Question about ASUS Motherboard P5n-mx
What is a video adapter.,my cpu beeps 1long2short and according to my guide.,it has a problem in the video adapter. i have no idea what is a video adapter and what am i suppose to do?
    President:
  • 567 Answers
Hi the video card is the 15 pin blue connector which you connect the monitor to,each motherboard has one built in,if you are using a built in video card you or one in the computer.You should buy one which is compatible with you motherboard.There are two types of video cards " AGP and PCIe if your motherboard has a short brown slot saperate from the other slots, you are using AGP but if it use a green slot its PCIe make sure you buy the right one.
Posted on Aug 08, 2010
Why does my computer beep when I turn it on?
Here is a list of what beeps may mean:
1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU 1 short DRAM refresh failure 2 short Parity circuit failure in the first 64KB of RAM: Likely a bad RAM IC, or possibly one of the hardware tests has failed
Once you have identified what the beeping means you should contact the type of pc you have and ask what to do.
PCHELPSTER007 from youtube
Jun 25, 2011 | Computers & Internet
Tip
A Comprehensive Guide on Computer Beep Codes. (AWARD BIOS)
When a computer is booted up its BIOS, it performs a power-on self test, also known as POST, to test and verify the computers hardware and to make sure all components are working properly. Here's a comprehensive guide on how to determine which component has failed on a particular beep code and give you an idea on where to start for troubleshooting.
The exact meaning of the beep codes depends on the type and version of BIOS that you have. The three most popular types of BIOS are those made by Award, American Megatrends (AMI) and Phoenix. If you are using a PC made by a company that writes its own BIOS, e.g. DELL, HP, etc, you will have to consult your PC user's manual or the company's web site for assistance.
Beep Codes for Award Bios.
1 long, 2 short = Video adapter error
Troubleshooting: Either video adapter is bad or is not seated properly.
Repeating (endless loop) = Memory error
Troubleshooting: Check for improperly seated or missing memory. Reseat the memory if you can.
1 long, 3 short = No video card or bad video RAM.
Troubleshooting: Reseat or replace the video card.
High frequency beeps while running = Overheated CPU
Troubleshooting: Check the CPU fan for proper operation. Check the case for proper air flow.
Repeating High/Low = CPU failure.Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat.
Troubleshooting: Check the CPU fan or BIOS settings for proper fan speed.
I will be posting more tips on other versions of BIOS.
Hope this helps.
on Mar 25, 2011 | Computers & Internet
My computer is beeping every so often it beeps about 3 times and it does it fast please tell me why
It only mens that there's an error on your computer.
Beep codes are use to check or identify which computer part/s causing the problem.
Beeps
Error Message
Description
1long, 2 short Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly. Repeating (endless loop) Memory error Check for improperly seated or missing memory. 1long, 3short No video card or bad video RAM Reseat or replace the video card. High frequency beeeps while running Overheated CPU Check the CPU fan for proper operation. Check the case for proper air flow. Repeating High/Low CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat. Check the CPU fan or BIOS settings for proper fan speed.
May 11, 2011 | Toshiba Computers & Internet
No start up and continuous repeated long beeps?
Hello
Here are the bios beep codes:
1 long, 2 short
Video adapter error
Memory error
1long, 3short
Overheated CPU
Repeating High/Low
CPU
Check computer beeps and act according to suggestion
Hope it helps if so do rate the solution
Dec 20, 2010 | Compaq Presario Notebook
WHEN I TURN IT ON, THE COPUTER STARTS BEEPING
that sounds. are memory problem related :
Beeps Meaning 1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU
May 10, 2010 | Computers & Internet
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
What is the beep code asus p5ntws
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
Apr 20, 2010 | ASUS P5NT WS (P5NT WS GREEN) Motherboard
Boot Issues
Check the memory and the video.
Jul 20, 2008 | Intel Motherboard
Continuous Beeping, new PC
Hi.
Continues short beeps... means a short OR no power OR loose card OR system board.
Test it without the keyboard and mouse too. Just the Processor with heatsink, motherboard, memory and Video card.
Now add the keyboard, no mouse yet.
Check also the voltage of the CMOS Battery it should be 3V.
keep me posted for the result... count also the beeps.
Feb 09, 2008 | Intel Motherboard
Long Beeps every other second
Ok, I did some research into your board. Your motherboard is running an award bios. All motherboards use beep codes to tell you what is wrong. You've got a hardware problem somewhere for sure, but where is the question. If you're having 1 long beep, with the same timing and frequency over and over then according to the codes you most likely have a memory problem. Try resetting the motherboard by resetting the cmos ( you can also do this by removing the power from the computer and taking the little clock battery off of the motherboard for about a minute). Also, make sure your ram is tightly seated. In fact, take the ram out and then place it back in. Try running the computer with only one of the chips of ram installed (if you have more than 1 chip that is). Maybe one of the chips went bad. Finally, here is a list of the award beep codes. If you are getting beeps that match one of these examples better than we can go from there. 1 Long, 2 Short - Video adapter failure Repeating (Endless loop)- Memory error 1 Long, 3 Short - Video adapter failure High freq. beeps (while running) - CPU is overheating Repeating High, Low beeps- CPU failure
Sep 30, 2007 | Biostar K8VGA-M Motherboard
ASUS Motherboard P5n-mx  Logo
79 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
