Question about Cycling
Campy mirage 8sp cassette assembly instructions. In what order do the cogs go onto the rear hub?
  • bob_carr Aug 09, 2010
    wrong answer!!
    Brigadier General:
  • 8,546 Answers
Didn't you get it the first time? Largest first, then next largest....
http://branfordbike.com/page.cfm?pageID=60
http://www.parktool.com/repair/readhowto.asp?id=48
Posted on Aug 09, 2010
How to replace specialized hub
this could be several things, it could be the cassette on the rear hub, this can be replaced. I new cassette body cost's about $25 and up and most bike shops will charge about $15-35 to swap one out.
This could also be a worn out chain skipping on worn out rear cogs. A new chain and cogs is about $40-100 and $20-40 in labor.
Most bike shops can sell you a whole new wheel for about $45-65.
Your Specialized dealer or most any other local bike shop dealer can give you more details. Shop it around as prices do vary. If you want to attempt the repair yourself, it will require about $30-40 in special tools if you don't have them already plus the parts. This type of repair is not very common so it may not be worth the money to invest in your own tools.
Aug 20, 2014 | Specialized Crossroads
How to remove rear sprockets
most multi-speed bikes these days use Cassette rear hubs. The cassette is held in place on the hub via a lock ring that has some small teeth on the inside. Since there are many different brands on the market, you have to have the right cassette lock ring tool for your cassette. They cost about $10-15 each. You will also need a tool called a chain whip ($15-20) to hold the cassette in place, to prevent it from "free-wheeling" while you engage the lock ring tool to unscrew the lock ring. Once the lock ring is removed, the cassette will slide right off of the free hub body. Note that the free hub body has splines on it and the cassette can only be installed when all the inner teeth on the cassette gears line up with the splines on the free hub body. The first couple of cogs are usually loose, take care to note the order in which they are removed and their respective spaces so that they can be reinstalled in the proper order or else you bike won't shift correctly. Your LBS (local bike shop) will have all of these tools and most charge $5-15 in labor to remove and reinstall a cassette, some will do it for free if you buy the parts from them.
Oct 24, 2013 | Fuji Nevada 50 Mountain Bike Performance...
I changed the rear hub to a powertap now the Cassette is jamming when torquing the axle
First thing, count how many cogs you have, and then make sure the PowerTap hub cassette body (what the cassette slides onto) is made for that cassette. Some older hubs have cassette bodies made for fewer cogs. If it is the proper body for your cassette, make sure there isn't a spacer that is too thick underneath the cogset.
What is probably happening is that the cassette is out further than the outermost locknut on the axle and it's just coming against the frame as you torque the QR down.
Sep 10, 2013 | Cannondale Scalpel Carbon 2
Last season Shimano and several mail order houses said 'no problem' to using my existing Ultegra 6600 brifters with a 6700 SS rear derailleur (which would allow using the 11-28 cassette) Now...
The real question here is - are you having a problem and how can it be fixed?
Even full gruppos can cause users to ask us for adjustment advice.
OTOH, theoretically incompatible parts like Campi shifters and Shimano derailleurs can be made to work. I have several such pairings that work flawlessly. But then, I'm running 9-speed.
The thinner you go with cassette cogs the finer and less fault-tolerant everything has to work together.
As is attested to here: http://www.bikeforums.net/archive/index.php/t-623547.html
"AFAIK, there is no change to the RD's actuation ratio, so it should work."
http://cycle.shimano-eu.com/publish/content/global_cycle/en/nl/index/tech_support/faq_s/compatibility.download.-Par70parsys-0024-downloadFile.html/Road_charts_2009.pdf
http://www.parktool.com/blog/repair-help/rear-derailler-adjustments-derailleur
Sep 23, 2011 | Cycling
Hi, Repacking a Campy 8-speed cassette
Nice sticky grease might do the trick.
Jul 04, 2017 | Campagnolo Cycling
I have been given a set of Mavic NKSIUM Race wheels currently fitted with a Campag Cassette. Are these hubs Shimano compatable, as I want to fit a 8 speed Shimano Cassette Ian...
