Question about Microsoft Xbox 360 Hard Drive (20GB)
I just got a 120gig external hard drive with a E68 message on it is it possibal to fix it?
    Novelist:
  • 105 Answers
Hi Keith, the E68 error is common and basically there are many causes: internal connection problem, overheating, HD general failure. You should try to disconnect the HD and see if your console works properly. If yes then it's luckily related only to the HD and not affecting your 360 :) If you get the same error also after HD removal, please advise me with few more details and we'll try to get rid of it. Now, as you just bought it, i'm assuming you have warranty so i'd bring it right back to the store and ask for a new one or a refund. Regards, Peter
Posted on Aug 08, 2010
E68
E68: Hard Drive Error - Hard drive not DMA configured: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it. Also this can be caused by a problem with the fans that make them draw too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices. If you have any case mods you may want to investigate those as well.
Apr 24, 2011 | Microsoft Xbox 360 Console
I was watching net flicks and my xbox rebooted and flashed a red ring (bottom right) and it said E68. i shut it off and started it up again and works<did that twice<the unit was alittle hot...
The e68 error on your Xbox 360 is caused by a hard drive/HDD problem. It can be caused by an internal connection error with the hard drive, a general failure of the hard drive, or overheating of the hard drive. Basically, there is quite a large range of things that can cause the Xbox 360 e68 problem, which can make troubleshooting the issue slightly difficult.
To fix the e68 code on your Xbox 360 is to remove the internal hard drive and try playing your console without it. If it then works, then you can be sure that you can permanently fix the problem. If not, then you will have more serious issues on your console that will need to be checked over by Microsoft, as the e68 is generally believed to be related only to your console's hard drive/HDD.
Hope this helps.
Mar 06, 2011 | Microsoft Xbox 360 Console
A message on the screen says system error contact customer support code E68
Regards.
Jan 16, 2011 | Microsoft Xbox 360 White Console
How i fix on my xbox 360 e68 problem?
hi, that error code usually relates to either a problem with the hard drive or a problem with the fans or a problem with some external source such as extra fans or other devices connected to your xbox, so try playing with no hard drive attatched and if it still dont work you know the hard drive is working as it should, if it works without the hd then it will need formatting or getting a new drive.
if it still dont work and you have extra things plugged into xbox unplug them and see if it works, if nothing works then the problem could relate to the wrong voltage getting to the fans.
here is the exact e68 error code:
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Dec 07, 2010 | Microsoft Xbox 360 Console
E 68 error....will transfer cable help fix it?
The E68 is a weird error. Its normally from a hard drive failure. The underground xbox 360 scene says
THe E68 is a Hard Drive Error. The Hard drive is not properly configured: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it.
If the xbox can play without the hard drive then this error can be caused by a problem with the fans that make them draw too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices.
If its the hard drive or your console causing the problems contact Microsoft they will probably fix your hard drive and maybe recover your game saves. On the newest games that info is stored on xbox live.
http://support.xbox.com/support/en/us/nxe/contactus.aspx
May 08, 2010 | Microsoft Xbox 360 Hard Drive (20GB)
XBOX System error E68
my friend suffered like these doubts....... he cleared his problem with the help of xbox 360 repair guide...... click here for your reference
May 08, 2010 | Microsoft Xbox Console
On my xbox360 i got the e68 error message and i took the hard drive out, and then put it back once the xbox was on and i went to memory on the system settings and for my main profile it said corrupted...
can you still access anything else that was saved on your hard drive?
such as demos or anything else you downloaded, etc? generally that means your hard drive has over heated, or worse, crashed. but! you got lucky that your whole xbox didn't crash with it. there is a chance you can save your hard drive and all your files. there is a how to here: http://ezinearticles.com/?Xbox-360-E68-Error-Fix&id=2549596
Aug 06, 2009 | Microsoft Xbox 360 Console
E68 error on xbox 360 HELP PLEASE
A Working Solution.
Remove any disk from the DVD drive.
Remove the hard drive and turn on. When you get to the dashboard turn it off again by holding the X button on the controller and select 'Turn off console'.
Wait 10 seconds and then turn on again by pushing the X button on the controller. When you get to the dashboard turn off again via the X button.
Remove the AV / Video plug from the back of your Xbox.
Replace the hard drive correctly.
Switch on the Xbox via the power button on the console. 4 red lights should flash.
Wait 10 seconds and re-insert the AV / Video cable.
You should now load into the dashboard with your hard drive profiles - wait theres more!
Turn off and on via the X button as before another 2 times with all leads and the hard drive in place.
After you power it off the second time, remove the power lead for 20 minutes and then turn on again any way you feel like it and it should be cured.
E68
E68: Voltage Error... This error means that the Xbox 360 has insufficent power to function properly. This can be caused by an error in the hard drive or the fans that make them **** up too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices. If you have any case mods you may want to investigate those as well
more information can be found at http://support.microsoft.com/kb/917874
Nov 29, 2008 | Microsoft Xbox 360 Console
System error E68
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error. Some also believe this might be caused by a problem with the fans.
Feb 25, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Hard Drive (20GB) Logo
59 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
