Question about Oreck Cordless Speed JP8100CA Iron
I have described my problem repeatedly. Again - My Oreck Cord-Free Steam Iron JP8100C series stopped heating
  • 12,061 Answers
Ok whenever an iron stops heating it is either the Thermal Fuse,or the Element or the actual temperature control. One would have to use a meter to check the Voltage at the element of the iron. & Test the Thermal Fuse.
Also though with Cordless irons it may simply be that your batteries aren't working as they should. They can quickly be ruined if not charged correctly.
I do NOT think, that this is a job for a home repair due to the added complexity that the batteries add.
You need to take it to a professional repair center and ask for a "Quote" before allowing any repairs to proceed. As the cost of repair may exceed the cost of a new one.
Posted on Aug 08, 2010
I have a MR jet stream it's making all the right noises, but no steam, the small pump seams to be working it makes a noise when I trigger the button iron gets hot...but no steam.
Try adding vinegar to the iron to dissolve any built up mineral deposits inside the steam passages. Put the vinegar in place of water, heat the iron and let it sit for 10 or so minutes. Dump out the vinegar and put water back in the iron and heat again. if the water starts sputtering out the steam holes, then repeat the process a few times to clear the passages.
May 27, 2018 | Irons
The green light does not come on and it does not steam
follow this adjustment and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in wa
Nov 04, 2013 | Oreck Steam-It Steam Wand
My Oreck Cordless iron stopped heating. The "Heating" light on the iron lights, but there is no heat.
Check and test this possible fault:
- Blown fuse
- Faulty or broken thermostat
- Broken power cords
- Broken heating elements
Hope helps.
Apr 20, 2011 | Oreck Cordless Speed JP8100CA Iron
My oreck cord-free is a JP8100c series. I have had this iron for years and really like it. just recently it will heat for a second or so than the light goes off, I tried holding the reset button and I...
Good news and bad news.
The good news is I found a website with your iron model and the parts, however, the bad news is that the manufacturer decided to discontinue the base the part that heats up your iron. But, if you would like to purchase another one, eBay and Amazon have some great deals. Just in case you want to contact the website I previously mentioned the # is 877-346-4811. Or you can go to ReplacementParts.com. I hope that you find what you're looking for.
Sep 26, 2017 | Oreck Cordless Speed JP8100CA Iron
My iron will not heat when plugged into to the wall socket. Tried different places. Light comes on but won't heat. press to reset light stays on.
try opening the iron and see if the wires are connected to the thermostat/heating element, if not you can easily tie them again, it sometimes happens when the thermostat fails to open the circuit and the heating elements over heat and causes a break in the line or heating element.
Feb 07, 2010 | Oreck Cordless Speed JP8100CA Iron
My iron is filled with water but won't steam - why?
No heat ! It's probably an electrical problem. If the electrical cord is connected to the iron properly, then it's probably one of the swithes to the iron.
Oct 07, 2009 | Oreck Cordless Speed JP8100CA Iron
Oreck Cordless Speed Iron
Try an Oreck store or customer service.
If not I would suggest Ebay or something of the sort that would have odd and end parts
Sep 06, 2009 | Oreck Cordless Speed JP8100CA Iron
Brown spots coming from steam iron
Fill with 50/50 water vinegar solution. Get it good and hot and let it sit for two hours. Rinse and repeat if necessary. Buy a gallon of water from the market and use that from now on. This will fix your problem. The Iron is concentrating the iron in you water and this is what is causing the brown spots. Hope you find this helpful. If you do please take the time to rate it fixya and maybe I will keep helping people for free.
George
Jun 23, 2008 | Oreck Cordless Speed JP8100CA Iron
No steam when ironing and no burst steam
bad connection to heating coil. Not worth fixing.
Nov 03, 2007 | Oreck Cordless Speed JP8100CA Iron
Oreck Cordless Speed JP8100CA Iron Logo
637 people viewed this question
Top Oreck Irons Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you an Oreck Iron Expert? Answer questions, earn points and help others
