Question about Westinghouse W4207 42 in. HD-Ready LCD TV
Was dusting television, must have hit a button because now there's no picture. We can hear the satellite and can change the channels but there's no picture. the menu screen says no input
  • Westinghouse Master
  • 12,061 Answers
Simply try removing from the wall Power and and then reconnect, this should reset anything that was done.
http://www.generalmanual.com/Monitors/Westinghouse-W4207-HD-Monitor.htm
Above is your user manual this may help sort it out if removing from the power to reset doesn't work.
Posted on Aug 08, 2010
Deleted my channels how do I restore
If this is an HD TV you don't have to scan the channels if you have a cable box, U-Verse or Satellite Receiver.
Find your TV remote. If it's a Samsung TV or LG TV or whatever, that is the remote you need. Not the one you normally change channels with.
On the remote, look for a button marked Input or Source or TV/Video.
Hit that button repeatedly until it highlights HDMI or Component. There may be several of each. If your cable box or receiver is on, you should get a picture on one of those inputs.
The TV will not be on a number channel.
If this is a Tube TV, you have already done all you can. Your TV is deceased.
Oct 01, 2014 | Televison & Video
Multiple issue,power light flashes
Sounds like first loose connection on circuit board. I would first look around the relay this is what clicks. Then also the low voltage transformers. These problems are always concerns when set is moved or bumped hard. Try this first. Or it could be a heated issue.
Nov 26, 2007 | Philips 50P8341 50" Rear Projection...
Ticker along bottom of screen for news channels and sports channels is being cutoff along the bottom. That is, the ticker moves right to left and I can read it but the bottom 10-15% of the letters is...
I might need a little more detail to solve this problem - I suspect the problem is an incorrect setting on your cable/satellite receiver (assuming you are using one), but let's start with the TV.
Firstly, switch the TV on and select a channel where you can see the ticker. Then press the "FORMAT" button (above the red REC/CONNECT button) on your Mitsubishi remote control. This will change the screen aspect ratio and the current setting will be displayed on screen. Each time you press the FORMAT button the screen size should change.
The screen aspect ratio settings for your TV are STANDARD, EXPAND, ZOOM, STRETCHED and NARROW. Press the FORMAT button repeatedly until "STANDARD" is displayed on the screen. If the ticker is still cut off, you need to change the aspect ratio setting on your cable/satellite receiver.
Please note: If the TV will only allow you to select STANDARD, this is not a fault. It simply means that the aspect ratio cannot be changed on the TV because it's displaying a picture from an external source, i.e. a cable/satellite receiver.
You should then look for a button on the front of your cable/satellite receiver or the cable/satellite remote control marked "FORMAT" or "ZOOM". When you have located this button, try pressing it repeatedly until the ticker is both fully on the TV screen and the picture covers the entire screen.
If you don't have a FORMAT or ZOOM button for your cable/satellite receiver or you are unable to set the picture size correctly, leave the TV set to STANDARD and then reply to me with the brand and model number of your cable/satellite receiver. I will then be able to assist you with finding the correct picture settings and give instructions on how to set these correctly.
I hope this helps - please post back here if you need further assistance.
Regards,
BElectric
Jan 15, 2011 | Mitsubishi WS-73909 73" Rear Projection...
When i turn the TV to vid1 is has a crisp clear picture but when i turn hit the satellite button it goes to chanel 3 and is fuzzy (grainy looking). Any suggestions? I cant leave it on the vid1 channel...
Get a surround sound system. Run the video to av1, and then the red, and white audio cables to your surround sound aux. You will get the clean picture and great sound.
May 05, 2010 | RCA HD52W59 HDTV Projection Television
My Zenith C32V28 television does not display the top and bottom of the picture. I phoned Zenith tech support who told me that it was the satellite signal. I called the satellite provider who advised me it...
This is applicable to Bell Television Services (Canada)
I solved the problem myself after two calls to both Zenith and Bell Television satellite service. On the bottom left of the Bell remote control there is a * (STAR BUTTON). Press this * button and within two seconds you must press the channel change button up or down. This will do two things. One; it changes the channel; and also changes the ratio of the satellite signal. There are three satellite signal ratio settings. Try this when you are tuned to a TV channel such as BNN (Canada) (Business News) or The American channel which has a stock ticker usually displayed along the bottom of the TV screen. Select the ratio (setting) that allows the stock ticker to be displayed......hope this helps.........Jim McP
Nov 10, 2009 | Zenith C32V28 32" TV
'satellite' icon not available to retune digital channels
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Sep 30, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Magnavox, channel buttons cycle through sources
You need to reprogram your TV if you do not have a cable box or satellite box, otherwise those are going to be the only channels that the unit will pick up. If you do have a cable box or satellite box, just hit 0-3 or 0-4 if you are using a coaxial wire. If no box is present, you can just go into the menu and hit autoprogram - select cable for direct cable from wall, and antenna for antenna. Note: this particular TV is going to need a box in another 5 weeks due to the DTV transition, so my solution will only carry you for another few weeks.
-Tha Mp3 Doctor
Jan 11, 2009 | Philips Magnavox 20MS233S 20" TV
Snowy picture with catv 1 mono on screen
is tv making some.. sound...please tell me..
Oct 20, 2008 | RCA TruFlat 27F520T 27" TV
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Phillips projection no picture
It sounds like you hit the AV button. Try hitting it again until you see a picture.
Dec 24, 2007 | Philips Magnavox 51MP392H Rear Projection...
Westinghouse W4207 42 in. HD-Ready LCD TV Logo
139 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
