Question about Optoma Office Equipment & Supplies
In the middle of the TV forecast my optoma looses the signal and search for it a few seconds and then is ok, this happens over and over, it takes a few seconds to find it, this is really annoying! Thans for any help you nay provide on this
  • 89 Answers
Change the signal cable.
Posted on Aug 10, 2010
Why does my digitrex tv freeze at 19% when doing a digital channel search?
It would have been helpful if you had provided the model number of the combination unit. It is likely the channel signals are weak or there is some interference.
Try to use the manual tune option for a few main channels to see whether you are getting good signal. If the signal is ok then power off the tv at the mains and start again. I am assuming the TV antenna is external roof mounted.
Aug 07, 2014 | Televison & Video
Optoma hd65- componant signal OK but no hdmi signal found
whats the reason for no display on hdmi to hdmi connection- to the x box display is fine-?
Jun 25, 2012 | Optoma HD65 DLP Projector
Bushnell 7 day forecaster. My screen does not display information and says that the network is lost or in network - please wait 1 hour. It's been more than an hour it's been a few days. I have changed the...
I have a Bushnell 7 day forecaster for about 10 years I love it . Suddenly one morning it lost its signal and no matter where I placed it I would receive a message from the unit no signal found try another location . Loosing my owners manual IN THE BACK OF THE FORECASTER AND THERE IS A SMALL RESET BUTTON ON THE BOTTOM I TOOK A SMALL PIN AND PRESSED THE RESET BUTTON AND IT WORKS PERFECTLY now Hope this can help who ever has this issue , note the smaller five day forecasters do not come with a reset button in the back.
Feb 03, 2011 | Bushnell Measuring Tools & Sensors
The weather Forecast Icons don't change on my honeywell weather station model # TE852W
This problem could arise due to various reasons
1)Replace the batteries in remote sensors
When the batteries are properly installed, the remote weather sensor will resume sending signals to the main unit.To enforce an immediate remote signals search, press and hold
DOWN on the main unit.
2)Remote thermo-hygrometer sensor could be weak in sending the signal about weather Forecast.Test it properly.
3)Reset the unit and check
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 11, 2010 | Honeywell TE852W Weather Forecaster With...
OPTOMA HD70 projector turns off in a few seconds
my 3m projector turns off as soon as it is turned on
Mar 05, 2010 | Optoma HD70 DLP Projector
The colours on the screen are very dark and run into each other
This is an older model plasma and could be as simple as a loose cable, make sure you check all inputs, if it does it on all inputs including the ant/cable inputs then it is either a bad signal board or a problem on the Y or X board. if something is loose (bad connection) on one of the boards I usually take the back off and stand the TV back up with the stand rebolted to it. with the TV on and a picture showing gently tap the boards one at a time to see if something is loose. The signal board is in the middle lower section and has the ant screw in on it. the Y is middle left, X middle right when facing the back of the set.
If nothing is loose, there are some adjustments on the Y board that can cause blotches, dots, shading, color distortion. If you want to try adjusting them make sure to mark each ones position with a sharpy. Turn each slightly to see the corrective effect then back till you find the middle spot where the picture looks normal.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 16, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Black box in the middle of the screen
Very easy fix, The problem is you have the TEXT close caption ON. Just go into the TV menu and turn the close caption OFF.
Best regards
CircuitCity
Nov 28, 2007 | Samsung SyncMaster 710MP 17 in. LCD...
Searching for signal, component connection
  • the problem is in the system control section of your tv
  • it might be due to loose connection in that section
  • some components must have failed.
  • loose contact in any pin of system control ic.
  • good luck.
Oct 22, 2007 | Samsung DynaFlat TX-P3076WH 30" TV
Open Questions:
256 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