Nope. Campi and Shimano casette bodies are TOTALLY INcompatible, BUT I have had good luck with finding Campi casettes online (eBay) and having no interchange problems between my wheels and Shimano or Campi 9-speed shifters and derailleurs on several bikes. I switch wheels without concern for the other hardware.
http://desc.shop.ebay.com/i.html?_nkw=campagnolo+8-speed+cassette&_sacat=0&_odkw=campi+8-speed+cassette&_osacat=0&_trksid=p3286.c0.m270.l1313&LH_TitleDesc=1&_rdc=1
Within Campi there may be incompatibilities, though. If your wheels have an 8-speed Campi cassette now I think you'll be ok.
Feb 09, 2011 | Mavic Cycling
I have a Campy 10 Speed Shifter, running with SRAM S60 wheels, it causes some problems when upshifting
If you are running a SRAM or Shimano Cassette, then the spacing will be ever so slightly off. If you want to have precise clean shifting then you need to either replace the cassette body with a Campy one and replace the cassette with campy or get a 10-speed conversion cassette such as those from American Classic. Campy spacing on a shimano/ Sram spline.
The wheels in and of themselves should not make any difference.
Another trick for perfect shifting, make sure that your rear derailleur and shifter match - Campy to campy, Sram to Sram as examples.
Jan 02, 2011 | Cycling
Campag Chorus medium cage rear mech with 13 - 29 cassette
That's a 16-tooth spread in the rear. The cage can handle 36 teeth of chain length change including the front. That means your highest and lowest chainrings should be within 20 teeth of each other, but I avoid those issues by being careful to find a straighter chain line than anything near a cross-chain, typically not venturing more than one cog past the center opposite the chainring I use. That way I can actually use a shorter chain, too.
http://parktool.com/repair/readhowto.asp?id=64
Read up on the B-screw adjustment
Jun 07, 2010 | Campagnolo Chorus 10 Speed Short Cage Rear...
I have a Campy cassette set on my Cannondale. Lately, there has been an intermittent clicking noise coming from the rear wheel when pedaling. Nothing appears to be hitting the wheel. Also, at speeds above...
Clicking noises are commonly bearing problems but may occasionally be loose pedal cranks. If rear cassette isn't free wheeling properly sounds like a free wheel bearing is defective. I don't know your Campy - mine are all Shimano - but you should be able to replace the free wheel assembly OK as a separate service item. Mind you if it's of an age to demolish a bearing you should also be checking the gear teeth and chain for wear.
Nov 21, 2009 | Cycling
Clueless
The rear cassette is only a part of the solution. The front gearset also comes with a variety of ring/teeth configurations.
Plenty on new bikes come with a 'compact' gearset (2 front rings, 10 speed rear cassette). That is generally a lower gear ration to aid in hill climbing.
The rear cassettes are easily interchanged (must be same brand as what the hub uses). Of the 3 you listed; the 11-26 would be "Fastest".
If you want to go fast, and are fit enough to power it at speed for a good duration... look for a large crank ring (greatest number of teeth) and a small cassette # (like the 11-26 you listed). It's a sinple ratio calculation. What you're looking for is the most amount of rear wheel rotations per crank rotation. That is achieved by a big (lots of teeth) front ring and a small (not many teeth) rear cassette ring.
While at the bike store, put the bike in it's highest gear (biggest ring on the crankset, smallest ring on the wheel cassette). Lift the rear wheel off the ground and count the amount of rear wheel rotations for 1 crank rotaion.
A triathalon/time-trial bike will come with a ratio of about 5.5-6.5 rotatotions of the rear wheel for each rotation of the crank.
An endurance road bike (with compact gearset) might come with about 4.25 rear wheel rotations for each crank rotation.
Tri/TT bikes are made to put the rider in the most areodynamic position possible thereby reducing the wind drag and making pedaling easier (so you can manage a higher gear ratio). Endurance road bikes are designed to put the rider in a confortable position (more upright) for all day riding.
Get the bike shop to fit you properly to the bike you choose, not all shops offer this. There are professional bike fitters that can help you when you get close.
Hope that helps
Apr 30, 2009 | Sram 850 8 Speed Cassette 11-32t Mountain...
Cycling Logo
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
