Question about Samsung TX-P2670WH 26" TV
It turns off by itself. Now it won't turn on. It's a TX-P2670WH. Looked inside for bulging capacitors; nothing.
  • alan_dnn Aug 08, 2010
    Already posted with tech.
  • Samsung Master
  • 3,866 Answers
Just look for bad capcitors will not cut it,
1. Check if the fuse has blown
if the fuse has blown you can replace it but if it blows again then you got power supply issues and you going to need ot take it down to a local tv repair shop.
just checking for blown caps is not goign to solve your issue or make new issues there are reasons why a cap would blow and you must follow up on those reasons like a bad relay, bad transformer ect ect.
let us know
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 08, 2010
  • 1 more comment
    The fuse is fine. The problem was gradually getting worse, so last week I took the back off and blew the dust out with a compressor; it worked great for a while. Now it turns itself on and off, making a high pitched noise with flickering lights; no picture.
    Thanks
  • Grand Canyon Tech
    Grand Canyon Tech Aug 08, 2010
    I did some investigation on your issue and I am saddened to bring you this sad news because there are no parts for this set anymore you might reconsider even trying repair.
    The power supply is your major issue there. It has been found in these sets that there has been a crack that has fromed in these PCB's on these power supplies you cannot really see the cracks but its caused from heat /dust and the like.
    I really wish I can give you a little better heads up but finding a power supply for this little guy is not going to be easy.
    let me know :(
    Okay, thanks for your help. I bought this TV six years ago, and now I can buy a larger one for half the price I paid back then. Less than the cost of repairing this one, I can see.
Westinghouse 42" TV, model TX-42F430S, will not turn on. Orange light in front appears rather than the blue one.
There is a defective electrolytic capacitor (470MF/16V) on the main board that went bad, it will causes intermittent, slow, or not power up, the location number of the cap is not marked on the board, please see the attached photo to locate it.
Mar 12, 2014 | Westinghouse LTV-30W2 Television
The yellow LED on my Toshiba 32CV510U flash all the time and TV won't turn on
check some leak or bulged capacitors at the power supply board then replace it.
Oct 02, 2012 | Toshiba 32CV510U LCD TV
My L.G 50pc3d won't turn on and all I hear is
try to check all capacitors inside if looks like bulged on top try to replace it with the same value.
Apr 27, 2012 | LG Televison & Video
I have a emprex wt323 that won't turn on I was
It most probably is the power supply board. There is a repair service which addresses any problem with the power supply board, not just bad capacitors: http://www.coppelltvrepair.com/p/779/emprex-wt323-power-supply-board-repair-service-no-power-shutdown-etc
Mar 11, 2012 | Televison & Video
My philips lcd tv does not turn on, it just blinks for 5 times and then nothing... what could be the problem?
good day if the tv won't power up then just only a blinking light from the indicator, you will need to check the power supply first. you can apply the visual checking usually bulging capacitors at the secondary filter capacitor of the power supply they are leak which need replacement. sample of bulged capacitor en.wikipedia.org/wiki/Capacitor_plague . you can find replacement at www.digikey.com. now after you replaced defective capacitors turn on the tv unit then check all the out put voltage if normal the 5v stand by. 5v switched, 12v, and 24v for inverter ballast now if those voltage are stable i'm pretty sure your tv unit will working fine.
Aug 19, 2011 | Televison & Video
My panasonic th-50px60u television turned itself off last night and won't turn on makes clicking noise when unplugged and plugged back in but then nothing red light flashes
Tries tv unplug,replug it back like about an hour later for the tv to do it resetting itself back to the factory setting,tv might work again.If not still same problems.The tv 90-95% it is the board that call the tv power supply board is having a problems.That the board where the tv power a/c cord plug into it.U have all tools and know basic electronic and also can do basic soldering works too?Yes,take the tv aparts,check the tv power supply board carefully for dying and soon to be dead capacitors components parts.These capacitors components parts are alway bulges up or puffing up onto it tops.These dying and soon to be dead capacitors components parts are bulges or puffing ups on to it tops must have to be replaced will solved ur tv power unstable and flashing red light.Or try website like Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Jul 29, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Jan 01, 2008 | Samsung TX-P2670WH 26" TV
Interesting problem
It sounds as if you have a cold solder joint. I would check for bad solder joint(s) around the flyback transformer as this can be a common problem in some televisons.
Jun 04, 2007 | Samsung DynaFlat TX-P3071WH 30" TV
Samsung TX-P2670WH 26" TV Logo
29 people viewed this question
Jerry Greenberg
Jerry Greenberg
