Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
The cable receiver broke, how complicated to fix it?
    Top Expert:
  • RCA Master
  • 14,553 Answers
This model uses a tuner which is flat on the signal board---board would have to be removed to replace the fitting--NOT A DO IT YOURSELF type of repair.
A viable option is to use a cable box (or satellite etc) and input it into one of the Audio/ Video inputs on the back of the set---this bypasses the cable fitting.
If you do not have cable etc---get a old vcr (it does not have to be able to play a tape etc---connect your signal to the unit and use its Audio and Video outputs to input into one of the A/V inputs on the TV---
If you cannot fix it get around it---I have 30 years of experience and if I was to fix this cable fitting I would estimate the repair between 100 and 200 dollars (almost all labor).
Let me know if you have questions as I am here to help and would appreciate your rating my help.
If you want help press the "add a comment" button.
There has been some trouble on this site lately where I do not see the comment; if this happens email :"support@fixya.com" and tell them you want them to contact me for the instructions.
The other option is you can also email "Lauren@fixya.com" who is the community manager here.
If the site does not notify me of your response I cannot get the FREE information to you.
Regards, SD TECH
Posted on Aug 08, 2010
I have a kenwood dnx7200 it's just started saying broken cable connection please confirm connection how do I fix it
This unit is a upgrade/replacement for vehicles that have a dash configuration big enough to accommodate it? Who did the installation? And was the proper adapter cables used to connect the Kenwood unit to the wiring of the host vehicle? This is a complicated unit to install, and is probably beyond the means of your average DIY-er, who has replaced a few car stereos, and thinks he is up to the challenge. Take it back to whoever did the initial installation, and let them diagnose the problem....I'd forget about fixing it yourself.
Oct 12, 2016 | Kenwood Car Audio & Video
AC inlet is broken on TX-SR875... How do I replace it?
A simple easy fix would be to hard wire it, solder a new cable in and secure it so it cannot be pulled out.
Feb 14, 2014 | Onkyo Audio Players & Recorders
How to fix shifter cable on 2004 pontiac montana van
order a new cable! if it's actully broke! can't fix broken cables just have to put new ones!
Sep 03, 2012 | Pontiac Cars & Trucks
Where you plug in to charge is broke
Hi.
If you broke the lighter socket on car dash, replace it.
If you broke the cable replace the cable. Here the spare:Garmin Power Cables
If you instead damaged the power socket on your Garmin, call the Garmin number listed in the owners manual. The Sat Nav must be sent to Garmin for repair:Garmin ' Contact
Next time use a Suction Mount Windscreen Holder
Regards.
Ginko
Dec 15, 2011 | Garmin StreetPilot c340 GPS Receiver
How do I replace the flexible cable and where can I find a new one for the DEH- P6800MP
pioneer website,its a bit complicated not for the novice i broke 2 when i first learnt how to do them they are made not to replace
Apr 21, 2010 | Pioneer DEH-P6800MP CD Player
HDMI switching problems, ongoing, HDMI board has been replaced
Congrats? There's barely any information to go off of here, but assuming the receiver has broke multiple times, you need to contact Onkyo tech support and/or a better repair center to see if there is a different problem in the system. HDMI is a very complicated and annoying connection system. You should post your actual symptoms and components in your system along with how everything is connected and we'll have a better chance or narrowing down the problem, along with solving it.
Mar 11, 2010 | Onkyo TX-SR606 Receiver
Pioneer VSX-72TXV used to work but trying HDMI just broke it...
I fixed it myself. Didn't realize that I loosened speaker cables on the wall panel when I moved the receiver and two were touching...
Dec 10, 2009 | Pioneer VSX-72TXV Receiver
Driver side window not going up fully on my Audi A4 Cabriolet 2002, it eventually will go up by pressing the button gently. Sounds like a cable breaking or broke, but if so how is the window still able to...
There really is no cable. The power window runs on tracks inside the door, which is attached to a motor which is also inside the door. It's very tough to get to to fix it, lots of screws and you would need to take the door panel off. It's not something I even try to fix myself, and I consider myself very mechanically inclined. I have replaced a window motor once, and took a large chunk of meat and skin out of my finger in the process. Hope it helps. If you want to try fixing it yourself just know, it's VERY complicated.
Aug 09, 2009 | Audi Cabriolet Cars & Trucks
Rear door handle broke..is it a spring? where can I get a part
This happened on my parents 2003 Santa Fe. They paid a garage $250.00 to fix it.
Dec 30, 2008 | 2003 Hyundai Santa Fe
Sony STR-DE825 Receiver Digital "Noise"
Make sure you have fib/opt cables are securely inserted in right ports. Switch through "input modes" on front panel; opt, anal, auto. This unit is tricky and unecessarily complicated. Read through manual carefully!
Jan 28, 2008 | Sony STR-DE825 Receiver
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
