Question about Health & Beauty
I HAVE A 1997 CEVY SUBURBAN 2500 5.7 ENG, 4/4. I HAVE OBD CODE 151. AND NEED TO KNOW WHAT IT MEANS, SOME TIMES IT RUN GOOD AN THEN SOME TIMES NOT SO GOOD .WHAT MUST I DO WITH THAT CODE TO FIX .MY NAME MARVIN MY EMAIL IS KORNEGAYENT@VERIZON.NET
    Brigadier General:
  • 7,191 Answers
Kindly submit the question under Chevrolet Suburban section on the website by clicking this link so that the top car experts can view and provide a solution to the problem.
Thanks for using FixYa
Posted on Aug 08, 2010
Code p1351
GM General Motors P1351: ICM Circuit High Input Conditions Details: With engine speed less than 250 rpm, ignition control enabled, the VCM detected that the ignition control circuit was more than 4.90 V
Read more at: https://www.obd-codes.com/p1351
Copyright OBD-Codes.com
Feb 22, 2018 | 1997 Chevrolet Suburban
How to tell if o2 senseris bad
Check OBD Codes with a reader. It should give you a fault code letting you know if an O2 sensor is bad. May even tell you which one needs to be replaced..........
Dec 05, 2013 | 1997 Chevrolet C/K 2500
1995 chev suburban 2500 wont stART
First, you need to know that when you are asking for help with your vehicle - ESPECIALLY when you have and engine that will not run, there is some standard information you should include:
> C-2500 Suburban (2-Wheel Drive) or K-2500 Suburban (4-Wheel Drive)?
> Which ENGINE is your Suburban equipped with?
> Is this an AUTOMATIC or STANDARD transmission?
These things can all make a HUGE difference in the wiring diagrams for your vehicle. There are also some components that are used on one vehicle that do not exist on others. So, to make sure we are working with the correct information for your vehicle, it is necessary to get a FULL description of the vehicle.
With all that said, I also find that the problem description is a little unclear. When you say "No response from the ignition electrical system", do you mean that the starter will not crank the engine? Or do you mean that the starter is cranking the engine, but there is no ignition? Or do you mean something more like nothing works when the ignition switch is turned on?
When it comes to electrical diagnosis, it is very important to know what IS working, as well as what is NOT.
Get back to me with this information and I will see if I can help you.
Apr 12, 2012 | 1995 Chevrolet Suburban
4 flahes, then 2 trouble code on a 1995 chevy suburban
it is a 42, 96 on up use a OBD-II system to read codes. older than 96 use an OBD-I system to read codes. 42 means - electronic spark timing or bypass fault. this means that BYPASS line is open or grounded,
2) EST line is open or grounded
3) PROM or CALPACK not seated properly in the ECM
4) Poor connections between ignition module and ECM
5) Poor routing of EST harness and/or poor quality ignition wires (EMI induced electrical noise)
6) Faulty or incorrect ignition module
7) Faulty ECM.
May 22, 2011 | Chevrolet Suburban 1500 Cars & Trucks
I have two codes coming up,they are 1-2 and 4-3
I don't think you have the OBD system yet in that vehicle . the 1-2 is a code 12 and should have flashed 3 times. 12 means the computer is working to give you codes. The 4-3 means code 43 and that should be:
  • ESC circuit
  • knock sensor signal
I hope this helped and good luck.
Feb 06, 2011 | 1990 Oldsmobile Cutlass Ciera
How to change a heater core on a 1997 GMC suburban 2500
Most are under dash inside heater box you have to disconnect all cables and hose lines .before you can remove core also have to drain coolant out of core...It is a lot of work and not always easy to get back in and sometimes cables do not work as well as they did before repair i personally suggest you get a price from a good Rad shop it may save you a lot of greif in the long run....good luck on your decision also in my taraus I had to remove the entire dash to get at the core
Dec 21, 2009 | 1997 GMC Suburban
1999 Surburban 2500, 7.4, surpentine belt installation
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I have only been a free contributor to this site for the past 4-months.
I do not know if you still need this information, but I am going ahead and answering it anyway.
CLICK
on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies....
http://www.2carpros.com/car_repair_information/year/1999/make/chevrolet/model/suburban/1999_chevrolet_suburban_drive_belt_routing_diagram.htm
Aug 10, 2009 | 1997 Chevrolet Suburban
Need steps to reprogram chevy suburban 1997 keyless entery
1. Locate the Data Link Port. It is located under dash drivers side. Be sure you know
which pins are 8 and 4.
(Note port is wider at top) Your OBDII port will not
have numbers, use the for reference.
2. Make sure there are metal contact pins in terminals 8 and 4. Connect 8 to 4 with a
suitable jumper wire (leave the jumper wire connected throughout the programming
procedure). Make sure you know which terminals are 8 and 4. The vehicle will respond
by locking and unlocking the
doors to signify entering of programming mode.
3. Press and hold both the LOCK and UNLOCK buttons together on the first transmitter to
be programmed. After about 15 seconds, the vehicle will respond by locking and
unlocking the doors. Release the buttons on the transmitter.
4. Within one minute, repeat the previous step on the remaining transmitters to be
programmed.
5. Remove jumper wire applied to the OBDII Port.
Jan 15, 2009 | 1997 Chevrolet Suburban
Health & Beauty Logo
22 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
