Question about Frigidaire GLHS68EE Side by Side Refrigerator
We have a Frigidaire GLHS68EE PB4. The freezer side appears to be working normal but the frig side is not getting cooler that 53 degrees. Any suggestions??
  • Frigidaire Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorWe have a Frigidaire GLHS68EE - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Aug 08, 2010
Frig is not cold- alarm keeps going off but freezer says it is 6 degrees and it seems fine - just the frig part not cold. It is up to 47 degrees
It sounds like you may have a faulty thermostat, or a control panel issue. I would recommend that you call a repairman, that will alleviate the guess work as it could be a few things that could be wrong.
Mar 23, 2011 | Frigidaire FRS3R5EMB Side by Side...
I have a frigidaire side by side #FSC23LR5JM2 that is not keeping cool enough. Age is aprox 1.5 yrs. Noticed the problem over a couple of days. Turned the temp cooler by 2 numbers in the frig and freezer,...
if the freezers staying cold but not the refrige section,then its the damper vent door between the freezer and refrige section thats either frozen shut or the damper door motor is bad or without power,if nothings cold as in freezer and refrigerator sections,then its the ptc overload & relay on the compressor thats bad,unplug the ptc overload & relay off the side of the compressor and obtain an exact replacement and plug in the new replacement and it will again cool
Refrigerator thermastat set to 37 degrees but registers at 28. Freezer set at 0 degrees but registers at -2. Frig/freezer do not feel that cold but vegetable bin (produce bin) in refrigerator is...
i have never seen the problem
my idea is the thermostat is bad. but won,t both of them be bad.
you try to check the damper motor swithch and damper motor
good luck
Jan 12, 2011 | Frigidaire FRS26R4A Side by Side...
Have a Frigidaire GLHS68EE. The freezer side appears to be working normal but the frig side doesn't get cooler than 53 degrees. Any suggestions?
Sounds like you have a defrost problem since the freezer side is working ok . It probably is not blowing cold air into the refrig side , so to check the defrost circuit , unplug the refrig and inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Useing a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly thru the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrig back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrig and reinstall the refrig control section . Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired togather and the replacement part comes with a new heater and bimetal already wired togather . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Good luck in solving this....
Aug 08, 2010 | Frigidaire GLHS68EE Side by Side...
My frigidaire side by side isn't cooling properly,
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 21, 2010 | Frigidaire Freezer Refrigeration White...
Freezer works, frig doesn't
there is a fan on many newer units that blows cold air from the freezer side to the frig. If that fan is not working, the frig will be cool, but not 34° like you want it.
Nov 25, 2009 | Frigidaire Refrigerators
PLHS69EGSS1 Freezer not cooling properly but Frig is OK
This is one time you might need gas. Your freezer needs to be 20 degrees or less for the ice maker to work.
May 01, 2009 | Frigidaire PLHS69EGSS Stainless Steel Side...
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Frig and freezer warm most of the time
HI thanks for your question, i think what your problem is . the compressor is over heating and cutted out. clean all the coils at the back of the fridge. if theres a fan motor at the back make sure its going check that thanks
Aug 23, 2008 | Jenn-Air JCB2388G Side by Side...
My frigerator
This will get warm. If very hot check and clean coils in front, underneath. Also check fan behind rear panel. It should be turning when the unit is running. Also check for door not closing properly.
Nov 12, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire GLHS68EE Side by Side Refrigerator Logo
74 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
