Question about Cisco Aironet 340 Wireless Bridge
I need to reset a Cisco Aironet BR-340 v8.24, with lost password, distribution firmware disable, I think that need phisical reset. Ivan Alva
4 Suggested Answers
SOURCE: how to reset Cisco Aironet 340 Wireless bridge?
Aironet 340 Series Bridge For Software Version 8.65 or Later If you forget the password that allows you to configure the 340 bridge through the console port, you must completely reset the configuration. Complete these steps in order to delete the current configuration and return all settings to the factory defaults:
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors in order to connect the COM 1 or COM 2 port on your computer to the RS-232 port on the bridge.
    For more information, refer to the Cabling Guide for Console and AUX Ports.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal. Other programs are similar.
  3. Enter a name in the Connection Description window.
  4. Select an icon for the connection.
  5. Click OK.
  6. In the Connect To window, use the Connect using pull-down menu in order to select the port where the cable is connected.
  7. Click OK.
  8. In the Port Settings window, make these selections:
    • Bits per second (baud): 9600
    • Data bits: 8
    • Parity: None
    • Stop bits: 1
    • Flow Control: None
  9. Click OK.
  10. In the Connection Description window, enter a name and select an icon for the connection.
  11. Click OK.
  12. Press Enter.
  13. When the Main Menu screen appears, reboot the bridge.
    Turn the unit off and then back on.
  14. When the bridge reboots and the Main Menu screen reappears, enter 2 in order to choose Reset.
  15. Press Enter.
  16. Enter Yes.
  17. Press Enter in order to confirm the command.
  18. After the bridge reboots and the Express Setup screen appears, reconfigure the bridge with the terminal emulator or an Internet browser.
see this link 340 Wireless Bridge
Posted on Jul 25, 2008
SOURCE: Dose cisco aironet 1100 support routing
You must use a router to perform NATing to the ISP. Simply use a Netgear or Linksys router and plug your access point into it. You can even use a Netgear or Linksys wireless router with the ethernet ports built into it. Just disable the onboard wireless.
Posted on Aug 04, 2008
SOURCE: how to reset to factory default a Cisco Aironet
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
    Note: These instructions describe HyperTeminal; other programs are similar.
  3. In the Connection Description window, enter a name and select an icon for the connection and click OK.
  4. In the Connect To window, select the port to which the cable is connected and click OK.
    1. In the Port Settings window, enter the following settings:
    2. 9600 baud
    • 8 data bits
    • No parity
    • 1 stop bit, and
    • Xon/Xoff flow control
    1. Click OK and press Enter.
    2. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    3. When the bridge or AP reboots and the Main Menu screen reappears, typ
    4. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
    5. Open a terminal-emulation program on your computer.
    6. In the Connection Description window, enter a name and select an icon for the connection and click OK.
    7. In the Connect To window, select the port to which the cable is connected and click OK.
    8. In the Port Settings window, enter the following settings:
      • 9600 baud
      • 8 data bits
      • No parity
      • 1 stop bit, and
    9. Click OK and press Enter.
    10. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    11. When the bridge or AP reboots and the Main Menu screen reappears, type 2 to select Reset and press Enter.
    12. Type yes and press Enter to confirm the command.
      Note: The Reset command is valid for only two minutes immediately after the bridge or AP reboots. If you do not enter and confirm the Reset command during that two minutes, reboot the bridge or AP again.
    13. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.e 2 to select Reset and press Enter.
    14. Type yes and press Enter to confirm the command.
    15. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.
    Posted on Apr 18, 2009
    Can get router to work
    The Cisco Aironet 1200 access point provides secure wireless connection to your network. Cisco's wireless access design meet the needs of a small to medium size business.
    This unit provides secure network access for laptops or Wi-Fi capable portable devices, which you upgrade at any time as your business grows.
    A beneficial feature of the Cisco Aironet 1200 is its ability for the administrator to reset the access point remotely.
    This resetting process works through your internet browser.
    Log on to the System Configuration page by entering your Cisco Airnet 1200 IP address in your browsers web address text box.
    Enter your user and password information from the pop up menu.
    Click on the "Setup" button from the summary status page.
    Select the "Cisco Services" setup option and click on "Manage System Configuration."
    Click on "Reset All System Factory Defaults" to reset the router.
    The Cisco Aironet 1200 will be restored to factory defaults.
    http://www.cisco.com/en/US/products/hw/wireless/ps430/index.htmlCisco Aironet 1200 Series
    Configaration Cisco Aironet 1200 Serieshttp://www.cisco.com/en/US/docs/wireless/access_point/1200/vxworks/configuration/guide/bkscgc10.html - wp1016665
    May 07, 2014 | Linksys Cisco Aironet 1200 Wireless Access...
    Reset cisco aironet 350 adapter
    Try Putty and a 9pin male to RJ45 RS232 serial console cable.
    the instructions are in the link provided here:
    http://wirelesslanprofessionals.com/wp-content/uploads/2010/01/Password-Recovery-on-Cisco-APs.pdf
    I’m happy to help further over the phone at https://www.6ya.com/expert/matt_7e951e081251ffbc
    Jun 30, 2017 | Computers & Internet
    Hi Sir/Madam, I have an issue on cisco Aironet 1142n, keep connecting disconnecting sometimes only, i have configures 4 Vlan's and 3 ssid's, any one can help me to solve this issues. if more...
    This might help:
    In Device Manager, open your wifi and/or Network Adapters Properties, under Power Management tab, disable the "Let Windows turn off this device to save power".
    Feb 19, 2018 | Cisco Aironet 1142N (AIRLAP1142NIK9)...
    Default username & password after hard reset
    Username:[none]
    Password:Cisco or
    :root
    :Cisco or
    :Cisco
    :Cisco
    Try from above 3 then you can access cisco router.
    Let me know if you need further assistance.
    Thanks for using FixYa.
    Feb 01, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
    Need to reset to factory default
    If there is, hold it down for about 3 seconds while powering on the unit. Hope it helps.
    Dec 21, 2009 | Aironet BR500
    Drivers four air-lmc drivers
    Official page: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=268438196
    You might have to signup at cisco to be able to download the software. It's done in a few minutes though.
    Hope that helps!
    Jun 06, 2009 | Cisco Aironet 340 Wireless Adapter
    Jul 31, 2008 | Cisco (airap1120bak9airpcm352) 802.11b
    How to reset Cisco Aironet 340 Wireless bridge?
    5. Click OK.
    7. Click OK.
      • Data bits: 8
      • Parity: None
      • Stop bits: 1
    9. Click OK.
    11. Click OK.
    12. Press Enter.
    15. Press Enter.
    16. Enter Yes.
    Jul 22, 2008 | Cisco Aironet 340 Wireless Bridge
    Puzzled with blinking red lights
    Hi.
    Yes, unfortunately your device is busted . Power surge might have cause it. next best thing what we can think of right now is what to replace it.
    Pls feel free to ask Fixya if you may have additional questions
    Thanks
    Jun 15, 2008 | Cisco Aironet 340 Wireless Bridge
    Cisco Aironet 340 Wireless Bridge Logo
    83 people viewed this question
    Top Cisco Computers & Internet Experts
    Gopi Venkatesan
    Gopi Venkatesan
    Prashant M
    Prashant M
    Gareth Tomlinson
    Gareth Tomlinson
    Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
