Question about Dell Latitude C840 24X CD-R W/ DVD Combo (SIDE Unit) - D1361 CD-ROM Drive
Okay, I have a Dell C840 I bought on E-bay. The hard drive was destroyed due to private info. Well, I bought an external hard drive for it (Seagate 320 GB). Problem is, even before attempting to connect this to the Dell, I got an error message after turning it on. It came up to a black screen said "No bootable devices-strike F1 to retry boot, F2 for setup utility" I've tried changing boot order to the cd/dvd drive first and still no luck. It still did the same. I found a post about the cmos battery? Thing is, I don't know where it is? Any help? Thanks.
  • wysn Aug 08, 2010
    I should have mentioned that the old hard drive is not in it (that's why I said destroyed). It did not come with the laptop. I tried booting with a windows cd as well and it did not work. :( Under the BOOT ORDER screen these are the options: cd/dvd/cd-rw/drive, modular bay hdd diskette drive internal hdd onboard nic cardbus nic I don't even know NIC stands for so I didn't mess with those. All of those are enabled also. Could there be a conflict? I know, I doubt it, but thought I'd ask.
  • wysn Aug 10, 2010
    no, problem not solved.
    I mentioned there was no hard drive installed to begin with.
    Brigadier General:
  • 4,044 Answers
I doubt if that will help much. The problem is when you first turn it on it does a search for boot devices. Unless you put that USB device as a boot option, which I doubt you can, it will not boot from it. Try partitioning that old hard drive and then formatting it to make it usable. You could also try booting the computer with a Windows CD in the CD drive to get it to boot from CD. Right now the machine isn't recognizing the format of any devices and most likely isn't setup to boot from a USB device. Another option you could try to use to assist in partitioning and formatting the HD is Knoppix. Knoppix is a Linux based operating system that will run from CD/DVD that will give you some tools to use in Partitioning the Harddrive. You can usually get it in a book store with a Manual on how to use it for about $12. I found one in a Half Priced book store for $3 and still use it as a Primary Operating system. Very dependable and very light on resources required to run it.
Posted on Aug 08, 2010
  • 3 more comments
  • wysn Aug 08, 2010
    cd/dvd/cd-rw/drive,
    modular bay hdd
    diskette drive
    internal hdd
    onboard nic
    cardbus nic
  • James Young Aug 08, 2010
    If you can't boot from the CD there maybe a second setting in bios that needs to be set or the CD drive isn't working correctly. Windows install disk are usually in a DVD format that some machines don't like initially. The knoppix I mentioned is a CD not a DVD and should boot unless you Drive is bad. your last option to format that hard drive so the machine will at least boot to DOS is to remove the drive and put it in a portable case and connect it to another computer through the USB port and format it that way.
  • wysn Aug 08, 2010
    I missed you mentioning about the windows being on dvd or cd. It is on a CD-R disk.
  • James Young Aug 09, 2010
    You say CD-R, do you mean it is a copy? That would explain why the computer didn't boot from it. Windows Installation disk do not copy correctly because of their formatting. It is not a standard format but a format that must have a little file stored in an area of the disk that can't be copied by a standard DVD or CD. Get an original disk and try booting the machine from that and using the included tools to format the Disk during install. If your using a copy of a Windows install disk it's most likely never going to work.
  • wysn Aug 09, 2010
    I have always used the disk before on other computers with no problems, but aside from that, the bios is showing no fixed optical drive installed. Perhaps I should have did more research before purchasing this Dell. :(
  • Dell Master
  • 3,247 Answers
Refer to the "reserve battery" description at this site.
The full service manual for the C840 is available at this site.
If it is not booting from the CD then it is possible the whole system is faulty. What is the CD you are using to boot? Is it a bootable Windows CD?
Try it on a working PC by booting from its CD after changing the boot sequence.
  • 3 more comments
  • wysn Aug 08, 2010
    I will try this now, but since I get nervous working with small parts it may take a bit. I will keep posted. By the way, yes, it is a bootable Windows XP cd and it does work as I've used it before a few times. I did also try it after changing the boot sequence and it still gave me the same error.
  • wysn Aug 08, 2010
    I did that and it did no good.
    The disk is a bootable Windows XP Home Edition and it is on a CD-R
    It is a good copy because I've used it a couple times before. I actually have a couple copies of the same disk. Made them in case I needed them. (Happens with kids)
    Now, I managed to use another laptop with XP on it to load the disk on the external hard drive. Now, how can I get the Dell to recognize it because it still isn't? I thought it would have.
