Question about Toshiba Satellite A105 Notebook
Screen flickers I have an A105 Toshiba Satellite and my screen flickers. I purchased a used complete screen that includes an inverter, black and while cables and video cable and the result is the same. The screen on my external monitor works. Do you know what could be causing my screen to flicker.
    Scholar:
  • 144 Answers
I think not continues voltage to your inverter.Not really sure but
1.Test you power adapter that it really have continues power supply like all the time 19V..not up and down.
2.if you already change inverter then.....you should check all the
cable that goes into inverter some shoulde 18-19V ,some should have 3V..(continuesly) if problem with the voltage then its the chip that control it.
takecare
Posted on Apr 29, 2008
  • 56 Answers
Sounds like the issue is a problem with the motherboard. Does it get worse when the cooling fan and/or cdrom are running?
Toshiba a105 on start up screen is red, then goes black
The Toshiba A105 notebook computer is made for mobile computer users who need optimal processing power. The LCD screen is a 15.4 diagonal widescreen with TruBright technology. The laptop has a fast hard drive access rate that is in the 3ms range for the paging and access of data. There are problems that can occur with the Satellite A105 that can be solved by knowing what to look for when troubleshooting the system.
Black Screen Problem Black screen problems can occur when the Satellite A105 backlight is burned out or the inverter is not working correctly. The backlight can be replaced with a new LCD bulb manufactured for LCD screens. The inverter is a housing unit that controls the voltage to the LCD screen. The inverter must be replaced by a compatible A105 Satellite inverter unit. Power Problems b> During the power-up phase of the laptop, the Satellite A105 will quickly turn off without signing into the Windows Operating Screen. The problem can be due to a faulty power adapter that is not supplying the right amount of voltage to the system board. You can also check to see if the unit that houses the power plug is loose, which also indicates lack of voltage or electricity going to the board for power up operations. Hardware Conflict Problems b> Hardware conflicts can cause system errors or "freezes" by loading a new hardware component into the same hardware I/O address. The Satellite A105 has designated input/output addresses for peripheral devices, such as hard drives, video drivers and other hardware functions. To solve hardware conflicts, use the Control Panel "Hardware" device function to see which hardware I/O addresses is not being used. b> Audio Not Working Correctly b> Loading a new audio program can cause the audio codec for the Satellite A105 not to produce sound. The audio codec can be restored by loading the "restore system disk" for the A105 laptop. The restore menu provides options on certain components that you want to restore. If you pick the option for audio, the program will restore the audio to its factory settings. b> On-board LAN Switch Not Working b> The Satellite A105 is automatically configured to detect T Base 10/100 Ethernet networks. If the laptop does not recognize the on-board LAN switch, check the system setup to examine if the LAN switch is on. If so, a firmware update may be needed to upgrade the BIOS.
Jan 16, 2013 | Toshiba Satellite A105-S4334 Notebook
My Toshiba Satellite A105 screen comes on for a little bit, flickers and then shuts off. However I can faintly see the screen, and the laptop works fine when hooked up to the external monitor. Wondering...
If you can still view screen if you view it in an angle or spot a flashlight on screen. Then, definitely it is a problem on backlighting, might be loose connection, inverter giving up or cfl giving up.
Hope this helps
Nov 06, 2009 | Toshiba Satellite A105 Notebook
Screen flickers and dies
You have a faulty LCD inverter board.. Go here for instructions on how to replace and find a new one, or you can search on ebay for one. http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
Sep 11, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite a105 s4004
Here, I found this:
Toshiba Satellite A105. How to remove and replace laptop FL inverter and LCD screen.
Jun 23, 2009 | Toshiba Satellite A105 Notebook
I have a Toshiba Satellite A135 and not sure if blacklight or something else
Your backlight lamp, (Bulb), or the Inverter is bad.
1.General instructions, and photos, for replacement of a typical laptop backlight,
http://www.ccfldirect.com/lcdtutorial.html
2.Instructions for completely disassembling a Toshiba Satellite A135 laptop. The reason I included this is twofold.
A.It shows, and tells exactly, how to remove the LCD screen from your laptop.
B.It shows you that the following information in link 3, on how to replace an Inverter in a Satellite A105, will work for your Satellite A135.
http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-1.htm
(At the bottom of this page you will see Page1:: Page2:: Page 3:: Page 4
You are on Page 1. Just click on the white Page2, and so on, to continue)
3.How to replace an Inverter in a Satellite A105,
FIRST! Always remove all power! AC adapter, (Charger), and battery.
Second! Observe anti-static guidelines!
Third! This ain't tough! It just looks hard. Once you see how simple this is, I'm sure you'll agree with me.
May 28, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A105 Display
If you've replaced the LCD Panel already, then chances are good, the failing part may be the FLR inverter. It's a thin little chip about 3 or 4 inches in length that bridges the connection between the LCD and the motherboard. It's location varies from computer to computer though, so you may have to check with manufacturer documentation. They're not too terribly expensive to replace though, much cheaper than the LCD panel, anyways.
May 09, 2009 | Toshiba Satellite A105-S4004 Notebook
The screen flickers and scrolls and is very messed up. im trying to figure out if its the lcd screen or the inverter board
if the screen at any piont work normally its the inverter. they can be bought on ebay for 10 dollars
Jan 08, 2009 | Toshiba Satellite A105-S4004 Notebook
Screen flickers
yes i have had this problem before
the propper signal isnt getting to the screen from the mother board
has anything been spilt on the screen or the computer its self
i would suggest taking it to a tech they should be able to fix your problems
Jul 19, 2008 | Computers & Internet
Screen black out?
Most likely the LCD inverter. The inverter supplies the voltage to the ccfl lamps to light the display. These inverters run about $20 on e-bay.
On my toshiba M105 the problem is the Tab welds at the top of the lcd itself. 1/3 of the screen is not usable but an external screen is perfect.
Apr 14, 2008 | HP Pavilion dv6000z Notebook
Toshiba satellite A105-S361
the inverter maybe going bad. go to ebay get a cheap toshiba satellite a105 lcd inverter.bam the problem fix oh you would need a screw drivercause this is a diy project no need tosend it out link me if anything bakerandre2000@yahoo.com
Apr 14, 2008 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite A105 Notebook Logo
259 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
