notebook
How do i remove my compaq presario 2200's hard drive?
    President:
  • 567 Answers
The Compaq Presario line is one of the longest-running series of computers, originating in 1993 and remaining in production even after the purchase of Compaq by HP. Because of this, many Compaq Presario desktops have required that some of their parts be upgraded or replaced because of the wear that they have received over years of standard use. One of the more commonly replaced Presario desktop components is the hard drives, especially given how much hard driveHow do i remove my compaq presario 2200's hard - mag-glass_10x10.gif storage capacity has increased since the Compaq Presario line was introduced. Replacing a hard drive in a Compaq Presario desktop isn't difficult, and can usually be done in a matter of minutes even for users who aren't familiar with computer upgrades.
structions
  1. Step 1Remove the screws holding the left side panel of the computer on, then slide the panel back to remove it. Set both the panel and the screws aside so that you can put the panel back in place once the hard drive has been replaced.
  2. Step 2Unplug the ATA (wide, flat and usually gray) or SATA (thicker, thin and red) data cable and the power cable from the back of the hard drive that is currently in the Compaq Presario. Move the cables so that they will be out of the way, but make sure that they will still be easily accessible to you so that you can plug them into the new hard drive.
Posted on Aug 08, 2010
  • Hilton Bristol Aug 08, 2010
  • Unscrew the screws that hold the hard drive in place and then slide it out of the mounting bay that it is in. Set the old drive aside and place the screws in a convenient location where they won't get lost.
  • Step 4Slide your new hard drive into the same mounting bay that the old Compaq Presario hard drive came out of. Line up the drive so that you can secure it using the screws that had been removed from the old hard drive, then plug the data and power cables into the back. Don't worry about accidentally plugging them in incorrectly; the cable plugs are designed so that they will only plug in the proper way.
  • Step 5Place the side panel back on your Presario desktop and use the screws to hold it in place. Turn on the power to the computer and begin formatting your hard drive or installing an operating system so that you can make use of the new hard drive in your Compaq.
5 Suggested Answers
ArmyMason
  • 121 Answers
SOURCE: remove hard drive in compaq presario laptop f572us
Please see link for Detailed instructions. Its simple as unscrewing a few screws and sliding out the hard drive.
Posted on Apr 01, 2009
  • 31 Answers
SOURCE: can I put my dell 2200 hard drive into my compaq
If your trying to use the operating system from Dell 2200 in your Compaq... your going to have driver issues and Windows liscense issues... it may not let you boot into the operating system seeing that how Microsoft builds the copy protection by building in the hardware where Windows was first activated into the encrption for the copy protection. That being said... If you want to erase the drive and install it as a new drive into the compaq and then put a Operating System on it from there... you can do that.
The Bottom line is yes you can use your Dell Hard Drive in your Compaq as long as you Erase it and Reinstall a Operating System on it once you get it in the Compaq.
Hope this Helps!
Posted on May 11, 2009
ICmanServer
  • 129 Answers
SOURCE: compaq presario cq40 how do i remove the hard drive
Hi..
If you want to remove hard drive of your unit. Be sure that do you have little idea to do it with your own. You need to remove first the screw of your unit to open the back cover. Once you are already open the cover, you can remove the hard drive slowly.
Regards
ICmanServer
Posted on Aug 12, 2009
Geekman
  • 32281 Answers
SOURCE: the compaq presario v3000 replace hard drive
Yes you can according to the maintenance manual click on this link to download the manual (PDF file) :-
http://h10032.www1.hp.com/ctg/Manual/c01035667.pdf
You can also re-use the old hard drive by inserting it into an USB hard drive adapter case and use it as an USB external hard drive.
Posted on Dec 02, 2009
Testimonial: ". . . and now to also discover a "USB hard drive adapter case". Thanks for the suggestion."
Presario 2200 hdd not being detected
This is not good, remove the hard drive and reseat it back in place, sometimes that is enough to get it going, if no change! the hardware may be open and if that has been determined you will need a new hard drive.
Mar 28, 2012 | HP Compaq Presario 2200 Notebook
How do I remove a Compaq Presario 2200 forgotten drivelock password
If you forgot the password of the hard drive I'm afraid there is no way to access the drive any more. This password is used to encrypt the hard drive entirely, and without this key there is no way to decrypt the files or access the drive.
Jan 31, 2011 | HP Compaq Presario 2200 Notebook
My Compaq Presario 2200 powers on ("on" led, drive
1) put the laptop on a bed or a similar surface to close the air openings below
2) wait some time (15-30 min or 1hour) and let it get warm enough
3) restart.
it worked for mine. hope it works for you too.. the laptop seems stable and does not give any more beeps (for now).. good luck !
Jan 02, 2011 | HP Compaq Presario 2200 Notebook
What is the largest drive I should put in my Compaq Presario 2200 PC Notebook?
Usually the drive which can be put in your machine depends on what you want to use the machine for. But usually to attain optimum performance it is advisable to put in a hard disk in accordance to the RAM on your system. The ration of RAM to hard drive should be about 1 Gig Ram to 100Gig Hard drive. This should help you decide what size of drive to put.
Hope this solution has been helpful?
Nov 30, 2010 | HP Compaq Presario 2200 Notebook
Remove hd compaq presario 1621
I think it is the same as HP. When you undo the cover just pull it right out by the small plastic. No screws holding the drive.
Apr 21, 2010 | Compaq Presario Notebook
Where is the hard drive located ?
moz-screenshot.jpgplease copy and paste the link below to access the user manual.
search hard drive as key word for easy reading.
http://www.elhvb.com/mobokive/edwin/laptops/Compaq/Compaq%20Presario/Compaq%20Presario%201230-1250.pdf
Apr 16, 2009 | HP Compaq Presario 2200 Notebook
Hard drive failure compaq presario 2200
If the bios is showing no ide, means that your ide hard drive is not being detected.
This can be caused by some motherboard failure, some bad cable connection or caddie connection or bad hard drive.
Nov 05, 2008 | HP Compaq Presario 2200 Notebook
Presario 2200 won't boot up
Hello
your hard driver is broken or it can be your motherboard sata controller.
sorry
replace your hard drive and run a restore. you can get your restore cds from HP.
check if you have warranty left. then you can go to nearest hp reseller and get your motherboard or hard drive changed for free.
good luck
Aug 10, 2008 | HP Compaq Presario 2200 Notebook
HP Compaq Presario 2200 Notebook Logo
1,102 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
