Question about Epson Stylus Photo 1410 Printer
My Epson 1410 with CISS system is printing tramlines. I have cleaned and aligned the heads over and over, I had the head replaces at a service agent all to no good.
  • joandmalcolm Aug 08, 2010
    Hi Silverdragon
    Thanks so much for your insight - it makes sense to me. The printer goes back tomorrow. Wish me luck.
  • Epson Master
  • 12,061 Answers
Now this happens when the Pattern is too close to the heads and they push the paper too close and the head edges drag on the paper and leave behind that trail. I am astounded that you had it seen to,replaced the heads and still it faults, i don't think the repairers did you a good job. Surely it was incumbent upon them to make it work as it should. If it were me this would be unacceptable in the extreme. I think you need to take it back and demand that it is fixed, as it should have been.
Posted on Aug 08, 2010
    Hi Thanks so much for your insight, it makes sense to me. The printer goes back tomorrow. Wis me luck!
Horizontal lines when printing
Hi Mehrabmeh,
Run a cleaning page through it, from the printer control panel in windows
if that fails try running the printer head alignment program
check in your printer manual, you should find instructions on both in there
OR
If You Still Need Assistance Then Follow US For On : Epson Printer Support
Feb 05, 2014 | Epson Stylus Photo 1410 Printer
Epson stylus dx7400 will not work with ciss - lights keep flashing
this mean that the waste pads full and you need software to reset the printer
Feb 11, 2013 | Epson Stylus Office Equipment & Supplies
Does not print, just a faint black print, the cartriges are half full.
your printer is a photo printer which consumes considerable amount of inks when printing... you may need to perform a head cleaning process to clear the clogg on your nozzle. this may consume your ink cartridges... i suggest that you convert your printer into a CISS (continous ink supply system) this is more cost effective instead of buying ink per ink as this shows the same output as the regular ones.
check out ebay for people who convert epson system to CISS
note: doing the head cleaning process always takes ink to force the clogg out of the nozzle tube
hope this helps
Aug 07, 2011 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus CX5400 will not print. This printer was unused and stored for 3 years. We replaced the ink cartridges and cleaned the print head and aligned the print head and ran a nozzle check. The printer...
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!You might have dried it up.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 11, 2010 | Epson Stylus CX5400 All-In-One InkJet...
Ink is not visible on paper
First NEVER raise the tanks of a CISS above the height of the printer otherwise all that is going to happen is that the ink will syphon out and end up getting everywhere.
As you have not used the printer in a long time there wil be dried ink in the print heads 3x head cleaning is nowhere near good enough to clear the blockages.
One thing I would do as you have a set of OEM carts is the following presuming you have the equipment.
Drill a small hole in the top of each cart and extract as much ink as ps=ossible with a syringe (you can put it in the ciss ink tanks) and replace with head cleaning solution. Reseal the ink carts (if clean selotape will do) insert carts and do 5x head clean, leave 24hrs and do 5x head clean again. This will allow the head cleaning solution to get right insine of the print head, soften the dried ink and then flush it through..
A lot of messing about I know but you've just shelled out a few bob for a CISS so it's worth it.
NB
Make sure you keep the CISS carts above the tanks whilst outside of the printer.
Aug 24, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson PictureMate - can't clean all nozzles & Error P
Many times head cleaning will throw much ink away. 1 time about 10% of ink. After meny times head cleaning, ink will out, and need replacement. May be after head cleaning nozzle is ok, but after replacement, printer do ink charge. It may be distrub the flow of ink at head. Is the cartridge new?. Use CISS for continuity printing.
Jul 26, 2009 | Epson PictureMate C11C623001 Photo Printer
Hi my epson r285 with ciss is leaving ink blotches all over my print outs, predominantly black, but less frequent with the other colours. This is only a new printer. Head cleaning, noxzzle cleaning and...
It might be caused by waste ink at bottom plate around head sprayer. For some CISS (bottle) design, ink will flow to head, and then flow to pad, when printer off. So, you must close respiratory hole at bottle when printer is not used. For cleaning, turn off printer (unplug power) when head is not in parking position. Move head to center. Put wet tissue (with cleaner or hot water) at top of pad (at head cleaning mechanics). Move head to parking position. So bottom plate contact with tissue. Wait for 10 minutes, repeat 3 times. Check nozzle.
Jun 21, 2009 | Epson Stylus Photo 1290 InkJet Printer
Not printing properly specially the black
Printer nozzle is clogged and needs the cleaning process several times. Get a new/refurbished printer from Epson.com and then, Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Jun 19, 2009 | Epson Stylus Color 400 InkJet Printer
Won't Print
Sounds like print head issue; have it serviced or u can try this :
How to Unclog Epson Print Heads
Jan 21, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus Photo 1410 Printer Logo
75 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
