Question about Samsung RB215LASH
Ice maker hooked up for the first time doesn't work.
  1. Water comes from water pipe, usually with a shut off valve (open??).
  2. Yes
  3. Fridge has a small filter (for sand etc.) at inlet. (not clogged??)
  4. No
  5. Water travels to solenoid valve, and waits for request. (do you hear it click when water requested??)
  6. No
  7. Water usually goes to a fine filter..(these fail (plug) quite regularly).
  8. Water goes through storage in back of cool section (Inside fridge- is it full of water?).
  9. I can not find any water storage area in fridge or freezer.
  10. Water goes to ice maker on fill request.
  11. ?? Is the power switch "on" (to icemaker)??
  12. Yes
  13. ?? Is the full / stop filling paddle/bar up?
  14. No
  15. ...ask me more questions
  16. Where exactly is the storage?
  • 121 Answers
Hi, The storage is usually on the back fridge wall near bottom. Your answer indicates the demand solenoid is not operating. You will need to check wiring connection at the solenoid, and at the ice maker plug. Best of luck.
Posted on Apr 27, 2008
Ice maker stopped filling with water
where the tube (water supply)cumes into the ice maker inside the freezer may be froze shut /locate it and see if it is use something small to open it up easy!
Apr 10, 2013 | Kenmore Refrigerators
Do i have to hook up my refrigerater to the sink to get water an ice
Yes you have to connect the water pipe from sink to refrigerator back.hen turn ON the water valve o run the water from fridge to freezer section.Form freezer section to water inlet valve at the back of ice maker.Then only ice maker and water dispenser will function.Other wise only freezer and fridge will work.-------------- If you dont have water tube and water valve then You can get required parts from www.repairclinic.com or from online sears part site. If you are not aware of how exactly to set and connect water valve and water tube then local plumber or fridge repair technician can do it for you.Its not at all hard job and can be easily done.It will take near to 15 minutes to connect all parts.------------- Thank you.
Jan 31, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Maytag side by side with water dispenser and ice maker doesn't work. We bought a house - never lived in - and the fridge and freezer work fine. We replaced the water filter and find that no water comes...
The sadle valve is located on the copper pipe where the tube attaches to your water pipe in the house. Shut the water off at the saddle valve. Remove the hose from the rear of the frig on the water inlet valve and put it into a pail. Tunr the water on at the saddle valve and see how fast the water comes out. Some times if the saddle valve is installed on the bottom of the copper pipe they will get corrosive and restrict water flow. Open and close the valve several times to make sure it is clear and reinstall the hose to the rear of the frig. Turn the water back on to see if it works.
Dec 29, 2009 | Freezers
We have a Maytag MSD2754ARA refrigerator and heard water leaking under it last night. We checked and it is coming from the line connected to the icemaker. The line inside is frozen solid. I have read that...
You'll need to first defrost/thaw the freezer and the water line in order to get water flowing again. This can take some time, so you might want to shut off the ice maker by lifting the ice maker bin arm, which will stop it from cycling/calling for more ice to be made.
You can try to thaw the line by using a household hair dryer, but unless you have only a small area of the water line frozen, it could take some time. That is why it is best to empty the fridge/freezer and keep the doors open and the unit off to allow for a complete defrosting of the unit. Have towels, sponges and buckets handy to get all the water.
It sounds like it could just be the frozen water line, but until you thaw it out, you can't really determine if that's all it is.
Jul 13, 2009 | Refrigerators
ICE MAKER NOT MAKING ICE, WATER NOT FEEDING INTO ICE MAKER
you may have a frozen inlet tube coming in to the ice maker. This is caused from a bad water valve and you would need to replace the water valve.
Apr 02, 2009 | Frigidaire Freezers
Ice maker has quit ,had this one put in after only six months ,and now this one has quit.
  2. Fridge has a small filter (for sand etc.) at inlet. (not clogged??)
  3. Water travels to solenoid valve, and waits for request. (do you hear it click when water requested??)
  4. Water usually goes to a fine filter..(these fail (plug) quite regularly).
  5. Water goes through storage in back of cool section (Inside fridge- is it full of water?).
  6. Water goes to ice maker on fill request.
  7. ?? Is the power switch "on" (to icemaker)??
