Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Screen is foggy and out of focus,blurry.. - Philips 60PP9202 60" Rear Projection HDTV-Ready Television
  • Philips Master
  • 1,229 Answers
You may have one of two possible problems here. First..you may have a contaminated tube. This means one of the projection tubes may have fluid that has become cloudy and must be replaced with clean fluid. This would take a bit of patience to do so. It is not easy. The second problem may be that the small signal module may need replaced. Do not confuse this board with the small signal board, which is a tiny board that sits on top of the signal board and easily snaps in and out. You want to repair or replace the signalboard that is located on the floor next to the power supply board [has the flyback on it]. It is the board that contains all the RCA jacks and RF connections, that you are concerned about. Please check the first answer. You will have to disassemble a bit to look inside the projection tubes as they are lit. Thanks for asking!
Posted on Aug 08, 2010
Why is my screen blurry and out of focus?
First-things first,
Check to make sure the lens is free of grit! When the lens becomes dirty, the image on your screen will be blusry and out of focus.
Aug 31, 2014 | Cameras
VIEW SCREEN IS SO BLURRY I CAN'T TELL WHAT ITS SHOWING.
Is it the viewfinder (that you hold up to your eye) or the screen that's blurry?
If the viewfinder is blurry, there should be a diopter adjustment to fix it, probably right above the rubber eye cup.
If the screen is blurry, you should take some pictures and video and view them on a computer. I they are sharp on the computer but blurry on the camera screen, there may be a problem with the screen and you may need to take it in for repair.
If the pictures are blurry on the computer as well, the camera may not be focusing properly. If you can't focus manually, or the camera can't focus when auto focus is turned on, you have good light, and aren't too close to your subject, then it may need to be serviced.
Feb 26, 2011 | Sony Cyber-Shot DSC-F717 Digital Camera
Canon rebel xt 1. image looks blury in eye
1. The viewfinder's diopter is probably out of focus (doesn't affect Auto Focus of photos). There's a dial and a +/- symbol next to the viewfinder. Turn the dial till you can see clearly through it. Alternative reason: The glass in the viewfinder is dirty/foggy. Use camera cleaning solution (a drop) on a cotton bud to clean it.
2. Malfunction needs Canon Service Centre to take a look at.
Dec 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Does not focus after "far" objects when zoomed to 50mm or more ...
  1. If your images suddenly start looking blurry or distorted, try holding your camera up to the light. If your lens looks dirty, foggy or greasy, try applying lens solution with a lint-free cloth . Move the cloth in a circular motion until the lens dries. Do not apply lens-cleaning solution directly to the lens.
  2. If your images are still blurry, check your shooting mode. If you are shooting closeups, make sure you are using the "closeup" mode. Try to get within 2 feet of your subject before you shoot the picture. images can look more blurry when you are a long way from your subject
hope this helps you please do me rate on this issue
Dec 23, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
The picture is blurry. does anyone have a solution to this or has anyone had a similar problem.
I have a blurry screen and the top of it the picture is curved a bit. I was told to adjust the focus knob but I don't know where that is in the back of the TV. I took off the back and couldn't find it. I also tried to adjust the manual convergence and the red would not adjust only the blue would align. Any suggestions.
Nov 05, 2008 | Samsung HCM422W 42" Rear Projection...
Re: CTX monitor getting blurry
Hi Beth,
Your focus screen network turn faulty. It can be solved by by passing the original focus screen network to a new assembled focus screen network.
Apr 08, 2008 | CTX PL 9 19" CRT Monitor
Whats wrong with my viewfinder?
I don't have my camera with me, so I may be off on the exact placement, and I hope I'm not telling you something you already know and the problem is worse, but on the left side of the viewfinder itself is a tiny dial that adjusts the focus. Just look the the viewfinder and play with the dial to adjust to your eyesight.
Apr 03, 2008 | Canon PowerShot S3 IS Digital Camera
Blurry picture
adjust the flyback focus of your tv
just look at the flyback and you can see there the focus and the adjusting for the screen.
thats only what i know at least maybe it can help =).
Sep 23, 2007 | Toshiba 57H83 57" Rear Projection HDTV
New PCB SUB - But blurry and color off.
have you tried to also adjust the lenses to fine tune the focus .
Aug 28, 2007 | Samsung HCL4715W 47" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
