Question about Sony KDF-E50A10 50 in. LCD HDTV
SONY KDF-E50A10 SHOWS VIDEO, SCREEN GOES BLACK, LED FLASHES, AFTER ABOUT THIRTY SECONDS VIDEO RETURNS. REPEATS THIS OVER AND OVER. ??
  • cwessonilove Aug 09, 2010
    silverdragon said alot about nothing. i already know their's a problem. i'm looking for a solution. someone knows what circuit board is the most likely culprit. power supply, input, lamp? i have seen posts similar to mine so somebody has found a fix and i just want to know what it is. tv is on, screen goes black, led flashes, after about thirty seconds tv comes back on. this repeats over and over.
  • 4,889 Answers
Sounds like a fault on the main audio/video board. How many times does the LED flash when the screen goes off? Also is sound affected too? Does it happen on all input sources(DVD, Cable box etc.,). Please answer these questions so that we can continue troubleshooting.
Sai.
Posted on Aug 09, 2010
  • 3 more comments
    I replaced the main A/V board already. When the tv screen goes black the power/standby led blinks continously until it powers itself back on after about 30 seconds. Yes audio is affected also. It's like the tv powers off then back on by itself.
  • eagle338
    eagle338 Aug 09, 2010
    Any clicking noise when the unit powers off?
  • cwessonilove Aug 10, 2010
    no, it just powers down then back on. over and over
  • eagle338
    eagle338 Aug 10, 2010
    SOunds like a problem with the power supply board. But I want to be sure that it is that. Do you know how to use a multimeter to measure voltages at certain points?
    yes i do. i have been a tech for thirty years. telephone and security systems, so i am familiar with electronics but not specifically tvs.
  • Sony Master
  • 12,061 Answers
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it, they, may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. T What is happening is that you have a fault in the set, that is potentially very bad, and the Power Supply senses this and attempts to shut it down, now when it shuts down, the fault clears momentarily, and so the PSU, again tries to power up, sense the fault and tries to shut down again, we call this a Hic-upping Power Supply, and is often the symptom of a much larger underling problem. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of only a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
Posted on Aug 08, 2010
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
Sony KDF-E50A10 Power Up Problem with Display
yes it possibly lamp ballast board is faulty
Oct 13, 2012 | Sony KDF-E50A10 50 in. LCD HDTV
Turns off after 2 or 3 seconds then red light flashes 4 times
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Keep us updated.
Dec 22, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
I got a 50" sony model KDF E50A10 I got a new lamp bout i sill get 3 red flashes
3 red light flashes shows that lamp cover has not been fixed in its place as it is first plastic cover that was removed from tv cabinet to replace lamp in tv.
Make sure lamp cover is back in its place securely.
Sep 18, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Turns off/on every few minutes
I would replace the Lamp. This is a common symptom when the Lamp is failing.
I hope this helps,
Skyassoc
Oct 30, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Sony KDF-E50A10
Have the Ballast (power supply to the lamp) replaced.
Jun 23, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony KDF-E50A10 50 in. LCD HDTV Logo
78 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
