Question about Sharp AJ-5030 InkJet Printer
AJ-5030 Lost Manual
Have a message on printer "Clean up Scanner". What do I need to do.
Machine is old but in good shape. Use very little.
Need amanual for a sharp AJ 5030 all in one copier
Posted on Jun 22, 2008
  • 1,342 Answers
Get your manual HERE
Clean the glass in the scanner.
Posted on Apr 27, 2008
How to fix Aj5030 error clean up scanner
Clean scanner lamp and optical lance .if not the problem fix need to change scanner unit
Jul 14, 2014 | Sharp AJ-5030 InkJet Printer
Several all-in-one machines are designed not to function without ink cartridges installed. This is to keep from accidental burnout of the printhead nozzles. Even though you only want to use it as a scanner, you could easily click it to print or copy which woule burnout the printhead nozzles. I guess you could call it a "safety feature".
Mar 06, 2011 | Office Equipment & Supplies
My printer is not printing and give error message like ''communication error''. Is it because the cable is too long? I am using 10 ft now
Cable length has nothing to do with it. It may even be on the computer side as corrupt driver installation etc. Make sure the cable connections are correct. uninstall the device from the device manager and reinstall.
Sep 12, 2009 | Sharp AJ-5030 InkJet Printer
Keep getting error message to unlock scanner.....says it can be unlocked from the bottom of the scanner, but I don't see it.
My one touch 5800 USB scanner worked great on XP for over a year and then started giving me the unlock the scanner message. I tried different power supplies, reloading software and moving it to a machine running 98SE and nothing improved. I left the cover open and noticed that the lamp was fairly bright at the sides but very dim in the center. I replaced the lamp with one from an old parallel port scanner which was in good shape and it now works perfectly on 98SE. I have not connected it to a XP machine yet.
Aug 26, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
Ricoh ft 4522
check the fuser first, it should be clean and shiny otherwise it's coming from drum area
Sep 12, 2008 | Ricoh FT5832 Copier
Default setting
Your machine is old analague and a few years old now.It should be no problem changing.If your exposure settings are out it may be drum wear but more often or not all mirrors needing good clean.
Off top of head....M/c off..hold down 0and 8 numerics and power on...AD or AJ on display.punch in 15 and press print..... should read 00 on display... punch in01 and press green print 09 and m/c ready to go if not switch off and on.
If unhappy with auto expose or manual middle expose...0+5 power on...AD or AJ on display,punch in 0+1 then print key opens exposure....pressing 1 increases light each press,,,try poss.10 times and print after to load.. and 7 decreases light to darken then print to change value. 0+9 together will get m/c to ready please try, all the best.
Mar 27, 2008 | Toshiba 1360 Black and White Copier
HP LaserJet 3330
Remove the small glass pane of the left side of the scanner bed. You onlt need to remove one screw. Push the driver belt which will move the scanner to the left. It can be a little tricky to move the scanner the last little bit so you may need needle nose pliers or someone with a hook (I used a fork) to pull the scanner last little bit. Once the scanner is in the open spot where you removed the glass panel, simple take a q-tip and clean the mirror.
I did this and my machine is working just fine.
Nov 13, 2007 | HP LaserJet 3330 All-In-One Printer
Are they original cartridge if not change them for original ones failing this clean the contacts on the cartridges and the carriage.
Thanks J
Oct 13, 2007 | Sharp AJ-5030 InkJet Printer
Sharp AJ-5030 InkJet Printer Logo
110 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
