Sediment in washing machine
Is it possible for sand to somehow come through the washing machine's water source and then be deposited in the bottom of the machine after the clothes are washed. It happened once or twice with our machine and i have no clue as to where it came from
abhishek33
  • 1239 Answers
SOURCE: Water leaking from my washer
hi sir Dishwashers are usually protected from overfilling by a float switch. This switch is located in the bottom of the unit. Here's how to check and replace it:Step 1: Open the door and remove the bottom dish rack. Check to see if the float valve is stuck. If it is, clean away food debris around the float. With a screwdriver handle, lightly tap the top of the float to free it.
thanks.................rate it
Posted on Sep 11, 2008
CRTN
  • 716 Answers
SOURCE: leaking
Sheets Or Comforters? This Normally Occurs With An Overload Such As Pillows And Comforters Due To The Large Circumference. Which Simply Means That Anything That Has A Large Area Will Make The Water Come Over The Top Because When The Machine Is Running The Spin Cycle The Large Area Of Fabric Covers The Side Of The Machine. Actually Causing Water To Spin Off The Top Of The Fabric And Over The Sides Of The Washing Machine Bucket Thus Ending Up On The Floor Below.
Posted on Feb 06, 2009
SOURCE: Maytag Epic Z washing machine F20 error
F-20 error code its water inlet problem (no water or insufficient water supply) check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Posted on Mar 16, 2009
SOURCE: Sediment in filter at back of washing machine
http://www.filtersfast.com/Washing-Machine-Water-filter.asp
Model Number 85470. $23 / 2 84470 filter repl = $15
Posted on Jul 08, 2009
SOURCE: machine browning clothes
I have the same prblem
Posted on Oct 13, 2009
Miele novotronic w918 keeps filling with water, whether turned on or off! Help!
Hello. Based on your symptom, I strongly suspect a defective inlet water valve if the power is removed and the unit keeps filling--that's your clue. Trash like sand or sediment might have somehow gotten past the fine water screens at the hot/cold hose connections and jammed the valve. Or, the valve(whichever one is allowing water in) could simply be defective. Now, if power is removed and the unit stops filling, I would be looking at the main control board as the likely culprit--probably a stuck relay on the board causing the issue. I hope this helps you.
Nov 07, 2015 | Miele Washing Machines
Cold water values not working can do a hot wash and can swop hot and cold hoses to do a cold wash on hot setting but cold values not activating
Hello. This is a Simpson washing machine, right? From the problem you describe, there might be an issue with the electric inlet water valve on the cold side. Do you get your water from a well or is it city water? If on a well, or if you've never done this, turn off the cold water to the washer and disconnect the cold water hose. Using a flashlight, look into the valve where the hose connects. You should see a very fine wire or plastic filter screen. Usually, they get clogged with sand or sediment and completely block the flow of cold water. The hot side isn't affected NEARLY as much due to the sand/sediment dropping into the hot water heater tank first before it continues on to the washer. CAREFULLY pull out the screen, BEING EVER SO CAREFUL TO NOT TEAR THE WIRE SCREEN OR CRACK THE PLASTIC VERSION. Rinse out the screen under running water and use an old toothbrush to help you. Make sure you have something blocking the sink drain to prevent the screen from accidentally falling in.(ask me how I know this) Carefully replace the screen--NEVER RUN A WASHING MACHINE WITHOUT THOSE FILTER SCREENS. The electro-magnetic valves will become jammed with debris very quickly.
If the inlet valve screen(s) are clear, then the problem is either a bad inlet valve or main board--check to see if there is voltage present at the connector when the valve should be energized. If it isn't, suspect a possible broken wire or a defective timer/control board. I hope I helped you!
Sep 04, 2015 | Washing Machines
How is a sedimentary rock made? what is it made out of?
