I dropped my Digital Concepts digital camcorder (it takes pic. and videos)
and now the screen is blurry....takes blurry pictures and videos because that is the way the screen is. PLease help!
I dropped my camera and the lens won't close now, so when I take pictures theyre all blurry and the same with videos. I can't take any pictures now because theyre all blurry!
AnonymousApr 12, 2009
I spilled soda on my camera but i took it apart and cleaned it but when i take a picture it comes out blurryI spilled soda on my camera but i took it apart and cleaned it but when i take a picture it comes out blurry
You can't post conmments that contain an email address.
If the pictures are blurry, you probably damaged the lens with the drop. You will have to send the camera to the factory service to replace the lens unit, if it is not serviceable.
If you drop a camera this is not normally covered by the warranty. You may find it cheaper to replace the camera than have any major service done to it.
Is it the viewfinder (that you hold up to your eye) or the screen that's blurry? If the viewfinder is blurry, there should be a diopter adjustment to fix it, probably right above the rubber eye cup. If the screen is blurry, you should take some pictures and video and view them on a computer. I they are sharp on the computer but blurry on the camera screen, there may be a problem with the screen and you may need to take it in for repair. If the pictures are blurry on the computer as well, the camera may not be focusing properly. If you can't focus manually, or the camera can't focus when auto focus is turned on, you have good light, and aren't too close to your subject, then it may need to be serviced.
maybe you zoom in a lot and then it would be normal and if the pictures come out fine, i wouldn't worry about it but if the print pics come out grainy and blurry i would take it back if you have warranty
When I turn my camera on, the lens goes in and out a few times. Once it's finally on and I look at the screen, everything is blurry. When I take the picture, it's blurry too. If I try to use the zoom to adjust, the lens starts going in and out all crazy and won't adjust right.
number 1,make sure you have lithium batteries,energizer prefered.2 put it on auto focus.3dont be too close on the object your trying to photograph,and 4 do not zoom in too close on object either.this should solve your problem,good luck,hope i helped
If you dropped the camera then the lense is out of alignment from when you dropped if mabey it can be fixed or not. It will cost much to fix the camera.it has a gear mechanisim so if its out of line its fuzzy pics.
Try resetting camera. If that doesn't work more than likely there is a lens error. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
