Question about Logitech X-530 Computer Speakers
My right logitech speaker jack no longer works due to the cable being pulled out too hard. im sure its the jack because the right speaker still works in the left jack. i had a quick look at the inside and don't know where to begin to repair. any help will be much appreciated, one speaker sounds sad :(
  • Flo210 Dec 24, 2010
    Are you talking about the rear speakers?
  • 40 Answers
If so, buy an unwired RCA (male) jack. Remove the jack from the speaker (if it didn`t broke while pulling) and connect the new RCA jack.
Posted on Dec 24, 2010
Looking for old Logitech S-100 driver
These are analog speakers and do not need a driver. First, make sure they're plugged into the speaker/headphone jack and not the microphone jack. Second, make sure the computer's sound output is enabled and set the headphone/speaker jack. Third, verify that the sound output is working by plugging in a headphone set or a different pair of speakers. If the computer sound checks out, the speaker cable is bad or the power supply is not working.
Nov 14, 2017 | Dell Computers & Internet
I have actually lost my satellite speakers that came with the Logitech Z-2300. I am wondering what my best option is. I can't seem to find anyplace that sells these kind of speakers separately. I...
Hi
http://www.livedigitally.com/2005/09/05/logitech-z-2300-speaker-system/
It would appear you need 2 x 1/4 inch (3.5mm) jack to RCA cables, one for each channel and each speaker, left and right, rather than just the 1 cable ("..and a mini to RCA cord...") you seem to have bought.
The Yellow and Black RCA ports appear to be the Left and Right speaker channels respectively.
The output cable with a green jack that connects to the green jack on the computer's sound card seems to be tied in with the wired Remote Control.
I would have recommended getting a pair of passive 40W RMS Logitech Stereo Speakers.
As long as the speakers you have match in terms of Wattage and Impedance, you should be okay.
I hope this helps.
Aug 26, 2011 | Logitech Z-2300 Computer Speakers
We connected our z 5300 speaker to a new computer. and get no. sound. Is there a driver that needs to be installed. the last computer no longer works.
Did you open your speaker ICON and check to see that you don't have the audio muted? I have seen a lot of customers complain that their NEW speakers don't work but they have their audio set to mute.
Mar 06, 2011 | Logitech Z-5300 Computer Speakers
X-530 one speaker not working
this is a problem that i have faced as well it is likely that the cable going in to the jack could be loose and you might need to move it a bit, but in your case i think most likely would be that the input jack on the sub for the speaker is broken in that case you should call up logitech and ask technical support to see what they can do for you should be covered by warranty!
Feb 09, 2009 | Logitech X-530 5.1 Channel Speaker System...
Microphone still muted
if you notice the speaker icon in your systray... that space with all the icon's on the lower right of your screen you will see a speaker... open that and look for a mic setting... you may have to go into the menu at the top of the window to add the control for the mic... make sure it is not muted.
Robert
Feb 02, 2009 | Logitech Quickcam Chat Webcam
Hooking up a Logitech Z-2300 subwoofer to a Yamaha RX-V392 receiv
This is the exact same setup im lookng at, just a different Yamaha receiver (RX-V663). Since the 3.5mm headphone jack and and the sub preout are both 'line level' you just need to pick up a male RCA to female 3.5mm jack converter from radioshack. I'd expect it to be around $5-8.
I have already stripped my old 5.1 HTIB system rca connector to use the surround speakers with my receiver. They work but are cheap speakers. Im tempted to do something similar with the z-2300 speakers, much higher quality, but I would definitely use a converter instead of stripping to keep them backwards compatible.
Jan 10, 2009 | Logitech Z-2300 Computer Speakers
No right front with Logitech X-530 5.1
bad wires i had tis set wigle the cable by the jacks see if its on in off
Jan 19, 2008 | Logitech X-530 Computer Speakers
One speaker works only
As long as the jack you are using fits snug into the port, they will be the right size. I am sure that they are the same size. As for the jack port, some can be finicky like that. It is more than likely your sound card that is at fault. You can check the connection on your card by removing it with the computer off and inspect it for a loose connection within the jack port and around it. Plug in the speakers slowly and see where it is not contacting. Some do it yourselfers can fix this by replacing the port or re soldering a bad connection
Nov 19, 2007 | Logitech X-230 Computer Speakers
Right speaker malfunction
try blowing the headphone jack hole. One hard puff should do the job
Nov 01, 2007 | Logitech X-230 Computer Speakers
Logitech z680 speakers
Plug in the green cable to the green plug. To plug in the rest of the cables you will need to buy a 5.1 or greater sound card.
Oct 03, 2007 | Logitech Z-680 Speakers and DVD218 System
Logitech X-530 Computer Speakers Logo
224 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
