Question about Vacuums
I have a kenmore vacccum model number 26512690 and I need to service the bearings inside but I can't figure out how to open the exterior case.
  • 1,673 Answers
Open the lid, push it all of the way back until it comes off. There 2 screws on the back cover, remove them, then using a pry, slip it under the cord return pedal and pry open to remove it, then there are 2 screws to remove, then the top cover will come off. You can go to, click on parts and put in your model number, click on vacuum, a parts list and picture will be there.
When you put in the model number, it is 116.26512690
Posted on May 01, 2008
Where can i find a manual for a Kenmore Power spray carpet cleaner model number 175.8099?
There are more numbers in the model number than what you posted and Sears parts site come up with 4 possibilities. I assume that you are looking for an owners manual rather than a parts listing and it looks like all they have is a parts listing. I will include a link to the page that lists all 4 models in case you are looking for parts. Model Search Results
Jun 30, 2015 | Kenmore Vacuums
How do I open the case on this hoover
If you cant figure out how to open it I wouldn't recommend you trying to rewire it, take it to a repair shop or ask your local friendly electrician.
Oct 19, 2014 | Vacuums
Kenmore cannister vacuum model 116.2411290 has begun exhausting a 'burned' smell. Suspect bad blower bearing. How to access?(Can't find manual online.)
Hi,how are you so sure the problem is from the blower bearing and not the belt,well to know if the problem is from the blower bearing or the belt you have to know how to access your vacuum first,so from all angle you need the manual You can download the manual of your kenmore cannister vacuum from this website; found it there Thanks and take care
Apr 01, 2010 | Kenmore Vacuums
Model 116 Kenmore vacuum cleaner. 20+ years old,
I believe that this is probably a Kenmore Canister vacuum cleaner, but I can't be positive. The model number 116 is just the first part, and all Sears vacuum cleaners start with model 116. There is a . after the 116 that will identify the vacuum. If you'd like me to be more model specific, or if this is an upright vacuum, please just request a clarification and I can take pictures even for you.
If this is a canister style vacuum, then you'll need to remove the foot pedal that rewinds the cord reel. There are 2 or 3 (depending on which model you have) hidden screws underneath of this pedal. You may simply pry off the pedal using a flat head screw driver. Also when you have the bag door open, you may just pull forward while it's open, and this will remove the bag door housing. There should be two screws in the front of the motor housing that need to be removed as well.
My guess from the age of the vacuum that's probably the motor that's gone. If this is the case, you probably can still get a motor if you'd like to just replace the motor inside, rather then buying a new vacuum. Typical Sears Kenmore canister motors sell for 79-120 dollars.
Again, I'd be happy to try and help you further, I will just need the entire model number after the 116. to know which vacuum you have.
If this was helpful, please click the 4 thumbs up icons in the top of the page. Thank you,
Chris J.
Mar 21, 2010 | Vacuums
Motor just stopped working
Kenmore Whispertone Model 26512690 PowerMate Brush motor does not run. The machine has no suction coming from the Power Mate Brush. However, I do have power in the main machine.
Jul 17, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore sweeper model 116-33919
Go to, click on the parts link, enter your complete model number, then you can click on the links for your vac and you can figure out what it takes, and you can order thru there also.
Jun 05, 2008 | Kenmore 31913 Progressive Direct Drive...
Need to replace power cord and can't find how to open canister to replace
I had the same problem and could not find the other screws. You need to pry off the power cord retraction button, you will find two more screws under there. It's pretty easy after that!!!!
Jun 02, 2008 | Kenmore 22612 Bagged Canister Vacuum
I am trying to remove the motor in my Kenmore canister vaccum but cant seem to figure out how to get it out.
Without the model number, I don't know which model you have. But you can go, click on the parts link, then put in you completer model number, choose the cannister or main unit, a parts list and a picture diagram will come up, you maybe able to tell from that how it comes apart. Or get me the model number for me to look at.
Mar 15, 2008 | Kenmore 22812 Bagged Canister Vacuum
How to open case??
I don't know this vacuum personally, but i'll take a stab at is. You're off to a good start prying around. There is most likely a coupld of screws holding things together somewhere. Check around the bottom and sides for holes where phillips screws may be lurking.
Hope this helps. Please rate this accordingly.
Feb 03, 2008 | Kenmore 22313 Bagged Canister Vacuum
Vacuums Logo
91 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
