Question about TORK 601A 24 Hr Mechanical Outdoor Timer 1 Grounded Outlet 15 Amps
HOW DO I SET THE TIMER, I WAS GIVEN THIS WITHOUT INSTRUCTIONS
Woods 49664/tm222a timer instructions
Try Googling (woods)(49664)(manual) without parens.
Mar 29, 2018 | Woods Hardware & Accessories
How do I set the timer?
Google (Stanley)(DR1212)(instructions) without the parens, of course
This approach got me instructions for a Stanley model 28442
Dec 21, 2015 | Stanley Hardware & Accessories
I have a question regarding the Intex Saltwater pump. If you cannot unlock the keyboard and set the salt timer will the plates on the ionization system still work or are they disabled unit the timer is set...
Must set the timer!!! It will not generate chlorine without setting the timer...
Try these instructions to unlock your timer and set the unit... If this helps, please rate the information.. Thanks and good luck!
Jul 23, 2011 | Intex Automatic Salt Water System for ...
I have a Woods 59336 time which was given to me without instructions. How do I set it.
Open following link to identify timer and download manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#59366
Instructions are same as 49522 shown below the 59366
You posted next to photo that looks like 59201 timer:
Open following link to identify that timer and download manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#59201
Add a comment if you need help with specific part of instructions, and add your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 29, 2011 | Woods 3C 24 Hour Indoor Mechanical Timer...
How to set the mechanical timer for Intermatic 600 Watt Low Voltage Transformer?
You can go to intermatic.com once you are on there page do a search for your model number, and from there you can download your instructions. Sorry that I could not given you more detailed instructions but with no model number this was as close as I could get you. Good luck!
Oct 03, 2010 | Intermatic 600 Watt Low Voltage...
Instructions on woods outdoor timer wth pins
go to Woods heavy duty timer and there is three tabs below the advertisement, one will say "specifications" and at the bottom of the tab page is instructions in green highlight. use the instructions given for pin timer , it works on earlier models as well.
Dec 12, 2009 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
TORK 601A  24 Hr Mechanical Outdoor Timer  1 Grounded Outlet  15 Amps Logo
Top TORK Hardware & Accessories Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
pawnpower
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