  1. Sedimentary rocks are formed when sediment is deposited out of air, ice, wind, gravity, or water flows carrying the particles in suspension. This sediment is often formed when weathering and erosion break down a rock into loose material in a source area.
    google.com/+GopakumarGopalan
Dec 03, 2014 | Toysmith Sedimentary Rock Science Kit
What does E-13 mean?
Low water pressure.
If this is the error message your washing machine is sending, it may be caused by inadequate water flow. There might be something trapped in the water hose such as sediments or lime deposits. If you are using tap water, this is a common problem.
Remove any sediments or dirt obstructing the flow of water in the hose. Pull the sensor that is located n the inlet valve and check inside to see if anything is trapped.
Dec 07, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Where's my washer filter located on the washer?
Hello, it doesn't have a water filter. Now, there a screen on the hot/cold water valve side. It could be possibly plug from sediments front the city water source. GB..stewbison
Sep 12, 2011 | Kenmore Elite 45986 Front Load Washer
My cabrio digital washing machine quits after rinse cycle and says f1
Your F1 problem may not need any parts to remedy. Get inside the control panel and remove the water pressure tubing from that control. Blow out the sand and sediment buildup in the bottom of the tub. reconnect that hose and retry with an empty tub.
I have repair photos and a service manual HERE
Feb 04, 2011 | Whirlpool Washing Machines
Where do you put the filtration system if you want to eliminate all sediment from your hot water tank. Doe's it go before or after the softener and into the hot water tank?
There are two water lines connected to water heater.
One is marked Hot and the other Cold.
The shut off valve is on the Cold line.
To eliminate sand and dirt from entering your water heater, the 'sediment' filter should be installed on Cold line.
Sand and dirt are sometimes called sediment, but this type of sediment is not the same as calcium carbonate sediment that accumulates inside a tank that receives hard water.
When you have hard water, then water heater makes calcium carbonate 'sediment' deposits that accumulate in bottom of tank. A 'sediment' filter will not prevent this problem.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
If you have hard water, to prevent calcium carbonate from forming inside tank, you need a water softener.
Water softener will prevent calcium carbonate sediment forming inside tank.
However water softener will shorten life of water heater anode rod.
http://waterheatertimer.org/Replace-anode-rod.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater.
Jan 04, 2011 | General Electric GE SmartWater Household...
I have an error code FE. The washing machine will not unlock. there are towels in the machine and it will not spin.
FE overflow error. sand and sediment in the sump is causing the sensor pressure tube to not recognize water levels. Remove tube and blow it out to get the stuuf out the bottom of the sump is what I would try.
Jan 16, 2010 | LG WM-2277HW Front Load Washer
Is there supposed to be a sediment type material, like sand, in the drainage pump area right after the big black hose that comes off the bottom of the washer?
No, that's an accumulation of sediment from your clothes and/or your water supply.
The good news is that you can simply lower the drain hose and flush out the sediment accumulation. Then you can run another wash cycle with some cold water and try to get as much out as possible. If you can, you can disconnect the discharge hose at the pump body and flush it out by hand.
The issue is to figure out if you're getting all that sand from the clothes being washed or from your water source.
Sand will hasten the wear and tear on most any machine, so unless this washer is at a beach house, where you tend to get alot of sand in washers, by the very nature of towels, etc., you'll want to address this problem.
If you're on a private water well, you would be well advised to install a whole house water filter to help minimize the amount of sediment you're getting into your washer. If you're at a beach house, try to shake out the towels and other clothes before putting them in the washer to get as much sand out of them as possible.
Hope you find this Very Helpful and best regards!
Sep 25, 2009 | Washing Machines
Washing machine overfills
Grab the tube off the water level switch that comes from the bottom of the tub and blow it out so that the sand in the bottom won't be blocking the operation,pump out the water, secure the tube tightly to the pressure switch and retry.aff8f03.jpg
Jun 10, 2009 | Washing Machines
Washing Machines Logo
207 people viewed this question
Top Washing Machines Experts
