Question about Prevention Wrist Blood Pressure Monitor WS-820PV
I don't have my manual so could tell me what dose it mean when the second little heart blinks? Thank you
Irregular Pulse Rhythm
Posted on Sep 03, 2010
  • PunAddicted Sep 03, 2010
    From the manual:
    "Irregular pulse rhythm can bea result of body movement during measurement or can be because of arrhymias. Although constant appearance of the indication under quiet measurements may suggest arrhythmias, do not make any judgment on your own before consulting with your doctor."
What does the heart on the monitor means?
The blinking heart symbol indicates that the unit is slowly decreasing the pressure in the wrist cuff. This is when the unit is finding your Diastolic blood pressure. This is a normal symbol on most automatic blood pressure monitors. When a nurse or doctor uses a manual blood pressure cuff and listens to the blood flow, they will record the systolic pressure when they first hear the heart beat. Then they record the diastolic measurement when they can no longer hear the heart beat.
The manual for the KS-7902 is available here: http://pharmasupply.com/wordpress/pdf/wristman .
I hope this helps.
Aug 08, 2014 | Advocate Wrist Blood Pressure Monitor...
Toshiba satellitep205d-s7438 won't boot up
You need to be more specific and tell what happens when you plug in the power cord and press the power button. There are a number of reason why a computer will not boot, but if you tell what's going on someone can help you.
Computers don't boot for basically the following reasons, 1) the power supply is bad. That means when you plug it in you don't see any lights, and when you press the power button nothing happens, you hear no fans, no beeps, no blinking lights, no hard drive spinning, no cd drive clicking and nothing appears on the lcd screen.
2) A motherboard issue, usually when this happens you will either see blinking lights or hear beeps. Those blinking lights and beeps are codes that tell the technician what is really going on.
3) Static Buildup - try removing the battery and the power cord then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back in (leave the battery out) and Press the Power Button. If it boots up you had static buildup and can replace the battery, count your blessings and Thank The Lord cuz a dishonest repairman would have told you he had to replace the motherboard for $300
Mar 20, 2012 | Toshiba Satellite P205D-S7438 Notebook
The low tire light is on
  1. Check and fill all the tire to the proper PSI (usually 35 PSI)
  2. Now open the drivers door.
  3. On the side of the dash is a little access panel that pulls right off.
  4. Now you will see a little red button to reset the low tire pressure light.
  5. First turn the ignition to on (don't start the car).
  6. Now press and hold that button for 10 full seconds until the low tire light begins to blink.
  7. Now release the button and wait for the light to stop blinking.
  8. Now turn the ignition off and back on.
  9. The light will now be off.
  10. Replace the little access panel.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 20, 2011 | 1999 Buick Regal
Looking for a manual for this Heart Rate Monitor. I cannot seem to clear the data that is installed already and start reset it. Monitor is telling me that the data is full Apprecaite any assistance...
Not sure which Heart Rate monitor you have, but if it is a Polar then you can download the manual on the link under my tips and tricks page.
if you have something other than a Polar, what is the brand and model, that is important to be able to tell you how to program it.
Dec 09, 2010 | Exercise & Fitness
Power light comes on then turns off tv dose not come on
Perform the self check that this set should have: when you turn it on and the power light goes off:
On the front of the set press and hold both the MENU and INPUT (OR DEVICE) BUTTONS AT THE SAME TIME FOR AT LEAST 5 SECONDS----then release both buttons.
The power light should blink a two digit error code--for example----------2 blinks, a pause and 2 blinks--this is the most common one and the easy one to know what is wrong.
Let me know what you find and I will tell you what it means.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 14, 2009 | Mitsubishi WS-65869 65" Rear Projection...
I bought a my little pony castle at a yard sale and the instruction manual was gone. Written on the plastic bag said the pony that made the castle work was included. what does this mean and how does it...
If it is the same castle we have, when the magnetic foot on the bottom of the pony is placed on the heart (that is also magnetic) at the top of the yellow staircase, it will start the music and lights blinking. Hope this helps.
Sep 11, 2009 | My Little Pony Toys
Tv turns on for two seconds, shuts off, begins binking.
The problem is most likely a power supply related problem.
The TV is in protection mode right now. It's keeping the other parts inside the TV from being damaged by automatically turning itself OFF. The 9 blinks should be an error code for the problem with the power supply. I don't have the Service Manual for your TV model number to tell you what the code means and which part to replace. Every brand of TVs have a different meanings of the code.
If you have electronic experience, you can find a factory repair manual over the internet. Normally, it's called a Service Manual. It costs about less than $20.
Jul 31, 2009 | Panasonic TC-26LX70 26 in. LCD Television
Prevention Wrist Blood Pressure Monitor WS-820PV Logo
231 people viewed this question
Top Prevention Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Prevention Health and Beauty Expert? Answer questions, earn points and help others
