Question about Honeywell Heating & Cooling
The unit will not turn on in the "auto" mode. cool on is flashing.
    Guru:
  • Honeywell Master
  • 588 Answers
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on Aug 09, 2010
What does the snowflake mean on a Honeywell thermostat in cooling mode. Also had the problem in the heating mode.
The snowflake means it's cooling. If the outdoor unit is not running then the problem is likely outside.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 21, 2017 | Honeywell Heating & Cooling
Standby keeps turning on when in standby but auto works turns itself on and off fine. Both sides of unit
I don't think you have a problem... I have a Taylor 8756p-27. In standby mode with my unit the beater motor turns on for about 15 seconds every 15 minutes and the compressor turns on as needed to keep the mix at a safe temperature. This is what standby mode is supposed to do. If you don't want it to turn on and off so much in standby mode, perhaps leave it in AUTO mode and it will turn off and on as it needs to to keep your product at the proper temperature.
May 06, 2015 | Taylor 754-33 Ice Cream Machine Soft Serve...
What does blinking light on wall unit mean?
When the Operation lamp is flashing, the unit can't operate efficiently and has shut off. Check and clean the Air Filters. Check that nothing is blocking the air inlet or outlets (on all indoor units (if a multi-unit system) and the outdoor unit). Remove all obstructions. Turn the breaker to Off and then On again. Check if the unit works with the remote.
If you have a multi-unit system, make sure that all indoor units are in the same Operation mode. If the units are on Auto, make sure that all units are set for Heat or Cool.
If the unit continues to have the Operation light flash, then you need to contact your service professional. The Operation manual for the FTXS18HVJU is available here: http://www.daikinac.com/content/assets/DOC/OperationManuals/FTXS15_18_24LVJU%20Operation%20Manual.pdf
I hope this helps.
Mar 11, 2015 | Daikin FTXS18HVJU Wall Mounted Indoor Unit...
Flashing light the at says e6
Usually Indoor Unit Anti-freezing protection (Cooling
Mode) or Over-heating Protection (Heating Mode)
for Evaporator
A) Indoor room
temperature too low
under cooling mode,
Too high under
heating mode
B) Indoor unit filter or
evaporator too dirty
C) Indoor unit fan motor
blocked
D) Insufficient refrigerant
under cooling mode
E) Indoor unit evaporator
sensor wrong
connection or failure
Jul 28, 2014 | Samsung AQV12VBE Vivace Wall Heat Pump Air...
How do I turn the flash on on my Nikon D70?
if u select mannual mode u have to press flash button,whitch is on left side below flash unit,if u select auto mode, flash itself elect when u half press the click button.
Mar 08, 2010 | Nikon D70s Digital Camera
What do the controls on a portabel AC mean. Like the mode button.
my 4m40mitsubishi model have something nocking during a litlle accelerating in the acelerator
Oct 07, 2009 | Heating & Cooling
Wireless Thermostat is chirping at base unit
look on touch pad for music symbol put in auto mode or heat cool mode than push program mode than push on music symbol to turn off chirp
Oct 04, 2009 | Honeywell Heating & Cooling
Pop-Up flash - Rebel xti
You will need to send the camera for servicing. There's a lever mechanism inside the flash unit which is responsible for popping up the flash. Since it is a mechanical device, it is sometimes prone to failure. I suggest not to put manual pressure to force the flash to come out, as it may cause permanent damage. Instead, send the camera for service.
Dec 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Heating & Cooling Logo
48 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
