Question about Kenmore Elite 45986 Front Load Washer
Kenmore 800 ultrasoft water softner
I need to identify the power transformer for this unit. I have a customer who is missing one. Is it the same as the 400 series units ?
I  could not find a product to fit this request
    Problem Solver:
  • 6 Answers
Simply go to Sears parts web site and type in the model # and view the transformer needed and it will list the part# and price. www.sears/parts.com Good luck
Posted on Apr 29, 2008
My Kenmore Ultrasoft 400 water softener tome light will not stop blinking. How do I reset it
It's been 10 years since I worked at EcoWater, but the Kenmore Ultrasoft 400 shouldn't have changed much. The brine tank light shouldn't blink at all. It should light for 4 minutes and then go out if you leave the door open if I remember correctly. How old is your softener and does it have a light bulb or an LED to light up the brine well? It's most likely a damaged control board that's creating your problem. You'll have to contact Sears for a replacement.
(EcoWater Systems LLC is the OEM [Original Equipment Manufacturer] of water softeners for Sears Kenmore, GE, Whirlpool, Morton Salt, EcoWater Systems dealers and a few others.)
Sep 03, 2016 | Water Dispensing & Filtration
My water softener last recharge on time, but keep going none stop, I pull out the electric power it is same problem.
There is a problem with your softner,if softener is equipped with bypass valve ,should say push to bypass,push the bypass valve in,unplug the unit , call the customer service number on the unit. Nothing more you could do.
Mar 03, 2015 | Water Dispensing & Filtration
Water is coming up in fabric softner cup during rinse time front loader
this is normal
water should go thru the softner and into the drum when the machine rinses to introduce the softner to the drum
Dec 05, 2014 | Kenmore Elite 45986 Front Load Washer
Why does my kenmore ultrasoft 250 keep shutting off
It i s possible he door switch if front loading, has a broken housing. If it works sometimes but then out out of the blue it is very likely the door closed switch plastic housing is broken.
Sep 15, 2014 | Washing Machines
Water softner water tastes salty
Possible that you need to use another type of softener if the water used is pretty hard.
please check for alternate softners from www.espares.com
Jul 02, 2012 | Kenmore Washing Machines
Washing machine faberic softner try fills with water when in use.
hot water valve inside unit may be faulty ck it to make sure that it is powering up and then make sure it is operating. the cold and hot valve are one unit on most washers so the unit is replaced as one. if its a front loader than there might be a one way ck valve malfunctioning or the unit keeping intoducing water into the unit even though it is at the level it should be at. top loader then the level sensor is jacked and needs replaced.
Jun 12, 2009 | Frigidaire GLTF1670A Front Load Washer
MISSED RINSE on culligan softner
the unit number one needs to be reprogrammed by a professional only it is tricky and ck the motor in the unit this controls the valves turning and water direction control.
Apr 29, 2009 | Culligan Sediment Water Filter
Rusty water after installing a water filter?
Leave it like it is. Unless you had sand coming through your water. The softener will regenerate and rinse alot of what your filter would plug with down the drain,
Please rate this response and Good Luck, Phil
Oct 21, 2008 | Plumbing
NO FABRIC SOFTNER
The fabris dipencer hose was clug need to remove hose , clean w/ stick not so tight rinse w/ water then assemble .
Jan 09, 2008 | Kenmore 43142 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
316 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