  8. ?? Is the full / stop filling paddle/bar up?
  9. ...ask me more questions
More likly than not- it has just frosted up and needs manual defrosting, or the water filter is plugged (assuming the cold water dispensor is slow)
Apr 22, 2008 | Refrigerators
Ice Maker
Apr 21, 2008 | Whirlpool ED5FHEXMQ Side by Side...
No water for ice maker or at door
  6. Water goes to ice maker (door) on fill request.
  7. For Ice maker:
  8. ?? Is the power switch "on" (to icemaker)??
  9. ?? Is the full / stop filling paddle/bar up?
  10. ...ask me more questions
  11. In your case the solenoid valve or more commonly the filter need to be replaced
Apr 21, 2008 | Refrigerators
Ice maker not making ice whirlpool gold side by side
Water leaking
Tarena, it's been my experience with Amana that tells me you have a failed water inlet valve.
Here's how it works; Water comes from the wall into the fridge to the valve I'm talking about. Now this valve works like this... When you put a cup in the dispenser area to get cold water a switch sends 120 volts to the valve and it opens up allowing water to flow through it. When you remove the cup, power is shut off at the valve... the valve is supposed to close all the way, if it didn't there would be water dripping from the dispenser area, right? (Like a leaky faucet) If the valve is bad, it won't open at all. (Like a blown out light bulb)
The ice maker is similar. When it "harvests" ice and it drops into the ice bin, the IM will send 120 volts to the valve (for 5 seconds or so) to re-fill the ice mold so it can make another batch. Now when the power is removed from the valve, it's supposed to shut off all the way. If it didn't, there would be water dripping into the ice maker fill tube (in the freezer behind the ice maker). drip, drip drip... one after the other.
Let's assume that the ice maker valve didn't close all the way. What would happen then? As these drops of water enter the freezer compartment and are heading down the ice maker fill tube toward the ice maker, they don't make it all the way 'cause they FREEZE in the tube! One drop at a time, week after week. ('course you never notice it, 'cause it's in the freezer) Now... the ice maker is still trying to make ice, so every 45 minutes or so it sends 120 volts to the valve to get more water. But the water fill tube has ice in it because of the water drops that have accumulated there. This goes on over time and eventually the water fill tube becomes completely BLOCKED with ice due to those water drops.
Now what happens? The ice maker is still trying to make ice, but the fill tube is blocked... it can't get water through it. But when the water valve opens up to allow water to the ice maker, where does it go? Since the fill tube is blocked, all that water pressure builds up in the water line (tube) that feeds the ice maker and eventually it blows out! (you can verify this... pull the refrigerator out from the wall, look at the water line going to the ice maker. There's a connector back there for the tube to fit into. This is what's blown out.) Now the tube is just dangling there and not hooked up to the ice maker any longer. Since the ice maker is still running, every time it asks for water it sprays out and onto the wall and floor back there through this dangling tube.
The repair? Replace the valve. It's easy. The part number is 67005154 and it lists for about $21.00. You can find one at any appliance parts retailer. (you'll see where the valve is located... it's where the water line hooks up behind the fridge.) UNPLUG YOUR FRIDGE WHILE YOU WORK ON IT!!!
Just replacing the valve is only half the job. You'll still need to remove the ice build up in the ice maker fill tube. Do this by pulling it straight out the back of the refrigerator and putting it under warm running water. Then re-install it and hook the water tube back up to it.
On some models, you can not remove the fill tube. If you can't get it out the back, you'll have to do it from the freezer compartment behind the ice maker (a little more work, but still do-able). It's easiest by removing the ice maker.... pull the ice bin out and set it aside. Then remove the 3 screws holding the ice maker. You don't have to disconnect the wires, just try to get it out of your way the best you can. Now take a hair dryer and thaw out the fill tube until the ice slides out of there. Then rebuild it.
There ya go! Job time? about an hour. Part cost? about $21.00. Knowing that you fixed it yourself? Priceless.
Oct 14, 2007 | Amana ACD2232HR Side by Side Refrigerator
Samsung RB215LASH Logo
138 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