  • Sam Aug 09, 2010
    It looks like there is more than just a faulty internal hard drive on your dell. If the boot with CD is not working then it is a bigger problem. I don't know how you are connecting the external hard drive to it? Unless the BIOS software on the motherboard can recongise the external drive it is not going to boot from it.
    Does the setup utility show USB as a boot sequence?
  • wysn Aug 09, 2010
    This SeaGate external hard drive connects using a USB port. Ugh, no, it does not give USB as an option to boot from. Double checking, it says there is no fixed optical drive installed even though there is.
  • Sam Aug 10, 2010
    As mentioned before your laptop does have some problem with the IDE or whatever it uses to communicate with disk drive and optical drive.
    Best to go to a repair shop and have it checked. You will not be able to do much without the IDE working.
I need to get working non dell harddrives
Hard drives are hard drives. They will work in any computer..
Mar 13, 2014 | Dell POWEREDGE 1950 Server
Dell firmware for Seagate SAS harddisk
The firmware for any electronics device tells the hardware how to properly function.
Most devices rarely need a firmware upgrade, however, computer products such as a Seagate hard drive need to have the firmware updated periodically due to computers constantly going through operating system upgrades.
Luckily, you can update your Seagate hard drive firmware with an Internet connection and a few clicks of your mouse.
Connect your Seagate hard drive to your computer if the hard drive is external.
Launch your Internet browser and navigate to the Seagate.com website.
When the site loads click the "Downloads" button.
Click on the hard drive listing you currently own.
This brings up all of the most current downloads for your Seagate hard drive.
The listings of the hard drives have the image, so match your hard drive to the image online if you are not sure what drive you have.
The user manual states what hard drive you currently own also.
If you don't have your owners manual, open "My Computer" (or "Computer") and right-click the hard drive icon and select "Properties."
Here the computer states exactly what model of hard drive you have.
Click the Firmware update and click the "Download" button to launch the download.
Click-and-drag the file into the hard drive if you are using an external hard drive
(open "My Computer," then double-click the removable hard drive icon).
Open the downloaded file and follow the prompts to install the updated firmware.
Hope this helps
Nov 11, 2012 | Dell 300GB 15K RPM SAS 3G 3.5 INCH...
I have a Seagate Free Agent Desktop External Hard Drive. I cannot get any of my computers to access the drive. I fear the drive has crashed.
get linux puppy and boot the cd while your hard drive is plugged in, if you can mount under puppy linux and see your info choose the info you need and offload onto an external usb, copy the files over, dont move them as if disk is corrupt you could lose info, then reformatt the drive, just to let you know there seems to be alot of hard drive issues with seagate lately
Feb 14, 2011 | Seagate Computers & Internet
Optical drive not recognized in Bios
You have either a bad optical drive or optical port. You can still load the OS but you need to make a bootable USB drive and install that way. Or get and use an external USB optical.
also, check in your bios or for the drive settings, it may be set to only accept sata drives or the port may be disabled. some latitudes give the ability to disable or not look at a specific port.
Jun 13, 2010 | Dell Latitude C840 24X CD-R W/ DVD Combo...
Recovered my pc,lost seagate manager somehow
Go to http://www.seagate.com/www/en-us/support/downloads/ and select your product then you can download any documentation and drivers that you need.
Mar 01, 2010 | Seagate FreeAgent Pro 1TB External USB...
When I turn on the laptop ...it says the dvice in the system modular bay can not be identified
Did you ever solve the non-recognition problem?
My C840 fails to recognize the/an extra HD in the modular bay, after I "overfilled(??)" it.
What to do to regain access to information stored on HD that the computer no longer recognizes? (Other components, including other HD's continue to work ok in the modular bay).
kcdd30a@aol.com
Nov 07, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
Is there any adapter neccesary (or is it even possible) to make a SATA hard drive compatible with a laptop that uses an IDE hard drive?
Basically not internally. About the only way to do this would be if the hard drive was an external hdd. Hope this helps.
Oct 12, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
Seagate FreeAgent external hard drive 500GB not recognising directory tree
Its the rubbish software that Seagate have bundled with their drive which will not allow you to backup the system folders. Solution is to use another backup utility, a google search will quickly locate numerous FREE software products which will alow you to copy anything. Unfortunately when you start googling about this drive you may be quite distressed about your purchase, as i have been :( Problems lay ahead with this drive due to inadequate cooling.....
Jun 12, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
52 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
