Question about Garden
I can start my line trimmer and t idles fine but when I try to accelerate the motor ( pull the trigger , the engine stops. Can you shed so light on what may be wrong? Ian
  • 252 Answers
Have you checked for blocked muffler screen or exhuast port/ muffler
2 stroke wil idle sometimes with blocked/ restricted ex port / muffler
then just go burrrrr if try to pull more revs
no exhaust out , no fuel mixture gets in basically not breathing
have you checked fuel filter and fuel lines ?
tried new plug?
try blocked ex port and muffler 1st
cheers
Posted on Aug 08, 2010
Rough idle/ not accelerating/coolant leak
Rough Running Engine - James on Engines #2 - Bell Performance
https://www.bellperformance.com/blog/rough-running-engine
Apr 21, 2015 - When diagnosing an engine with a rough idle, there are certain things that must be ... If the problem does not reoccur, the codes will be erased by the computer. ... when accelerating the vehicle, which causes a higher fuel demand. .... it was water in gas...added added Gas LineAntifreeze/Water Remover.
Mar 17, 2017 | 2000 Ford Focus
Km90 starts but won't run on full revs
The KM90 is a 4mix engine that has valves. You may need to check the valve clearance, using the clearance tool.
Aug 28, 2012 | Stihl Used Km 90r Km90r Pole Hedge Trimmer
I can get my trimmer started but when I try to accelerate the trimmer from idle it stops
sounds like typical carburator issues.Pull carb apart and clean jets if it idles than slow jets are good so its more than likely your high idle jet.
Jul 17, 2011 | Troy-Bilt Garden
I have owned my Model 224L Trimmer less than 60 days, last night I tried to use it and the trimmer head would only engage occasionally. It would start to spin then disengage, even when I had all the right...
It sounds like a warranty issue, up at the engine you have a centrifugal clutch bolted to the flywheel, as the engine speeds up the clutch expands and engages with the drum, this in turn rotates ans turns a flexible shaft within the tube, this engages into the gear box and turns the gears that turns the head, so i would say the flexible shaft is either slipping in the drum, or the tube or gearbox has moved out board so is now too short to engage into the drum.
Jun 14, 2011 | Husqvarna Garden
Johndeere c1200 weedeater
Clean air filter and check fuel lines for trash.If that isnt the problem your carb may have trash in it.Thanks for asking and I hope it helps.
Jul 16, 2010 | Garden
Starts fine but when I pull the trigger the engine stops.
There are two screws on the side of the carburettor, H & L, if it is ticking over all right don`t touch the low (L) screw but slowly adjuse the high (H) screw in or out a wee bit until it runs. Stephen.
May 07, 2010 | Craftsman 25cc Gas Line Trimmer
Engine starts but dies when I pull throttle trigger
you need to adjust the high speed needle turn it out in 1/4 increments as you throttle it, low speed may have to come out alittle but do high speed first. I had to answer this as I use to have a pastor john in sturgeon bay, miss him alot.
Jul 22, 2009 | Ryobi Garden
I have a TB425cs that won't accelerate. It will
try adjusting the mixture screws out a bit if any otherwise it will need a diaphram kit
Jul 16, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
