Question about Nikon Speedlight SB-800 TTL Flash
I have a SB-600 press the flash button and it doesn't work. It will not flash.
    Champion:
  • Nikon Expert
  • 225 Answers
If after doing a battery test it still will not flash you could look inside the battery compartment to see if there is corrosion. If not call Nikon 1-800-645-6689
Posted on Aug 30, 2010
My nikon d90 doesn't works when i put the flash sb-600
Could you provide some details? How does it not work? Does the D90 not turn on? Does it take a picture but the flash doesn't go off? What exposure mode(s) are you using?
Apr 02, 2013 | Nikon Speedlight SB-600 TTL Flash
How I can reset factory set from Nikon Speedlight SB-600?
To reset your Nikon Speedlight SB-600 you need to press Mode + ON/OFF, both buttons simultaneously for approximately 2 seconds to reset all settings, including the custom settings (except the distance unit selected in m/ft) to their default values.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this free solution.
Oct 01, 2010 | Nikon Speedlight SB-600 TTL Flash
I have a sb-600 flash. It works fine but it has
Try doing a reset - press the "Mode" and "On/off" buttons together for a few seconds and you go back to factory settings. Sounds like you got into some funky mode, assuming everything else is working ok.
Mar 09, 2010 | Nikon Speedlight SB-600 TTL Flash
Using SB 800 flash Master with 2 SB 600 as slave
Hi Frank, I use the same combination of the exact three flashguns you have. Works beautifully. I mount the sb-800 on my camera and set it to Master Mode (press and hold the center button till the menu comes up, select the master). Set the other two sb600s as slave. Please make sure the channel is set the same in all three flashes... when positioning the slave flashes, make sure that sensors on the remote will recieve the light from the main flash. For maximum coverage I use the sb-800 with a diffuser in bounce mode. You will be amazed at the quality of interior phots you can get with a 3 flash combo.
Apr 18, 2009 | Nikon Speedlight SB-800 TTL Flash
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Flash is not working for a nikon sb-600 speedlight
    zoom the flash all the way in so you can see if the flash bulb is broke
    Mar 06, 2009 | Nikon Speedlight SB-600 TTL Flash
    Sb-600 and d80 sync, connecting, off camera..
    1. On the SB 600, activate the custom settings menu by pressing the ZOOM and '-' buttons simultaneously for a few seconds.
    2. In the custom settings menu, set the Wireless Remote Flash option (indicated by a curled arrowhead) to 'ON' (use + and - buttons to toggle between options)
    3. Set the flash mode to Master (do not set it as AA or A)
    4. Press Mode button and select one of the four channels available (ensure that you set the camera also on this channel)
    5. On the D80, from custom settings menu, select Built-in-flash
    6. Set the built-in-flash to '--' if you do not want the flash to show up in the scene
    7. Set the mode of the group to i-TTL (this menu can be used to control multiple flashes in different groups. since you are using only one remote flash, select the group you have set in the SB600)
    8. Set the channel to the same as in step 4
    Now you are ready to use the remote off-camera flash.
    Jan 24, 2009 | Nikon Speedlight SB-600 TTL Flash
    Settings for sb-800 to control external sb-600
    set the SB-800 as the commander and SB-600 as the slave. Press and hold the mode button to open up the menu and select the options.
    Mar 25, 2008 | Nikon Speedlight SB-800 TTL Flash
    SB 600 Not resetting...
    my sb 600 speedlight won't turn on. Do I need to reset it? It has fresh batteries. Never been dropped
    Jan 21, 2008 | Nikon Speedlight SB-600 TTL Flash
    Nikon Speedlight SB-800 TTL Flash Logo
    44 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
