Question about Cakewalk Computers & Internet
No signal coming through from mixer. Record button is greyed out, not highlighted red, allowing me to record. Has worked fine on previous versions of cakewalk.
    Problem Solver:
  • 8 Answers
The new version of cakewalk is not compatible with your computer. Can you go back to a previous version that worked for you?
Posted on Aug 08, 2010
How do I record a series on my new Bush recorder, which button on the remode control is it?
Usually to record a series the epg, electronic programme guide, needs to be open. Find the programme you want to record and highlight it using the navigation buttons on the remote.
Pressing the record button at this point will set the system to record the programme but if it is a series a window should open asking if you want to record the series.
There are usually two buttons coloured red. One red button will be in a line-up of four coloured buttons. The record button is generally the other one.
Apr 28, 2018 | Bush Televison & Video
Why does my mixer take so long to select something from the menu and why does it freeze up?
Sounds like you need more ram or computer space. You didn't list what time of mixer or computer so can only answer basicly. If using a computer (which it sounds like) see how much the mixer needs andhow much space available on your hard drive. This is called a latency problem. Basicaly how long does it take for the computer to respond to commands while it is doing a task. either get a bigger hard drive and more ram or clear out some files on your computer. You can also go into settings and change the settings. You'll have to look through the manual on latency problems.
Nov 22, 2014 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Behringer mixer Eurorack UB802 is losing partial stereo signal in one channel. When I record (audacity software) I can hear both channels but displays one channel. Is it my computer's audio jack t
Sounds like the output cable from the 802 is not correctly pinned to your input on the computer. Fred is on the right track but you may need to take it a bit further.
It may also be helpful to use a Pro USB audio interface such as the Digigram UAX220v2 (line level version).
If you wish to use the computer's on board sound card consider an IHF/Pro interface that converts balanced audio to unbalanced , and the proper cables. Two 3-wire balanced 1/4-inch from the 802 to the left and right inputs of the interface (XLR Male), then RCA (Red and White) to a 1/8-inch TRS Plug cable onto the the computers audio input.
Henry Engineering's Matchbox HD comes to mind.
Good Luck.
Apr 24, 2012 | Behringer Eurorack Ub802 - Ultra Low-Noise...
Will not record from EPG settings but will record on 'live' record ie whilst already watching a program. Tried all usual reboot tricks but to no avail. Please note the forward recording schedule list has...
mikelake735
If you have DISH Network equipment, you can try a check switch test on your receiver so the receiver can update its information from the satellite. With the DISH remote press the Menu button which will display Main Menu on the TV screen.
Press 6 (System Setup), 1 (Installation), and 1(Point Dish). Highlight the CHECK SWITCH button on the upper right of the screen and press the Select button on remote. On the Installation Summary screen, highlight the TEST button at the bottom of screen and press the Select button on the remote. This will initiate the test. Allow the test to complete. Once completed, exit out of each screen till you get Acquiring Satellite Signal on TV screen. After acquisition completion, allow it to download the program guide. If this doesn't fix the problem, you may need a new receiver. I hope this helps.
Ray Calo
DISH Network
Feb 21, 2011 | Televison & Video
My record button ib Acid studio 6.0
that happen while u was recording some thing ???
Aug 21, 2009 | Sony ACID Music Studio 6 Full Version for...
Red record button will not depress to start recording
Check that you have not knocked the record tab out of the tape you are using.  Try a new tape.
May 28, 2009 | Panasonic RN-405 Handheld Cassette Voice...
Sony acid pro 6.0, microphone level when recording is way high
are u using the volume control or what mixer--u might want 2 try out the volume control--set it up recording
May 16, 2009 | Sony Acid Pro 6 Professional Music...
How use Tivo on Motorola DCT6412 III?
this works to record progam you watching
1. press menu key
2. highlight DVR button by using either < or > key then press OK button
3. answer prompts
Do this to set up a recording in advance or a series recording
1. Hit the guide button
2. scroll thru channels until you find program you want to record
3. scrool over to red dot press OK button
4.you can the highlight red dot for one time recording or go down one to record every episode. make sure you check the settings for this program.
Hope this Helps.
Mar 19, 2009 | Motorola Televison & Video
Unable to record show on the DVR
Try a hard reboot. Hold the power button on the box till it turns itself off. It will turn itself back on. After restarting try to record live tv. If you can't watch recorded shows either your harddrive may be fried. After thought, a $20 tv tuner card from e-bay for your computer, you could record them to your desktop.
Mar 11, 2009 | Televison & Video
Can get to region unlock menu but refuses to change.
hi try this one there are 2 versions they both have different chips.
  1. Power Up the unit with NO Disc in the tray.
  2. Press the Setup button on your remote control
  3. Press the 1 button on your remote control
  4. Press the 6 button on your remote control
  5. Press the 9 button on your remote control
  6. Press the 5 button on your remote control
  7. Press the 1 button on your remote control
  8. Press the 8 button on your remote control
  9. Select the region code with the Number buttons or the Navigation Buttons on your remote control. 0 (Zero) for Multiregion.
  10. Exit the menu
  11. Press the Power Off button on your remote control
  12. Press the Power On button on your remote control
it worked for me.
Sep 24, 2007 | Cyberhome DVR 1600 DVD Recorder
Computers & Internet Logo
70 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Anbes
Anbes
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
