Question about Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
MOWER blades WILL NOT SHUTOFF - Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
  • 252 Answers
Sounds like a electro clutch engage type system
maybe your electro-clutch engage switch is faulty or a wire is connected the wrong way
was the clutch replaced recenlty and was is compatiable ?
or maybe you have a faulty clutch to test try
remove plug lead from plug
disconnect wires @pto clutch and apply 12 volt directly to clutch then remove voltage - if clutch engages then disengages the clutch is good it should click on then off if it does then its a switch fault
replace pto switch
cheers paul
hope its helps
Posted on Aug 08, 2010
  • b59ram Aug 27, 2010
    My Clutch clicks (thunks is more like it) when I cycle the PTO switch, but it does not disengage. And the mower 'thinks' the blades have stopped, as it still starts, and does not shut off when the 'driver not on seat' switch is activated. How can I break the clutch free - of course it worked fine just prior to this problem surfacing this AM.
How to replace plastic blades on a challenge mower
Dave, Remove plug wire, raise mower, or tilt on it's side to access blade. Remove center bolt holding blade on, noting the position so as not to install new blade upside down. Install new blade correctly and tighten blade bolt tight. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change Lawn Mower Blade
Lawn Mower Repair How to Remove Lawn Mower Blades
What Direction Do Turn the Nut to Change Mower Blade
Jul 28, 2016 | Garden
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
2000 craftman lawn tractor 917.270822 blades will not engage
If your blades won't engage when you raise the lever to engage them AND that lever moves freely without the normally expected resistance, then you've lost the cotter pin that connects the lever rod to the mower deck assembly. Very easy fix! Using the mower deck raise/lower lever, lower the mower deck to "down" position. Now, lay on your side along the right side of the mower and look up (use a flashlight) under the mower at the top of the mower deck while moving the blade engagement lever "up" (which pushes the connected rod down). At the end of the rod, you will see a hole where the mower deck and rod connect. Align the hole at the end of the rod with the matching "pin" on the mower deck (you'll see it) and insert a new cotter pin to secure them together. Use a nail if you don't have a cotter pin. Voila! you are done. The blade engagement lever will now engage/disengage your mower blades successfully. Just remember that mower deck must be down, or lowered, before you engage the blades!
Jun 22, 2012 | Garden
I cannot get my mower to start tried everyting
Don't get excited. May be just an over looked something. Have you checked the safety switches or the wires running to the safety switches for shorts? Did you leave the blades engauged? I'm sure you have gas in the tank. Did you check the fuel shutoff. Is the spark plug wire on. (been there, done that) Do you have spark? If you can get me some info about what you have done to the machine, maybe I can help more. Till then try some of the no-cost ideas above. Good luck!!!
Jul 17, 2011 | Garden
I RECENTLY BOUGHT A PUSH MOWER AT A FLEE MKT..NEVERNHEARD OF A QUATTRO MOWER...IT HAS A 22 IN BLADE..I HAVE AN OLD 21 IN BLADE FROM A L-BOY..CAN I USE THAT ON THIS MOWER OR MUST I BUY NEW 22 IN BLADE ???...
i just looked up Quattro mower they are a 4 stroke engine and yes i would buy a 22 inch blade but be sure it fits this mower PS go to wall mart and check out their blades they are reduced now.
Sep 09, 2017 | Yard Machines 158cc Push Lawn Mower #11a...
Is there a deck switch on a YTH180
Hi..my name is Keith...and i havent worked on that lawn mower model..so i cant tell you exactly where the safety switch is..but it sounds like the reverse safety switch has failed and the lawn mower thinks you are in reverse..so i would look around your foward-neutral-reverse shifter for it...i hope this has helped..if not write me back
Jun 30, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Riding mower runs but blades stop
is the belt on the bottom of the engine the clutch for the belt could be bad check them & e-mail me back at wadembly@aol.com
Jun 07, 2009 | Garden
Remove cutting blade
take the blade disc off the mower, you should have the nuts on the top of the disc for the blades, put the disc on the ground and remove the nuts on the blades.
Replace the blades with the new ones and fit the disc back under the mower
Apr 05, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Mower shakes
sounds like you bent the crank - remove the spark plug , tie the shut off handle closed with a rope , then raise mower up so you can spin the blade . look at the blade bolt while you spin blade . if crank is bent the bolt will seem to wobble
Oct 13, 2008 | Poulan "Poulan" Push Mower
Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner Logo
282 people viewed this question
Top Oregon Scientific Garden Experts
Colin Stickland
Colin Stickland
roeb
Mike Squire
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
