Question about GE Cooktops
GE gas cooktop with 4 burners, shut off,started firing all 4 ignitors by itself.Had to shut off electrical power to the unit. Please, help.
    Guru:
  • 630 Answers
Sounds like a typical case of replacing the ignitor module.
Open the cook top and visually inspect all the porcelain elctrodes for breaks and crud build up etc. be sure the power is off...if all looks fine replace the ignitor module.
Posted on Aug 08, 2010
I have ge jgp337 . My gas stove started ingniting without turning the burners on and all flame started coming out from all 4 burners. i switched off the electric switch now even after 2...
I've seen this problem before. It happens when spillage get's into the ignitor switches. The switches are mounted on top of the gas turn-on valves. You have to replace all the ignitor switches because they are connected into wire harness. Rich
Aug 15, 2010 | GE 30 in. JGP337 Gas Cooktop
Burner shuts itself off after 10 0r s minutes of working normally
this unit has a gas coil controling the valve . and wen it gets hot it is failing and cannot keep the gas on . replace the valve coil // mm
Jul 12, 2010 | Thermador PC366BS Stainless Steel Gas...
What causes gas igniter to keep clicking when gas is off
Just solved this on the Kenmore model 911.33389 (same unit). Ignitors started with no one touching the cooktop. It has had a history of doing this and, this time, sparks were visible under the knob. Disassembled cooktop (don't forget to unplug and shut off the gas!). Performed "smell test" for burned electronics. Found smell in #3 ignitor switch. Disassembled and found worn, burned, and fried. Parts list was inside unit but had a typo for the "ignitor switch". Showed WB18T10240. Ordered that only to discover it was the transformer to ignitor wire harness set (no photo on website!). Wrong part... ugh! Dug deeper for the correct part #. It was WB18T10239 but it has been replaced with WB18T10344. Noted on some website that someone installed one and then the ignitor was NOT synchronized. Turns out, you can install WB18T10344 about three different ways. Mine was 22 degrees off vertical (different than original) and now my unit works perfectly! Also, install the new switch harness (if that's what you do) starting from the left front valve then clockwise. The original unit installed from the right front valve, then clockwise. Hope this helps.
Jun 20, 2010 | GE Profile JGP636 Gas Cooktop
Ignitor does not click
there is no "ignitor" as you would find in an oven or dryer. There is a sparkmodule that many times goes bad after 5 to 8 years. It is a plastic box about 4 to 6 " x 2" wide and wil have 3 to 5 wires or 3 to 5 terminal connector points on it. remember to unplug the range top fromwall electric. these units are not difficult to replace; they are not repairable, you have to buy a new one.
Apr 28, 2010 | GE Profile JGP636 Gas Cooktop
Gas cooktop starter continues firing
Turn your gas valve on, but leave your unit unplugged for a few days. You can light your burners in the meantime with a lighter so you can cook. Usually this problem is caused by moisture getting into one of your ignitor switches which are under your burner knobs. Most of the time the switch dries out and you can plug your unit back in after a few days. If it still keeps firing then you will have to replace one or more of your ignitor switches. Usually a very difficult job as most gas cooktops are now sealed burner units which means the top of your cooktop is bolted down to the burners with several screws or nuts that heat up with usage and become almost impossible to remove, without having to drill out the screws, or chiseling off the nuts. Be careful of boilovers or cleaning around the knobs with too much water to prevent this from happening again. Also get a surge protector at least 2000 joules or higher to prevent damage to you spark module. Good Luck, Appliance Specialists
Dec 16, 2009 | GE 30 in. JGP336 Gas Cooktop
Dacor sgm304s, Ignitor constantly snapping.
under burner control knob broken plastic cam that operates switch.
Sep 07, 2009 | Dacor Preference SGM304 Gas Cooktop
Jenn-Air Gas Cooktop Model CVGX2423
you will need to contact your certified local service tech.you might have a distributor problem at yor ignitor box.if the problem is not with your ignitors.
Jun 30, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Cooktops Logo
Top GE Cooktops Experts
Marvin
Marvin
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
