Question about Oreck Cordless Speed JP8100CA Iron
My Oreck cord-free steam iron JP8100C Series quit heating. I think it could be the Power Unit. Is it possible to replace that part of the iron?
SOURCE: Iron not heating up...
I had the same problem. There is a thermal cut-off switch mounted to the top-side of the base-plate. Unfortunately, you have to completely disassemble the iron to get to it. It is an easy replace, just make sure you take good notes on how it's all wired and put together. To disassemble the iron, I did this:
- Mount it in the cord base and move the switch to the "wireless" setting to remove the cord assembly from the iron.
- There are 2 small while nubs on the bottom of the blue plate in back. These are plugs. Pull them out to expose 2 screws.
- Remove these two screws plus the one in the center of the back blue plate.
- Pull the blue plate from the back of the iron and MARK all wires so you know where they go, then remove them.
- You will see 2 screws into the blue plastic base-plate at the back. Remove these.
- Open the door at the front of the iron where you pour the water in.
- Pry the spray nozzle at the bottom out (pry it forward). This will expose a third screw into the blue part of the base-pate. Remove this screw.
- Pull the white plastic and blue reservior away from the blue plastic base-plate. This will expose three screws into the metal bottom plate. Remove these three screws (on in front, 2 in back).
- Pull the blue plate away from the bottom metal plate. This will expose the thermal cut-off. There is a screw with a small metal clip holding it down. This is the part you will need to replace.
I bought my replacement part from a local electronics store. On mine, it was a 240 degree C cut-off. The part I used was from NTE. Part number is NTE8242. It cost me $1.40.
I suspect the reason this blew on my iron is because Oreck engineers didn't expect it to be plugged in all the time (my wife did not like the 'wireless' mode as it did not stay hot long enough so she uses it in 'corded' mode). If you use the iron on it's hottest setting in this mode, it appears that perhaps the plate gets hotter than 204C. That, or Oreck just got a lot of bad thermal cut-off parts and they are cutting off at a temperature lower than 240C.
Posted on Aug 03, 2009
  • 9 Answers
SOURCE: Oreck Cordless Speed Iron
Try an Oreck store or customer service.
If not I would suggest Ebay or something of the sort that would have odd and end parts
Posted on Sep 12, 2009
  • 403 Answers
SOURCE: my oreck iron does not heat up
Looked at several solutions, I think your best bet is to copy and paste this link below into your browser. It is a manual for your oreck iron. There is a number for support for your product.
http://www.oreck.com/includes/customer-service/owners-guides/pdfs/40188-01-TRAVEL-IRON-STEEMER.pdf
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Posted on Sep 30, 2009
SOURCE: I have described my problem repeatedly. Again -
Ok whenever an iron stops heating it is either the Thermal Fuse,or the Element or the actual temperature control. One would have to use a meter to check the Voltage at the element of the iron. & Test the Thermal Fuse.
Also though with Cordless irons it may simply be that your batteries aren't working as they should. They can quickly be ruined if not charged correctly.
I do NOT think, that this is a job for a home repair due to the added complexity that the batteries add.
You need to take it to a professional repair center and ask for a "Quote" before allowing any repairs to proceed. As the cost of repair may exceed the cost of a new one.
Posted on Aug 08, 2010
  • 102366 Answers
SOURCE: HOW CAN I OBTAIN A MANUAL FOR MY ORECK CORDLESS
You can download the manual from the manufacturer's web site at
http://www.oreck.com/PUG/IRONMANUAL-JP8100.pdf
Posted on May 03, 2011
Philips 6104 duble speed
follow this test and fix it. God bless you
As with many small appliances, regular maintenance makes a dramatic difference in how trouble free your electric iron will be. Even so, things can happen.
If the iron doesn't heat, make sure power is on to the outlet, check the power cord and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber
If the iron produces too much or too little heat, test the power cord Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Nov 29, 2013 | Philips HI-296 Iron
Straightener nano silver
please make this revision and fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the power cord , and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the power cord. Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle (see below).
Nov 29, 2013 | Irons
My Oreck Cordless iron stopped heating. The "Heating" light on the iron lights, but there is no heat.
Check and test this possible fault:
- Blown fuse
- Faulty or broken thermostat
- Broken power cords
- Broken heating elements
Hope helps.
Apr 20, 2011 | Oreck Cordless Speed JP8100CA Iron
My oreck cord-free is a JP8100c series. I have had this iron for years and really like it. just recently it will heat for a second or so than the light goes off, I tried holding the reset button and I...
Good news and bad news.
The good news is I found a website with your iron model and the parts, however, the bad news is that the manufacturer decided to discontinue the base the part that heats up your iron. But, if you would like to purchase another one, eBay and Amazon have some great deals. Just in case you want to contact the website I previously mentioned the # is 877-346-4811. Or you can go to ReplacementParts.com. I hope that you find what you're looking for.
Sep 26, 2017 | Oreck Cordless Speed JP8100CA Iron
I have described my problem repeatedly. Again - My Oreck Cord-Free Steam Iron JP8100C series stopped heating
Aug 08, 2010 | Oreck Cordless Speed JP8100CA Iron
My iron is filled with water but won't steam - why?
No heat ! It's probably an electrical problem. If the electrical cord is connected to the iron properly, then it's probably one of the swithes to the iron.
Oct 07, 2009 | Oreck Cordless Speed JP8100CA Iron
My oreck iron does not heat up
JimmyC
Sep 30, 2009 | Oreck Cordless Speed JP8100CA Iron
Sep 30, 2008 | Oreck Cordless Speed JP8100CA Iron
No steam when ironing and no burst steam
bad connection to heating coil. Not worth fixing.
Nov 03, 2007 | Oreck Cordless Speed JP8100CA Iron
Oreck Cordless Speed JP8100CA Iron Logo
368 people viewed this question
Top Oreck Irons Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you an Oreck Iron Expert? Answer questions, earn points and help others
