Question about Panasonic Televison & Video
Tv shut off while watching it. Won't turn on, I unplugged it did not help is their a fuse. Its a Panasonic 42" Pasma
  • johnlnolde Aug 08, 2010
    The tv is 42" Panasonic Plasma Model No. TH-42PX60U. I have the back off already, I see two fuses by each other, can not tell if blown because their not clear ones.
    Fuses were no good but I could not find the right fuses. I needed 8 amp but only could find 6.3 amp. The tv won't come on but now the power button flashes, is that because of the wrong amp fuse.
    President:
  • 1,961 Answers
Is the power indicator lit?if not then its the power supply that is not working..you can acces the power supply board by opening the back cover of your tv.the power supply board is where the power cord is connected check the fuse whether it is open.if it is open do not replace the fuse right away replace inspect the parts in the power supply if there are parts that are blown or melting..replace them with the same value.afterwards test the power supply plug it to the power source if the fuse blown again then time to replace the transistor regulator.this regulator is a component with 3 pins and install with heat sink..be very carefull when replacing this part be sure it is unplug...to the wall.you can also replace the whole power supply they are available at this link.Just post a message if you have other question.Im very glad to help you.
Posted on Aug 09, 2010
  • 10,594 Answers
Yes, fuse would be located on power supply board. Unplug tv from wall socket, take off back cover of tv and check nearby area where AC cord plugged in power supply board, check fuse and replace it if found blown.
If fuse blow again that means power supply board got defective and will be replaced.
Let me know if you have additional question with model number of your tv.
Thanks.
Posted on Aug 08, 2010
  • Shahid Electronics
    Shahid Electronics Aug 08, 2010
    OK, take out both fuses one by one and test them with multimeter as good fuse will show continuity and blown fuse wont show any thing on meter.
Why won't my Panasonic 42 TCP42S30 42 Plasma TV turn on.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service
technician, since the back cover has to be opened for investigation/rectification.
Aug 22, 2012 | Panasonic 42 TCP42S30 42 Plasma TV
My th-42px77u shut off while watching
3 blinks with Panasonic TVS denotes the fault with 3.3v SOS D Board. Visit this site for more details. Just type in "electronicshelponline" into the search box of your browser, and click search, and select the site named (Electro-help). You can see a site by this name. Pull up older posts there. Sometimes, ads related to each post might give you details about the availability of spare parts and prices.
Jun 28, 2012 | Panasonic TH-42PZ700U 42 in. Plasma...
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
I have a 1 1/2 year old Panasonic TC-P42U1 plasma tv. While watching a show, it suddenly shut off and won't come back on. What do you think caused this and how can i fix it? Thanks.
Try unplugging it completely for 30 seconds to 1 minute. Plug it back in. If it still won't come on, it's likely taken a power surge and popped a fuse or power supply, which means a trip to the service center.
Jun 18, 2011 | Panasonic TC-P42U1 42 in. Plasma HDTV
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Just shut off, no power
i have proble several time in a day
Nov 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
My panasonic tv got problem
when it is warm, shut off, then after take a rest it will automatic on again, probably you need change the on anf off switch.
How long have you had the TV?
Jul 10, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
Open Questions:
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
